Old 09-19-2010, 11:56 AM   #1
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
Default Finally starting to look at engine parts
ok well i am finally starting to collect stuff for my v8 207 motor, now first this is going to be piston, thinking about 4032 because im not going to alot of power, maybe 400, but it will be higher boost because i will be running e85 most the time, but also 93 just depends where i am at. now i want to run around 9:1-9.3:1 yes i understand at these CR's i wont be able to run as much timing, i tune my own car so im not so worried. so my question is where can i get pistons with this CR??? will they have to be custom??? i think they will just be drop in, i will be getting the block checked soon, but walls look good just need to make sure its not ovaled.
seanathanq83 is offline   Reply With Quote
Old 09-19-2010, 01:31 PM   #2
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
I think cp has ots pistons that are 9.0 to 1 for the 207.
john 1badSTI is offline   Reply With Quote
Old 09-19-2010, 03:49 PM   #3
seanathanq83
Member#: 173241
Sweet thanks I will look
Old 09-19-2010, 08:41 PM   #4
seanathanq83
Member#: 173241
started looking, and i only see 9:1 for 2.5 this is a jdm 2.0 liter, anyone else know of anywhere??? also since i will basically be building this for DD would it hurt drivability if i go with +1mm exhaust valves??? the heads have already been cleaned up a little over the big port they already are.
Old 09-20-2010, 05:39 PM   #5
seanathanq83
Member#: 173241
anyone else????
Old 09-21-2010, 10:40 AM   #6
StupidFastWagon
Member#: 157526
2014 335i xDrive
M Sport
You might as well just stick with rebuilding the block. Your heads are prob not a restriction if your still using the VF37. Just put some std comp 2.0 cp pistons in and you should be good to go. You could run the 9:1 but you might get some det on the high end of the RPM with 93 but e85 should be good...
Im not an engine builder but thats what I would recommend.
StupidFastWagon is offline   Reply With Quote
Old 09-21-2010, 11:26 AM   #7
seanathanq83
Member#: 173241
well i dont race much, and will be changing out the turbo prob to a borg s200sx which is twinscroll, but i really do alot of driving in the city and its stop and go so i want the better out of boost power, i have been looking and the offer OTS for sti with 9:1 and every evo is 9:1 and i know with the avcs, and the ported ver8 heads and bigger valves i should have a better ve to keep knock away, but i just cant find alot of info on it. i am gong to atleast keep stock compression which is 8.4:1 but would really like more city driving power and when i run 93 the power and boost would be turned down so as to keep det down
Old 09-21-2010, 11:27 AM   #8
al82
Member#: 177913
2011 WRX STi PBP
http://realstreetperformance.com/store/
These guys were really helpful to me when i was building my block...hope this helps
al82 is offline   Reply With Quote
Old 09-21-2010, 11:29 AM   #9
seanathanq83
Member#: 173241
thanks i will def get in touch with them when i get some free time today or tomorrow and see what they say, is there anyone running 9:1 that can tell me how there car is reacting to the change in CR
Old 09-21-2010, 12:08 PM   #10
Nuke209
Member#: 108089
2003 WRX
NF Performance
a bit more responsive off boost compare to a dog 8.0
that's about it IMO
Nuke209 is offline   Reply With Quote
Old 09-21-2010, 12:46 PM   #11
mrboost03
Member#: 249826
agreed
mrboost03 is offline   Reply With Quote
Old 09-21-2010, 01:37 PM   #12
seanathanq83
Member#: 173241
Originally Posted by mrboost03 View Post
agreed
Part number. Or link???
Old 09-21-2010, 02:02 PM   #13
Prevent
Member#: 149114
http://www.cp-carrillo.com/LinkClick...30%3d&tabid=64'
pg 16
However i see no listings for a 9:1 EJ207 piston
Prevent is offline   Reply With Quote
Old 09-21-2010, 03:58 PM   #14
seanathanq83
Member#: 173241
Yea no 2.0 ones that high, anyone else??? I may just go custom so I can get a good quench pad, and make sure I have the valve reliefs I need
Old 09-21-2010, 04:05 PM   #15
bugeye1257
Member#: 188598
i think jscspeed.com my have them?
bugeye1257 is offline   Reply With Quote
Old 09-21-2010, 05:36 PM   #16
seanathanq83
Member#: 173241
I will check out there too, I just don't know any company who makes them for the 2.0 guess we are a dying breed with everyone wanting 2.5 and all
Old 09-22-2010, 10:25 AM   #17
seanathanq83
Member#: 173241
Ok well does anyone recommend a brand to make custom pistons???
Old 09-22-2010, 10:02 PM   #18
seanathanq83
Member#: 173241
i would have figured more input???
Old 09-22-2010, 11:26 PM   #19
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
Depends on how far you want to take it. JE has the billet pistons, the fsr's, if you want to take it that far. CP will make you a custom piston too. Expect a 2-4 week lead time when ordering them, though!
wrxwhat is offline   Reply With Quote
Old 09-22-2010, 11:37 PM   #20
seanathanq83
Member#: 173241
not really worried about time, i have had this engine sitting bagged up dissembled for 2 years now was reading about the billets and fsr's and herd the fsr were cracking but not untill around 600 and im only shooting for ~400 max. may just go through 3MI on a set that way i can get them custom and hopefully it will help with the swirl and burn especially with the higher CR i see others with higher CR just dont know where they are getting them
Old 09-25-2010, 02:00 PM   #21
PSIPROformance
Member#: 249677
cp pistons give raceeng.com a call they can set you up
PSIPROformance is offline   Reply With Quote
Old 09-25-2010, 02:19 PM   #22
Prevent
Member#: 149114
I'd say cp, their customer service and tech help is awesome. I got to talk to the designer for the ej257 pistons and he was great help
Old 09-25-2010, 07:24 PM   #23
seanathanq83
Member#: 173241
I just picked up a full set of +1mm ferrera valves so that will be another thing, making sure with avcs I wont hit the piston
finally have means to look at another car drifterx Off-Topic 13 07-06-2010 01:54 PM
Things are finally starting to look up boosted06 Off-Topic 32 05-15-2010 02:59 PM
Someone near Detroit MI to look at a car, need help check engine Adrenalinesaint Mid West Subaru Owners Club Forum -- MWSOC 16 03-24-2008 09:15 AM
Going to look at/buy wrx engine, is my part list complete? BenBortner Subaru Conversions 12 06-03-2005 11:07 PM
So, They Finally Sent An Adjuster To Look At My Car... S-K South East Region Forum 8 02-11-2003 09:43 AM
