Old 09-19-2010, 02:22 PM   #1
Strider327
Member#: 131280
2004 Impreza WRX
Default Hybrid WRX Engine Oil Leak?
I have a 2004 2.0 heads mated to a 2.5 block. However I think I have an oil leak and need to find out which correct gasket I need to use to replace it with. I have included a picture. Its located right behind the whole timing belt cover on the driver side. A part number if possible would be great and if there's any other gaskets needed to go along with it is also appreciate it.
Strider327 is offline   Reply With Quote
Old 09-19-2010, 02:42 PM   #2
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
That gasket there is not your problem. If you are seeing oil there it is either left over from being spilled while filling the oil or you have an issue with a cam seal.
LiquidForce is offline   Reply With Quote
Old 09-19-2010, 08:56 PM   #3
Strider327
Member#: 131280
2004 Impreza WRX
So far I've cleaned up that area really well and been driving for most of the day. So far no visible leaks, hopefully it was just oil spilled on there. Will continue to monitor the area.
Old 09-20-2010, 03:53 PM   #4
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
2002 Impreza WRX WRB
If your not seeing any leaks than I'd suspect the oil that was there had dripped off the dipstick the last time you checked your oil. I've done that.
PSolbergfan is offline   Reply With Quote
Old 09-20-2010, 04:16 PM   #5
Disruptin
Member#: 184564
2009 SWP Hatch
Hella Snail'd
given the area if you have cleaned it up and it conitnues to leak and you havent been letting oil fall on the area, thats the area of a cam seal.
Disruptin is offline   Reply With Quote
Old 09-21-2010, 12:08 PM   #6
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Or the front main seal or the around the oil pump or the caps for the wrist pin access... Really you need to see the leak to know what you need as it could be from many places.
PS: I can't see you pic so I don't know where you have oil
Old 09-21-2010, 01:13 PM   #7
Le Saboteur
Member#: 142244
2007 SWP STi
WFC #243
+1. take the cover off. this happened to me, but it turned out to be power steering fluid gathering in that rubber timing belt cover gasket.
Le Saboteur is offline   Reply With Quote
Old 09-21-2010, 07:27 PM   #8
Strider327
Member#: 131280
2004 Impreza WRX
I appreciate the tips guys. Yeah I've been keeping an eye on it, so far no more leaking. So knock on wood, it was probably just dripped oil.
2.5 hybrid pass. side oil leak Twiztidunreal Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 06-03-2008 11:39 PM
1.8L FWD engine oil leak yimmer Normally Aspirated Powertrain 15 07-17-2004 04:08 AM
Engine oil leaking GTKim Service & Maintenance 8 09-15-2002 06:03 PM
Engine Oil Leak ? JAnderson Normally Aspirated Powertrain 2 04-28-2002 07:40 PM
Engine oil leaking into transmission bmacauto Normally Aspirated Powertrain 5 02-23-2002 04:00 PM
