Old 09-19-2010, 09:24 PM   #1
mcshane
Member#: 195343
1998 Impreza RSTi
Question Freaky problem (vss inside) help please!
Hi!
Okay in June I change engine and tranny for 6spd. Forgot to change vss (my car is a 98 Impreza, so 2 wire vss). I drive the car without speed reading and vss. The ecu (Ecutek flashed) never goes on fail-safe at this moment.
In July, we go for retune Ecutek. All is working good, again without vss because the internal shaft is broken into the tranny ... No fail-safe!
Once I go out from the shop, bang! Fail-safe at 4500 rpm. Okay, I don't have a vss, the tranny still unrepaired.
Now! We have repaired the tranny, I have a speed reading on my speedo, all seems to work perfect. 5 minutes later, 4500 rpm cut ... Why?? I now have a vss, I now have a reading, what is broken this time?
But, why before the retune, with NO vss no cut, and now, with vss cut-out???
Seems to be a parameter on ecu but not sure ... It cannot be the vss I think, I have a reading, it cannot be the wiring I think the car work perfect without cut for about 15-45 minutes ... I don't understand ...
mcshane is offline   Reply With Quote
Tranny Problem, 1st gear...HELP PLEASE 02trublu Transmission (AT/MT) & Driveline 7 08-30-2008 05:36 PM
PPG and 3rd gear using 4th gear syncro problem. Trans guru help please!!! hybrid gti 2 Transmission (AT/MT) & Driveline 24 02-07-2008 07:58 PM
Idling problems and wierd Cel problem.. Help please SPOOLME Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-26-2008 02:07 PM
Big problems need your help please! tunedmotors Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-07-2008 08:22 PM
HELP PLEASE!! (Much frustration inside) CrazyMike13 Car Audio, Video & Security 6 11-28-2004 11:01 AM
