09-20-2010, 01:51 PM | #1 |
Member#: 234397
Vehicle:2004 WRX STI WRB 15 DGM FXT |
who ran 12sec passes sti 14.5 boost on a vf39
I have a 12 sec pass on my 2004 wrx sti on the 2.5L oem- 14.5psi boost!!
no tune Quarter Mile: 2.5L vf 39 goes 12.68 in the 1/4 mile at 107mph and a 1.76 60ft Event: quarter mile Location: Dragway 42 West salem,Ohio Ambient Temp:81 degrees Elevation:1095 ft above sea level Weather: Dark,Dry,warm Track and Conditions: concrete, clean, flat Tires: Falken 452,y series,225/45/r17 bald! Car:2004 Wrx sti Tuner: none Dyno Info:none Transmission:6spd stock gearset Gear: 1st/2nd/3rd/4th/ and 5th Peak HP at RPM: unknown Peak Torque unknown Baseline hp/tq 300/300tq sti Target Boost:14.5 Target AFR:unknown Fuel: just pump gas unleaded sunoco 94 Engine/Power Modifications: internal-none external-none or electronic components-none Driveline Modifications: transmission/gearing changes-none, final drive/differential changes-none, driveshaft changes-none, clutch-competition stge3 clutch and light street flywheel transmission on royal purple. Suspension Modifications: struts-oem, springs-cobb springs, braces-perrin rear sway bar and rear links, bushings-cobb shifter bushings. Other Modifications:no wieght removal full interior!Koyo radiator/hks bellmouth dp/hks midpipe and catback exhaust/buscher uppipe/perrin cold air intake (foglight location). post your times please thanks! !!
09-20-2010, 01:54 PM | #2 |
Member#: 225361
Vehicle:2006 wrx sti beige |
you definitely know how to drive the car but we can't see the time =o
btw did you notice the white smoke from the srt..? |
09-20-2010, 02:04 PM | #3 |
Member#: 234397
Yeah I think he smoked his tires somewhat but i did put in the thread u can't see the et in the vid. I have the slip somewhere with the others, and the video the srt guys freind recorded it.
09-20-2010, 02:10 PM | #4 |
Member#: 225361
09-20-2010, 02:15 PM | #5 |
Member#: 115056
SCIC
Vehicle:2002 psm now w/ 2.5 jesus tuned my hot rod |
Great Launch!!
09-20-2010, 03:48 PM | #6 |
Member#: 210165
Great Time and Great launch, but take your car to Thompson (if its still open... lol) and see what it runs.. then average the 2.. as i recall Thompson runs very slow compared to Dragway 42... Nice times again
09-20-2010, 08:22 PM | #7 |
Member#: 234397
yeah far as I know there still open!thanks guys anyone else run these times??4 sure its really hard on the tranny and rear axles.
09-20-2010, 09:31 PM | #8 |
Member#: 192514
Vehicle:04 STi PTE6765 10.1@138mph / JR Tuned |
i was going 13.1@103 bone stock with 90k lol i skipped 12s all together and went to 11s.. now 10s.. and soon to be sub 9s
09-20-2010, 10:33 PM | #9 |
Merci Buckets
Moderator Member#: 88606
Vehicle:2018 Grand Cherokee Velvet Red Pearl |
We have a required format if you're going to post power numbers or quarter mile results. Please see this thread for the format and update your first post.
http://forums.nasioc.com/forums/show....php?t=1858764 |
09-20-2010, 11:35 PM | #10 |
Member#: 234397
wow crazy wish mine got that fast but now its not going to run the 12s its all apart now going for upgrades I just wanted a good baseline!
09-21-2010, 12:11 AM | #11 |
Member#: 243912
Vehicle:2019 STI Limited World Rally Blue |
with a stage 2 setup and EBCS at 23 psi, stock ej257/vf48 I did 12.6 @ 111.
09-22-2010, 09:09 PM | #12 |
Member#: 234397
pass
who else??12 sec. pass.
09-23-2010, 02:57 PM | #13 |
Member#: 50315
Vehicle:0806 LGTspecB & Saab 9-2xAero5MT DGM & MBP |
intake and exhaust on an STi running 12's at a fast track/cool weather. sounds about right... let's see the boost gauge with you running catless and not spiking past 14.5
09-23-2010, 03:31 PM | #14 |
Member#: 213152
Vehicle:2004 Subaru WRX STI WRB |
04 sti, bone stock except catback exhaust.. ran a 12.873 at great lakes dragway, Wisconsin.
09-23-2010, 06:22 PM | #15 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
peak boost really doesnt mean anything.....STi's tuned to 26psi on the vf still only run 14-16 psi from 5000rpm to redline.......most of the power up there is from timing anyway....the MAFv is stagnate.
throw up a boost plot.... and what are you tuned on? |
09-24-2010, 07:05 AM | #16 |
Member#: 142029
Vehicle:2013 Forester 2008 350z, 1991 Miata BRG |
^^ I think he's saying he's not tuned at all but has a TBE, uppipe and CAI
09-24-2010, 08:31 AM | #17 |
Member#: 81102
South East
oh lawwdy
09-24-2010, 06:02 PM | #18 |
Member#: 234397
yup no tune!or spike like factory.mabe tuned on bald tires and broken rear axles to get this time at almost 6k launch and the car is all apart now like i posted earlier for a gt30 setup!12.8 is also a great run 5th was the hardest to shift you just have to tap that clutch and jam the 5th gear to a diagonal right in one quick shot!
09-24-2010, 06:38 PM | #19 |
Member#: 142029
I ran 12.7 with just a TBE and tune... not sure what the big deal is.
09-25-2010, 12:27 AM | #20 |
Member#: 234397
yup yup time 12.7 thats great!!who tuned it anyways??
09-25-2010, 08:07 AM | #21 |
Member#: 142029
^Cleo at Precision
09-25-2010, 11:09 PM | #22 |
Member#: 125529
Vehicle:02 WRX 18G EJ205 1/4 mi stock block record |
Go Ohio!.... Dragway 42 is my normal spot. Its so laid back.
09-25-2010, 11:43 PM | #23 |
Member#: 234397
did i meet u there are you the blue one with painted black bbs's
09-26-2010, 11:51 AM | #24 |
Member#: 125529
No sir. I have been in hibernation most of this year (was out a few times this spring). The Wrx is white with LGT rims
Max boost on a vf39 | mogrl840 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 42 | 06-26-2011 11:09 PM |
When is Everyone Else Hitting Full Boost on Their Vf39? | stealth06wrx | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 22 | 11-19-2007 12:19 PM |
what is the max boost on a vf39? | Arts | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 16 | 04-03-2007 05:18 AM |
who had the black sti at regal row on tuesday? | svr_wrx | Texas Impreza Club Forum -- TXIC | 28 | 12-01-2006 04:40 PM |
How much boost on a vf39 | BoxerSpirt | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 3 | 06-16-2006 03:18 PM |
