Old 09-19-2010, 09:26 PM   #1
shift0246
Member#: 136553
02 bugeye,fozz
driftslut rx-7
Default aps turbo feed line
does anyone know where i can find a wrx oil feed line for a sr55? ive looked but can only find the blouch. would the blouch one work because the banjo bolt from the turbo is slightly bigger than the stock one from the stock turbo
shift0246 is offline   Reply With Quote
Old 09-20-2010, 07:54 AM   #2
shift0246
Member#: 136553
02 bugeye,fozz
driftslut rx-7
nobody knows?
Old 09-20-2010, 10:19 PM   #3
shift0246
Member#: 136553
02 bugeye,fozz
driftslut rx-7
bumps..have 2 threads by accident but still need an answer
Old 09-20-2010, 11:38 PM   #4
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
your not the only one i need one too!!subscribed!
EROCS04SBRUSTI is offline   Reply With Quote
Old 09-21-2010, 08:29 AM   #5
shift0246
Member#: 136553
02 bugeye,fozz
driftslut rx-7
bump!!
Old 09-22-2010, 01:53 PM   #6
shift0246
Member#: 136553
02 bugeye,fozz
driftslut rx-7
ok i called rallysport and they said the blouch line does not fit. they said to make a custom peice for it. ill make one up and post the details when it gets done
Old 09-22-2010, 02:21 PM   #7
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
that sounds great let us know and im wondering how different it would be from my 04 sti can you give a parts list or link thanks!
Old 09-22-2010, 02:43 PM   #8
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Don't APS turbos use garrett center section? I'm not sure but I thought there BB turbos were.
Old 11-08-2010, 06:58 PM   #9
shift0246
Member#: 136553
02 bugeye,fozz
driftslut rx-7
ok just to update this ...yes the aps sr55 does use a garret center section. i was able to get a turbo feed line kit from atpturbo.com
i got the tubo feed line along with a banjo fitting and A -3AN male to female adaptor. heres a link they come in differant lengths and what not
http://www.atpturbo.com/mm5/merchant...gory_Code=GTBB
aps turbo line shift0246 General Community 3 09-20-2010 05:36 PM
stainless steel turbo feed line bugeye-joemomma Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-22-2010 12:14 PM
Turbo feed line and drain line FP20g I3oostedScooby Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-15-2008 08:13 PM
Ss Turbo Feed Line Needed Asap!!! paulsaidhi Southern California Impreza Club Forum -- SCIC 7 05-05-2008 03:19 AM
APS turbo oil feed line SR30 SR40 SR50 SR55 Ricowrx Private 'For Sale' Classifieds 3 09-15-2004 08:54 PM
