Old 09-20-2010, 06:56 PM   #1
newsuby2211
Member#: 205818
Exclamation 2.2L cam gears and 2.5L cam gears
So here's the deal, my buddy has an '01 2.5rs and he ran it off the road blah blah blah.. I dont think he's tellin me everything but anyways, the timing jumped and the RH cam gear shattered. Supposedly a guy "scoped" it and said the valves were still good.. Not too sure how he can justify that. So I put a new timing kit on it, along with a cam gear from a '99 2.2L engine. Are the cam gears from the '99 2.2L motor the same as the one from the '01 2.5L motor? Both SOHC motors. I put it all together and the RH side of the motor has about 25psi compression. LH side of the motor has about 190psi. I was thinking either the motor is junk and just needs to be replaced or the cam gear is wrong. Can anyone help me out?
newsuby2211 is offline   Reply With Quote
Old 09-20-2010, 07:07 PM   #2
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
they are the same. its pretty hard to shatter a cam pulley without bending valves. he would have had to turn the engine off before he hit anything...
Zefy is offline   Reply With Quote
Old 09-20-2010, 10:41 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
That's not the cam gear. That's bent valves.
Old 09-20-2010, 11:43 PM   #4
newsuby2211
Member#: 205818
thanks alot guys, thats what I was thinking but just wanted another opinion.. cuz now he wants to put a 2.2L in it instead of finding a 2.5L and spending the extra money. Any advice on that motor swap?
Old 09-22-2010, 12:06 PM   #5
Jawney
Member#: 106363
Tell him hes dumb. And his head is sooo full of water...
Jawney is offline   Reply With Quote
Old 09-22-2010, 12:11 PM   #6
Jawney
Member#: 106363
Old 09-22-2010, 02:59 PM   #7
MrSnatch
Member#: 184686
2007 Forester XT
I can send you the link for a catch pan for all that water.
MrSnatch is offline   Reply With Quote
Old 09-22-2010, 09:09 PM   #8
newsuby2211
Member#: 205818
that catch pan better be more like a 55gal drum
WTB: 90-01 2.2L or 97-07 2.5L NA Flywheel ej20forester Private 'Wanted' Classifieds 1 10-27-2009 11:05 AM
95 2.2L Legacy to 98 2.5L DOHC EastsideLegacy Subaru Conversions 32 01-29-2009 06:57 PM
2.2l closed deck vs 2.5l STI semi-closed deck 2.5rsDOHC Normally Aspirated with bolt-on Forced Induction Powertrain 27 09-01-2004 03:55 PM
2.2l legacy engine and 2.5l RS engine jetfan8178 Service & Maintenance 10 04-02-2002 05:47 AM
2.2l turbo block and 2.5l heads Jessie James Normally Aspirated Powertrain 12 01-23-2001 08:34 PM
