Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 06-24-2002, 10:08 PM   #1
milkman
Member#: 8066
Y2K RSt
Sedona Mars Red Pearl
Default BOV vacuum?
Hi, Where's the best place to get a vacuum line for my BOV (it's a standard HKS, one vacuum line and no adjustments)
Should I hook it up before the throttle body or after?
The reason I ask is because when it's hooked up after the throttle body I can feel air going into it, then when I unhook the vacuum line when the engine is running I can hear it slam shut. Thanks
milkman is offline   Reply With Quote
Old 06-24-2002, 11:11 PM   #2
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
You have to get vaccuum after the throttle body. there isn't much (if any) vaccuum before the throttle body. ANy old vaccuum port is fine
Eric
Eric SS is offline   Reply With Quote
Old 06-25-2002, 06:18 PM   #3
milkman
Member#: 8066
Y2K RSt
Default Thanks
Thank you, that's what I was thinking but wasn't sure because my BOV was sucking air into it, is that suppose to happen?
WRX BOV vacuum line on a XT dodken 'Old School' Subaru Forum 4 07-31-2007 07:55 PM
TurboXS RFL BOV vacuum stichris Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-11-2007 10:18 AM
need bov vacuum hose...oem only? shu_chen4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-12-2006 09:04 AM
BOV Vacuum Elbow foolio Normally Aspirated with bolt-on Forced Induction Powertrain 0 03-31-2004 06:51 PM
bov vacuum line? scubaracer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-26-2002 03:38 PM
