Old 09-19-2010, 05:43 PM   #1
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
Default Swapping out a 16-bit ECU for a 32-bit
I'm starting to reach the limitations of the 16-bit ECU's that come on our 2.0L's (300g/s MAF and 24.75 psi commanded boost cap). I know there are work arounds, but I'm wondering if there is a better path.
I compared the schematics of the 02 WRX ECU and the 04 STi ECU, and for the most part, they are nearly identical. It appears the fuel controller might be a bit different, and you might have to swap around a few wires. I'm not sure if the absence of the DBW parts will matter. There are a couple other seemingly minor differences.
Anyhow, has anyone tried swapping in a 04 STi (or perhaps a 04 FXT) ECU into a 02-05 WRX? If not, I might have to be the guinea pig...
thefoos is offline   Reply With Quote
Old 09-19-2010, 06:11 PM   #2
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
won't work, you would have to change pretty much everything
do your homework better
there are ways to overcome 300 g/s on 16 bit ecus
Hyper is offline   Reply With Quote
Old 09-19-2010, 08:26 PM   #3
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
Yep, look at the wiring diagrams and the factory manuals show the ECU connectors being the same. Look at the I/O, and they are clearly different. Bad information in the schematics
I wasn't so concerned about the 300 g/s because that is easy to overcome. I mainly was concerned about the 24.75 psi cap. I realize there are ways around that too. I was hoping for a simple solution...
BTW, the "do your homework better" comment is unneeded. A simple no is good enough.
Old 09-19-2010, 11:26 PM   #4
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
for the boost cap, you can get a higher reading MAP sensor.
lil'redwagon is offline   Reply With Quote
Old 09-20-2010, 01:17 PM   #5
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
doesn't matter
16bit ecu is unable to read higher that what's 255 which is maximum per bit
DBW ECUs are 4 pin last time I checked, DBC are 5 pin, so I don't see how they would be the same
Old 09-20-2010, 02:22 PM   #6
paul_p1
Member#: 77372
2005 Spec C
WR Blue
Buy an AVCR or something similar then.
paul_p1 is offline   Reply With Quote
Old 09-20-2010, 08:20 PM   #7
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
^I can certainly run a MBC or aftermarket boost controller, I was just looking for a "stock" solution. Thinking outside the box a bit and exploring other options. Obviously, those old trusty standbys are always an option.
Old 09-20-2010, 09:49 PM   #8
ThirtyTwo
Member#: 134643
doesn't matter
the 255 limit is only applicable when logging via the SSM protocol. You can implement a higher reading map sensor and log it with the "(direct)" parameter to read its full range. The ECU will also read the higher values internally, so any table with a boost reference will function when set higher than 24.75. Of course this also requires changing the MAP offsets and scalings, but thats not a big deal
ThirtyTwo is offline   Reply With Quote
Old 09-24-2010, 12:32 PM   #9
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
I don't think he is talking about logging, I think he is talking about the hard limit in the boost targets table. But why he would think that as a true limit for boost I don't know because it is not.
fastblueufo is offline   Reply With Quote
Swapped out the SSAC fmic core for the real TXS core verc Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 01-06-2010 11:55 PM
is a 65 bit double > a 32-bit double Sausage Off-Topic 19 10-17-2007 05:32 PM
Should I swap out my P.E.'s for Nismos? mindchatter Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 10-11-2005 05:21 PM
IL: Let's Swap ECU's - My 2004 ECUtek ECU for your 2004 Stock ECU Red Rexx Mid West Subaru Owners Club Forum -- MWSOC 15 06-30-2005 05:47 PM
swapping out DOHC 2.5L engine for SOHC 2.5L engine 2.5GT Normally Aspirated Powertrain 2 11-14-2001 03:58 PM
