Old 06-24-2002, 09:37 PM   #1
Mariano
Member#: 56
Chapter/Region: PRSIC
1999 RS-T (Stage V)
2005 LGT LTD
Default What "settings" are you using on your ITC?
Got it installed today. Wiring was a walk in the park with the right diagram (had to use 3 different diagrams to get the job done)
Now, what are your current settings?
@ 800
@ 2400
@ 4000
@ 5600
@ 7200
Here's my set-up: (in case settings vary due to set-up)
-T03/4 (ball bearing)
-Spearco "big a$$" TMIC
-Apex'i S-AFC
-Vortech FPR
-Supra TT pump
-HKS Turbo timer
-Magnecor Cables
-3" exhaust system
-WR Pulley
-Bosh 4+ platinum spark plugs
-...& obviously Apex'i ITC
Your help would be highly appreciated.
thanx in advance,
MARIANO
Mariano is offline   Reply With Quote
Old 06-24-2002, 09:48 PM   #2
STiTuner
Member#: 5778
09 135i
Jet Black
I thought the install was easy too.
I'm still nA though so I don't think my number will help.. but +7 all the way through
Brad
STiTuner is offline   Reply With Quote
Old 06-24-2002, 09:51 PM   #3
Ch˙SacSVT
First RS in the 12's YEEEEEEEEEHA!
Member#: 129
'03 Corvette Z06
Black as in:180mph Black!
...........correction dude!!
Garrett GT Ballistic T28 B/B......
No stinkin' T3/O4 here!!
+2, +4, 0, -2, -4
and 12.56ET to prove it!!!
....cuando se cambien los inyectores, cambian los "seteos"....
Ch˙SacSVT is offline   Reply With Quote
Old 06-25-2002, 06:10 AM   #4
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
My setup is around 4 psi:
800: -2 (this is to aide in start up)
2400: -2
4000: -3
5600: -4
7200: -5
This is run along with a J&S Knock Sensor, so I get quite a bit of timing retard.
Graham
Graham is offline   Reply With Quote
Old 06-25-2002, 06:13 AM   #5
Mariano
Member#: 56
1999 RS-T (Stage V)
2005 LGT LTD
Chu (Pa-mel) O-tero:
What the hell you're doing reading my posts???
Sorry for the stinking T3/04 comment (my bad)
I just hope your setting will no blow up the car 'cause if it does..... I know where you live and i'll......
Brad, thanks for your reply.
Chu, mi "monito de baul" te manda este :monkey:
Mariano
Old 06-26-2002, 03:11 AM   #6
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
At 6,000 feet I can run more timing advance but I like to be safe.
1) For 6 psi I run NO retard on 91 octane on a hot day,
2) I can run 8 psi with no retard on 93 octane.
3) For 10 psi on a 90 degree day I run the following.
800: 0
2400: 0
4000: -2
5600: -5
7200: -5
4) At 12 psi of boost on 93 octane on a 90 degree F day. This is as much boost as I can get in 2nd - 5th gear on a hot day with my tiny 2.5" downpipe and 2 cats (only 10psi in 1st). My new 3" twin dump catless downpipe next week will help. It goes in while I am on vacation. I gteched at these settings at 13.54 @ 105.7 but speedo only said 102. This is like 9 psi at sea-level.
800: 0
2400: 0
4000: -4
5600: -6
7200: -6
For a 40 degree day on 97 octane and 14 psi I run, the following and keep up with a Z-06 to 120mph:
800: 0
2400: 0
4000: -2
5600: -4
7200: -4
Larry
ImprezaRS dot com is offline   Reply With Quote
What restrictor pill are you using on your 17psi+ vf34?? WheelsCSM Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-09-2007 03:50 AM
What radiator are you using in your Swap? John2.5RS Subaru Conversions 56 07-03-2006 09:07 PM
What size 17" Tire are you using on your WRX Wagon? makofoto Brakes, Steering & Suspension 32 03-03-2004 01:53 AM
calling all EJ20 swappers, what boost controllers are you using on your cas? Homemade WRX Subaru Conversions 15 11-27-2003 10:49 AM
What lugs are you using on your Rotas? Sandkicker Brakes, Steering & Suspension 15 10-22-2002 09:56 PM
