Old 09-20-2010, 01:02 AM   #1
andrew's bug eye
Member#: 254997
2014 Impreza
Pearl White
Default Injen intake Help
delete
andrew's bug eye is offline   Reply With Quote
Old 09-20-2010, 02:38 AM   #2
Audi20Tdriver
Member#: 206040
2009 Audi A4 2.0T
APR Stage 1
is your car MAF or MAP based? Should be very simple... vacuum lines you detached from the top section go back onto the intake.. if there is a MAF senor the injen should have a specific spot to screw it into. On my 2005 there were two lines from the air plume ontop they went into the two nubs ontop of the injen.. the MAF screwed in.. once the OE parts were out.. 5 min deal.
Edit: I think what you are calling the temp gauge is the Mass Air Flow Meter. Meaning you are MAF based. Been a while and I dont remember besides 04 off the top of my head the other MAP years. Anywhoo.. That is a very sensitive and gentile little friend. Be very careful with it or you will cause more trouble then the intake is worth.. Injens whole claim to fame on that piece is they keep the stock place and dimensions of the factory maf location. If it reached before.. it should reach now..
good luck..
Audi20Tdriver is offline   Reply With Quote
Injen intake help please andrew's bug eye Member's Car Gallery 1 09-19-2010 09:41 PM
Perrin FMIC / Blouch TD06 20G Turbo / Cobb AP v2 / INJEN DP / INJEN intake / SPT int drew11 Engine/Power/Exhaust 15 09-18-2009 08:39 PM
need help on an 05 injen intake install on an 06 2.5i skribblez32 Normally Aspirated Powertrain 3 08-23-2006 08:11 PM
injen intake install help (02 2.5RS) bahboy20 Normally Aspirated Powertrain 8 09-14-2005 08:42 PM
PE1820 spool up - Injen Intake is superior 15 extra hp! Intake test alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 54 01-01-2002 04:47 PM
