Old 06-24-2002, 06:13 PM   #1
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
Default need help: Adding (2)12v Fans to my Air/Air IC
Would you guys think this would give me a few more pounds of boost to safe out?
I am thinking about tapping into my 12v electrical system so I can mount two fans under my Hood Scoop Intercooler like this:
== <-- intercooler
/ \ <-- 2 fans underneath angled to blow towards exhaust housings
Would it make more sense for the fans to blow to the bottom of the car so that that fan suction is at the hot side or would it make more sense for the fan to blow directly at the intercooler rather than sucking away the heat?
I am thinking of using the fans to suck away hot heat and blow it off... HELP!!!! Theoretical experts arise!
STi-Nismo Dood is offline   Reply With Quote
Old 06-24-2002, 07:25 PM   #2
cammy712
Member#: 6576
2001 Impreza 2.5 RST
I read that with on a radiator the fans that pull the air through are much more effective then fans that push the air through. That should hold true for the intercooler so go with the fans that pull the air though.
cammy712 is offline   Reply With Quote
Old 06-24-2002, 07:34 PM   #3
STi-Nismo Dood
Member#: 4149
MY93 Impreza 6MT
GC8.6 Aspen White
Thanks! I will install the fans right beneath the intercooler, so the contained Intercooler heat will be sucked out by the two fans and then blowed to the floor/exhaust housing. Doubt this will increase performance while on the freeway... but I hope this will resolve some degrees on heat-soaking at the stoplights... I mean the stupid giant intersection ones where you have to wait like five minutes for your green.
Old 06-24-2002, 07:43 PM   #4
cammy712
Member#: 6576
My turbo is in the mail and I was thinking about finding a washer fluid tank and filling it with water/ice to have it spray the intercooler whenever i needed a little extra cooling. just an idea
Old 06-24-2002, 09:11 PM   #5
STiTuner
Member#: 5778
09 135i
Jet Black
get a seperate water pump and water cooler core and mount it in the fender or at the front of the car route the turbo cooling through the new cooling unit.. maybe get the turbo a bit cooler.
and if you want to use fans use the underneath the IC since they won't be as pron to be damaged by the natural elements.
Brad
STiTuner is offline   Reply With Quote
Old 06-25-2002, 02:36 AM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
you'd be better off using a water spray...is this for drag race purposes or daily driving??
jeremy
Old 06-25-2002, 06:24 AM   #7
Ethan
Member#: 246
The old Minnam Stage 3 kit used to fans on top of the IC
Ethan is offline   Reply With Quote
Will adding a Fuel Pump to my Stage 2 STI allow me to get more power? whitesuby22 Newbies & FAQs 9 06-14-2007 12:01 AM
WTB, but need help: EVO 2 or Fujitsubo and which downpipe? gharari Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 08-02-2006 09:49 PM
Adding a 12V outlet to cargo area of WRX? banman Electrical & Lighting 2 09-07-2005 02:57 AM
Adding 2 turbo subaru's to the family... rhdude Mid Atlantic Impreza Club -- MAIC 19 08-22-2003 06:36 PM
Added more Scoobnuts videos to my site 8Complex General Forum Archive 12 03-09-2001 12:36 AM
