Old 09-20-2010, 07:02 PM   #1
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Default Can I use a bore gauge on acl coated bearings to measure clearance?
Just want to tripple check. Want to use a bore gauge rather than plasti guage since the bore is more accurate. But will have metal on metal contact during measuring. (probe on bearing) This will probably damange the coating as it's uber flimsy. Should I just stick to the plasti guage or can I go ahead and use the bore gauge?
Bad Noodle is offline   Reply With Quote
Old 09-20-2010, 07:08 PM   #2
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
the bore gauge if used carefully will leave minimal scratches in the coated brgs,just take your time and be careful and go slow.
john 1badSTI is offline   Reply With Quote
Old 09-20-2010, 07:38 PM   #3
MartinSTi05
Member#: 145145
2006 wrx STi
It worked for me, however it did leave a visible mark on the coating. But, it was very minimal, to the point where you can't feel it with a fingernail.
MartinSTi05 is offline   Reply With Quote
Can i use the rear wiper fuse as a source to tap +12 Switched for my gauges? 03WRXMA Electrical & Lighting 8 01-14-2010 12:03 PM
Program so i can have speedmeter or rpm gauge on lcd screen? wrichiex_sti Car Audio, Video & Security 11 04-06-2004 03:15 PM
Can you use normal crush washers on Fumotovalve? garface Service & Maintenance 12 11-14-2003 03:29 PM
Can I use 2.5L clutch on 2.2L tranny??? Aspen Normally Aspirated Powertrain 2 12-12-2000 11:04 PM
