Old 09-18-2010, 11:29 PM   #1
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Default Victim of Det?
I read mostly about cracked ringlands on the pistons, or spun bearings. It looks more like a lean condition on the cyl. Trying to figure out exactly what caused the erosion of the piston/ it melting to the bore. Sorry the second pic is from my phone.
340Duster is offline   Reply With Quote
Old 09-18-2010, 11:33 PM   #2
NitroTrike
Member#: 62408
2002 wrx w/ STi guts
174k miles on Mobil 1
Were those marks in the cylinder, or it that from you trying to free it up??
NitroTrike is offline   Reply With Quote
Old 09-18-2010, 11:36 PM   #3
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Thats aluminum of the piston melted onto the steel of the bore. The engine was running when I pulled it.
Old 09-19-2010, 09:08 AM   #4
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Nothing?
Old 09-19-2010, 09:14 AM   #5
quazimoto
Member#: 70395
Probably. Its not like there are a whole lot of possibilities here. What mods were you running?
quazimoto is offline   Reply With Quote
Old 09-19-2010, 03:18 PM   #6
yaya20
Member#: 130354
Looks somewhat familiar... I'd start by getting your injectors checked out. Looks like cylinder 3???
Here is mine:
yaya20 is offline   Reply With Quote
Old 09-19-2010, 06:42 PM   #7
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Here is mine:
Thats exactly what I came up with today, I think its an injector failure, but Idk... I suppose #3 is more prone because its probably the hottest running cylinder. I have pictures to add.
Old 09-19-2010, 06:47 PM   #8
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
I think it ran lean and melted the piston, but thats my guess, I'm looking for other opinions
It was a Cobb stage 2, then was open source tuned to run 18-19 psi on just a ported TD04. I have a large TMIC, short ram and exhaust. Thats pretty much it for engine mods.
Old 09-19-2010, 07:18 PM   #9
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
Man thats not fun.
sackytar is offline   Reply With Quote
Old 09-19-2010, 07:22 PM   #10
yaya20
Member#: 130354
I wish I could give you more info. I just got the results from my injector test last week and they were fine. Mine was a built ej205.
The clean piston top makes it look like the cylinder wasn't getting fuel. But it's possible that after the loss of compression the heat and the fuel washed away a lot of the carbon build up. Injector is the first thing I would check. After that I'm all ears.
Old 09-19-2010, 07:23 PM   #11
yaya20
Member#: 130354
Here is my cylinder wall too:
My motor has not been broken down yet as I doubt anything in it will get reused.
Old 09-19-2010, 07:37 PM   #12
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Yeah I am right now looking to find someone to flow test them. I'm working on a new build, only the cams from that engine are being reused. I need to figure out what caused this though. Next is to post this to the built motor discussion, people with more engine experience hang out there.
Old 09-19-2010, 07:52 PM   #13
yaya20
Member#: 130354
I suppose a bad coil could be an issue, but I would think you would have misfires before it got to that point of destruction.
Old 09-20-2010, 12:11 AM   #14
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Yeah there was no CEL at all or anything other than the loss of power when the compression went to almost 0.
Have you had your tune looked at or the car logged for any issues on that side of things?
Old 09-20-2010, 12:24 AM   #15
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Old 09-20-2010, 08:48 AM   #16
yaya20
Member#: 130354
I had no previous CEL either. I was on the highway at about 15psi and building boost then boom and no power. I literally had zero compression in that cylinder.
I have not had the tune looked at by anyone other than the original tuner and no logging as the car was run as little as possible since the incident.
Interesting article btw.
Old 09-20-2010, 12:28 PM   #17
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Same here, except it was around 19psi, and I had the tuner go over the map, He said all the AFR numbers and timing were within the normal range for the setup I was running. So
Old 09-20-2010, 12:56 PM   #18
yaya20
Member#: 130354
Sounds like we are in the same boat. I'm going to see about maybe tearing down my block pretty soon and see how the skirts and rings look on the rest of the pistons. Maybe something that can show me if it was tuned too rich.
Hopefully some other folks will chime in here with some ideas.
Old 09-20-2010, 01:34 PM   #19
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
No I agree, I don't see how too rich would cause it though? I could see in the case of a bad injector, the AFR was in line with by running 3 cyls rich and one lean. That was my earlier thought.
Old 09-20-2010, 02:42 PM   #20
yaya20
Member#: 130354
The article you linked described how it would be possible in a situation that is overly rich...
Old 09-20-2010, 04:12 PM   #21
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Yeah, I just don't understand the lifting of the ringland, I would think in a cast piston it would simply crack. People talk about tiny amounts of fuel getting combusting and blowing the ring lands all the time.
Where's Soobaviator when you need him?
Old 09-21-2010, 09:16 AM   #22
yaya20
Member#: 130354
If the ring were to get pinched and allow enough oil to get into the combustion chamber, then there would be detonation. Now, if the oil was to pool a little on the bottom then start to combust (oil burns hot and slow), then I could see it melting a piston in the location we both had it happen in.
Old 09-21-2010, 09:51 AM   #23
NitroTrike
Member#: 62408
Did this thing have a blown head gasket on that cylinder?
Old 09-21-2010, 07:27 PM   #24
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Nope, head gasket was good. Has no one else melted a piston in one of these engines?
And does that seem like a rich problem or an oil control problem? how many miles were on your engine before it died?
Old 09-21-2010, 10:56 PM   #25
06PrecisionSTI
Member#: 238755
2006 IMPREZA WRX STI
BLACK ON BLACK
3 is the leanest cylinder and if the injector failed on 3 then the lack of fuel would be the problem. unless tthe rings were that bad then there would not be enough oil blow by to cause that. noow the guy with the built motor if the builder did not properly stager the ring groves then detenation could have ccaused yours but other than that. i would look at injectors if a coil goes bad then it wouldnt fire it fire unless told to do so. then that would be a computer problem. so guy i would have some one else look at the tune other than the orignal tuner he would not admit he messed up no matter what. to lean on that cylinder is what will cause that because it is the hottest cylinder and to rich wont huurt anything but power.
06PrecisionSTI is offline   Reply With Quote
For those of you that are victims of road rage, I found the solution to the problem! brucelee Off-Topic 78 02-15-2008 03:35 AM
Help! cause of det or knock DemiSlayer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-23-2007 12:46 AM
The sound of det BoomerRS Newbies & FAQs 15 02-01-2006 08:09 PM
Another victim of the Long Island Expressway BlueDevil Tri-State Area Forum 17 09-06-2002 08:37 AM
Victim of a driveby whitewag Mid West Subaru Owners Club Forum -- MWSOC 16 12-24-2001 01:18 AM
