Welcome to the North American Subaru Impreza Owners Club Wednesday July 30, 2014
Old 09-17-2010, 11:09 PM   #1
snowflowmfg
Member#: 163700
2013 Impurzer
wFc #270
Default The 3.3 ohm resistor fix is no longer working. :(
Hey guys. I have an aftermarket seat in my car and i've been using two 1 ohm and a 1.5 resistor (equivalent to 3.5 ohms 1/4w) in line to fool the airbag light for many months now with great success, but I accidentally broke one of the resistors while moving it.
I replaced them with new sets of 3 resistors since I couldn't find a 3.3 exactly in any store. So the problem is that the airbag light won't turn off anymore. What happens is that it goes away for a couple seconds then turns right back on again. I have no idea what the problem is. I've tried several different resistances like 3.2, 3.4, 3.6 etc and it always turns off then back on again. I've checked the fuses as well and don't have a multimeter to check resistance of everything.
Does anyone have any idea what the problem could be? and how I can fix this? I'm going to try to order some 3.3 ohm exact resistors to see if that will fix the issue.
TIA
snowflowmfg is offline   Reply With Quote
Old 09-17-2010, 11:15 PM   #2
cowboy_Rob
Member#: 194062
2003 Impreza WRX
it could be a problem somewhere else in the system. its checks more then just your seats. you need to scan the code and start from there
cowboy_Rob is offline   Reply With Quote
Old 09-17-2010, 11:18 PM   #3
subaru3169
Member#: 55252
* pullup bar *
personally, those resistors never worked on my car.. works for my steering wheel one, but not the seat
mine somewhat worked briefly intermittently.. at startup, the light was on for about 10secs then the light would go away for the rest of the drive.. that only happened randomly for a couple weeks and simply stopped working.. now, i just drive without the resistor at all
subaru3169 is offline   Reply With Quote
Old 09-18-2010, 02:38 AM   #4
snowflowmfg
Member#: 163700
2013 Impurzer
wFc #270
Does the seatbelt light have a code? Could this sort of code be pulled with my accessport?
That's exactly the problem i'm having now. It used to work fine, but now it only stays off for a few seconds.
Old 09-18-2010, 03:33 AM   #5
subaru3169
Member#: 55252
* pullup bar *
yaa i got so fed up that i mailed all of my remaining resistors to a guy up in tracy
or perhaps my car's haunted idk
Old 09-19-2010, 02:46 PM   #6
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
there was a post here, not too long ago, by someone who said that they worked in designing airbag systems...and going by his post---it seemed that he did.....this guy said that 3.3ohm was a bit much and the actual value is usually less....dont remember the exact number but...
it seems that the '3.3 ohm' value may be another 'myth' that has perpetuated
Old 09-21-2010, 01:06 AM   #7
snowflowmfg
Member#: 163700
2013 Impurzer
wFc #270
Thanks for the heads up scotty. I tried a 2.4ohm combo as well and it had the same effect as the "3.3" combo. Of course the problem i'm having is that the light turns off then immediately turns back on. So the car did recognize the lesser than 3 ohm value as enough to trick it.
Old 09-21-2010, 02:33 AM   #8
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I'm not familiar with the circuit the resistors are being used in but I can't believe that the resistances being mentioned here can really make a difference. They are so low that even wire connections would be significant. I have never seen anything in a car system that sensitive.
Old 09-23-2010, 07:09 PM   #9
snowflowmfg
Member#: 163700
2013 Impurzer
wFc #270
bump, any ideas?
Old 09-23-2010, 07:13 PM   #10
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
Originally Posted by snowflowmfg View Post
bump, any ideas?
wonder if something in the airbag/srs 'puter fried!?!??!?!?!?!
Old 09-27-2010, 07:01 PM   #11
snowflowmfg
Member#: 163700
2013 Impurzer
wFc #270
I sure hope I don't find that out the hard way!
Old 10-05-2010, 09:45 PM   #12
MykuL
Member#: 122451
01 RSTI w/07 EJ257
6MT Brembos BBSs Interior
Alright, I have to ask. All these resistors that you're using to add up to 3.3ohms; are you connecting them in series or parallel? If they're in series they add resistances, but if they're in parallel they're doing the opposite.
Sorry if you've already checked this, but it would be an easy fix.
MykuL is offline   Reply With Quote
Old 10-14-2010, 11:47 PM   #13
snowflowmfg
Member#: 163700
2013 Impurzer
wFc #270
They're in a series. Like I said, i'm doing the same thing that worked before...except its no longer working.
Still no luck.
Old 10-18-2010, 10:39 PM   #14
snowflowmfg
Member#: 163700
2013 Impurzer
wFc #270
bump...
Old 10-19-2010, 12:58 AM   #15
sanjosuby
Member#: 217877
2007 6speed vf37 WRX
damn where did you get the resistors, ive been staring at an airbag light for over a year
sanjosuby is offline   Reply With Quote
Old 10-19-2010, 01:14 AM   #16
snowflowmfg
Member#: 163700
2013 Impurzer
wFc #270
You can try fry's, or an audio shop. I personally went with a 2.5 ohm and a 1 ohm in a series. It worked for like 6 months.
You can also order from ebay. You get like 200 for $5 or so. (if you buy those, you should send me one.
Old 10-19-2010, 01:36 AM   #17
chRS
Member#: 228073
try using 3x 10 ohm resistors in parallel, they add up to exactly 3.33
chRS is offline   Reply With Quote
Old 10-23-2010, 11:15 PM   #18
Abnormal
Douchebag Moderator
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Pull the airbag code and go from there... search, the method to do so is out thdere.
Abnormal is offline   Reply With Quote
Old 10-23-2010, 11:35 PM   #19
snowflowmfg
Member#: 163700
2013 Impurzer
wFc #270
Will the airbag light have a code? Can my AP v2 pull it?
Old 10-23-2010, 11:44 PM   #20
snowflowmfg
Member#: 163700
2013 Impurzer
wFc #270
Alright, so out of the blue, I plugged in my clock (I removed it for some gauges) and now the airbag light goes off. So on my 07 wrx, pulling the clock trips the airbag light. Now, the issue is how can I continue to run my clock pod and keep the airbag light off?
Old 10-24-2010, 12:22 AM   #21
snowflowmfg
Member#: 163700
2013 Impurzer
wFc #270
Well my multimeter is broken, I was going to try to trick the plug with some resistors, but I just took the clock assembly apart and took the plug itself and just put it in and taped it away under the gauge pod. Everything works now.
So for all 06+ wrx owners....you will throw an airbag light if you unplug the clock!
Old 10-24-2010, 06:12 AM   #22
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Would have helped if you had mentioned earlier that you removed the clock pod. In an '06-up you can't unplug it because of the passenger airbag system, removing the pod will cause a permanent airbag light. The way around it is to leave the pod plugged in, and stuff it behind the dash someplace.
Old 10-24-2010, 12:27 PM   #23
snowflowmfg
Member#: 163700
2013 Impurzer
wFc #270
I didn't even think of any remote relation to it. I actually even forget I ever pulled the clock.
And yes, I did that and work like a charm now.
Old 10-26-2010, 02:05 AM   #24
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
ding
ding
and
****ing
DING
As of June 23rd I no longer work at Pence. My position is open. blackfang Mid Atlantic Impreza Club -- MAIC 19 06-27-2010 03:33 PM
The part of my car that I love the most is no longer RedBean Member's Car Gallery 30 02-23-2006 10:27 PM
Airbag fix with 3 10 ohm resistors slick50 Electrical & Lighting 4 05-01-2005 12:18 PM
The 213 Things Skippy is No Longer Allowed to Do in the U.S. Army Damn Yankee Off-Topic 27 03-21-2005 09:57 AM
('93-'01) Help, the old URLs no longer work! Caron Impreza Forum 3 06-28-2001 06:59 PM
