Old 09-18-2010, 03:13 AM   #1
sorrowfulkiller
Member#: 170439
I <3 Lamp
Default Looking for info to remove stock fuel lines
As the thread title says I'm looking for tips and info on taking out the stock lines that run through the cabin, I already have the interior minus the dashboard out.
sorrowfulkiller is offline   Reply With Quote
Old 09-18-2010, 10:47 AM   #2
sidewayz
Member#: 5810
2001 S366 2.5RS
What is your reasoning to pull the lines? You have to pull the dash, carpet, panels, seats, etc etc. Oh and I assume your pulling to the tank as well so the rear drivetrain has to come down to pull the tank too
sidewayz is offline   Reply With Quote
Old 09-18-2010, 01:10 PM   #3
sorrowfulkiller
Member#: 170439
I <3 Lamp
I'm going with a fuel cell and want to get rid of the stock tank. So I figure may as well just get rid of the lines while I'm at it.
Old 09-18-2010, 01:28 PM   #4
MartinSTi05
Member#: 145145
2006 wrx STi
I cut them at the B-pillar. Then I pulled therm through the firewall grommets.
MartinSTi05 is offline   Reply With Quote
Old 09-18-2010, 02:11 PM   #5
sorrowfulkiller
Member#: 170439
I <3 Lamp
I see, alright. I'll probably call you tomorrow if I need to ask you anything else. Hopefully I won't have any problems. Did you have any issues with pulling the tank or did you just drop the rear diff and pull it out?
Old 09-19-2010, 06:51 PM   #6
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
If you are smart/handy enough to install a fuel cell i would hope you could remove some little fuel lines.
Token-Negro is offline   Reply With Quote
Old 09-19-2010, 10:56 PM   #7
sorrowfulkiller
Member#: 170439
I <3 Lamp
Installing a fuel cell is simple enough. Taking out fuel lines could be a pain because of how they're routed.
what to look for when buying a vf39? td04 lines cross over? junior1023 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-19-2010 02:44 PM
what to look for on a vf39? also, td04 lines all transfer over junior1023 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 09-18-2010 05:42 PM
Having trouble finding info on how to remove stock WRX Stereo turkey187 Car Audio, Video & Security 1 04-20-2004 09:32 PM
Looking for instructions to remove door panel blacktideao Car Audio, Video & Security 2 02-13-2004 11:41 PM
Looking for a Digital Wideband Air/ Fuel Meter. Which one to buy $600 to spend on it. STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-24-2003 10:34 AM
