Old 09-18-2010, 05:37 AM   #1
DTDivad017
Member#: 95568
2002 wrx
white
Default HID Changing colors?
Hey guys, i noticed today that my passenger side HID has turned a slight tint of yellow. before both sides would look equally blue. does anyone know why this happen? and what can i do to fix this problem?
DTDivad017 is offline   Reply With Quote
Old 09-18-2010, 06:03 AM   #2
subaru3169
Member#: 55252
* pullup bar *
the bulb probably went bad
subaru3169 is offline   Reply With Quote
Old 09-18-2010, 10:20 AM   #3
CRAZYHAWK
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
+1 ^ They turn yellow and orange before they burn out.
CRAZYHAWK is offline   Reply With Quote
Old 09-18-2010, 05:32 PM   #4
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
It's probably a crappy Chinese kit, isn't it? They color shift to all kinds of weird colors. I've seen them turn green.
All the OEM bulbs I've seen have color shifted to a much bluer hue, they then last a good while longer, before they die.
Are they taking longer to start up, or doing anything strange while starting or warming up?
FourOnTheFloor65 is offline   Reply With Quote
Old 09-18-2010, 05:53 PM   #5
DTDivad017
Member#: 95568
2002 wrx
white
Nothing out of the ordinary but that particular side did go out once and all i did was turn it off and turn it back on and it was fine again. Now can I just change the bulb or is it something that I have to change the whole HID setup?
Old 09-18-2010, 06:15 PM   #6
CRAZYHAWK
Member#: 198067
WHITE Premium
Kits from
www.ddmtuning.com
are inexpensive, $50 with shipping.
They take around 2 weeks to ship.
Old 09-19-2010, 01:59 AM   #7
timmahhh
Member#: 258220
It may also be the voltage regulator; HID regulators have two phases of operation, initially there is a fire up high voltage phase and then there is a maintenance/operating phase that keeps the bulb running. On my TL my right side would fire up fine but after a few minutes it would turn bright pink and sometimes flicker... the bulb itself was ok, but the regulator was bad.
Hopefully it's just your bulb but you may want to get it checked so you don't waste money on new bulbs that may get taken out by a faulty regulator/controller
timmahhh is offline   Reply With Quote
Old 09-19-2010, 02:31 AM   #8
DTDivad017
Member#: 95568
2002 wrx
white
Thanks everybody for all your inputs
Old 09-19-2010, 04:41 AM   #9
lcjarrett
Member#: 133814
2008 AW STI
bulb went out...I just changed my bulb because it turned a tint yellow color.
lcjarrett is offline   Reply With Quote
FS: HID any color any blubs sum0325 SCIC Private Classifieds 5 10-28-2008 02:53 PM
Do HID bulbs change color just before burning out? cringeR Electrical & Lighting 13 12-14-2005 05:12 PM
STi projector HID retrofit color question DLUX WRX Electrical & Lighting 3 08-03-2003 02:21 PM
HID Bulb Colors/Levels??? vict116 Interior & Exterior Modification 0 02-11-2001 03:37 AM
