Old 09-19-2010, 10:05 PM   #1
*6STARS*
Member#: 205327
2006 WRX TR
1970 Camaro
Default Case half bolt torque Numbers
I am about ready ready to start putting my motor together and I have been reading the FSM and I have a question, about the final torque on the bolts that are in the coolant passages. I think I am reading the FSM right the final torque is torque and turn is that right? After reaching the 13.3 FT/lbs on both RH and LH sides the bolts in the coolant passages are tightened 90 degrees (my FSM has 2 dots by the 90 this is why i'm confused) from the last torque of 13.3 FL/lbs is this right?
Thanks
*6STARS* is offline   Reply With Quote
Old 09-22-2010, 12:43 PM   #2
06PrecisionSTI
Member#: 238755
2006 IMPREZA WRX STI
BLACK ON BLACK
u can buy the factory service manual on a disc form off ebay for about 25 dollars it has evrything that the dealership has
06PrecisionSTI is offline   Reply With Quote
Old 09-22-2010, 03:30 PM   #3
sidewayz
Member#: 5810
2001 S366 2.5RS
sidewayz is offline   Reply With Quote
Block half bolts- Torque to yeild? NeedsWork Newbies & FAQs 1 05-13-2009 12:51 PM
Fuel rail bolt torque number ? ThePunisherGT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-09-2008 01:21 AM
case half hardware help, please!! wrxzzz Built Motor Discussion 2 02-18-2007 05:41 PM
New STI case halfs and STI short block with spun bearings StiScoobySnacks Private 'For Sale' Classifieds 3 05-26-2006 06:05 AM
Help: Need torque numbers for the strut bolts, brake bolts and lugnuts for wheels Sordid Philosopher Brakes, Steering & Suspension 3 11-22-2002 09:27 AM
