Old 09-20-2010, 09:38 PM   #1
barryj
Member#: 146723
2005 WRX
Default Turtle Wax Lens Restorer?
Any comments on "Turtle Wax Headlight Lens Restorer Kit"? It seems to be complete with 3 sanding grades and and 3 solutions..........
Had read many threads that "Crystal View"(?) was the kit to get, but I can't seem to find it in this area of Northern NH.....
barryj is offline   Reply With Quote
Old 09-29-2010, 10:09 AM   #2
98outbacksprt
Member#: 130263
2004 Fxt
i used the turtle wax kit and it actually made them worse.. followed the directions very closely and still very poor results...
98outbacksprt is offline   Reply With Quote
Old 11-17-2010, 05:44 PM   #3
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I will be trying this kit today. Will take some photos.... this thread makes me worried.
Old 11-18-2010, 04:36 PM   #4
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I used the kit - after applying the sealant they looked amazingly nice. I left them to cure for 24 hours...
Problem is durability of the sealant. Without the sealant, scratches are visible.
Old 11-18-2010, 04:44 PM   #5
gray_scoob_punk
Member#: 144318
2005 Impreza RSC
CGM
i used this kit before. It lasted maybe a few weeks and then looked worse.
gray_scoob_punk is offline   Reply With Quote
Old 11-18-2010, 05:35 PM   #6
BoDiddley
Member#: 249683
2005 boobie saver
harlequin
used the kit made the headlights better..i wax the headlights once a month and they look fine
still doesnt stop rocks from making dents in the head lights
BoDiddley is offline   Reply With Quote
Old 11-18-2010, 06:29 PM   #7
2002wrxspoolin
Member#: 252473
2002 Wrx
I've heard that a gojo hand cleaner works great. Just a suggestion and its cheaper.
2002wrxspoolin is offline   Reply With Quote
Old 11-18-2010, 06:36 PM   #8
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
how long did you cure them?
Old 11-18-2010, 08:17 PM   #9
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Looks good, but no idea how long it will last.... I left them to cure for more than 24 hours...
Before and after photos.
Old 11-18-2010, 08:41 PM   #10
Feartheroo
Member#: 240108
2008 WRX Sti
Rally Blue
I was actually pleasantly surprised, I used them on my daughter's car, followed directions and let them cure for a full 24 hours, and well over two months later, they look just as good as the day I did them.
B
Feartheroo is offline   Reply With Quote
Old 11-19-2010, 03:33 AM   #11
Jaren1
Member#: 195061
1997 \_(ツ)
Green
THere is already a thread on this
http://forums.nasioc.com/forums/show....php?t=2011221
Anyways. I work at a shop that charges to do this service. I am the one that does it on all the cars. Its really simple and you dont need a kit.
We us sand paper and a rotary buffer and some polishing compound.
BEFORE:
First step is to take 400 grit (for really bad lights) sand area evenly like so:
Then I stepped up to 600 Grit:
Then from there I stepped up to 1500 then to 2000. Finished by Polishing with a yellow pad at some compound at about 1500rpms. Then I took i light pad and some polish and ended up with this:
Final
Jaren1 is offline   Reply With Quote
Old 11-19-2010, 05:30 AM   #12
nairbmik
Member#: 220259
09 2.5i
SSM
Don't forget to spray it with rattle can clear coat! Or else it'll keep coming back.
nairbmik is offline   Reply With Quote
Old 11-19-2010, 10:35 AM   #13
jxkim
Member#: 239150
2003 WRX Sedan
plenty of threads on these products and diy headlight restoring...
most of the time sanding is not necessary... and most dont realize it does more harm than good. sure it looks good but the protective uv clear coat and layers are being sanded off. eventually it will haze within months and turn yellow
use rubbing compound ($3 for a whole can) and then you are done! thank me later
for bonus use plastx after, and keep it waxed like your paint
jxkim is offline   Reply With Quote
Old 11-19-2010, 12:39 PM   #14
Jaren1
Member#: 195061
1997 \_(ツ)
Green
You couldnt be more wrong. 90% of the time Sanding is needed. Sorry no matter how hard you try, rubbing compound isnt going to remove the layer of faded and yellowed plastic. I have enough experience doing this.
Sanding really doesnt do any more harm then what has already been done by the sun. Obviously the UV clear coat didnt do its job if you need to refinish your lenses, so why would sanding be any worse? Its not
Old 11-19-2010, 01:56 PM   #15
jxkim
Member#: 239150
2003 WRX Sedan
its a tip i picked up from lightwerkz and i am 3 for 3 with it. worked amazingly well. who told you sanding was needed? 3m? haha
i would only say sand if there are nicks and uneven surface, but just for fading its pretty unnecessary as i figured out. why skip such an easy step, you are not risking anything. in detailing always start with less severe methods and move up.
Old 11-19-2010, 09:48 PM   #16
Jaren1
Member#: 195061
1997 \_(ツ)
Green
Im willing to bet i have multiple times more experience doing this then you. We do it for customer cars. Cant do a half ass job if you have a company reputation riding on it.
Not a SINGLE customer has ever complained.
And given my experience I have done and tested what you are saying multiple times. Doesnt even come close to the results obtained with sanding.
You do it on your car. I do it on paying customers cars. Paying customers are surely more picky then friends or yourself.
Old 11-20-2010, 02:22 PM   #17
TPF23
Member#: 262764
2007 Impreza
looks brand new
TPF23 is offline   Reply With Quote
Old 11-20-2010, 02:48 PM   #18
markgsa
Member#: 255271
2006 STI
AW
I used wizards turbo cut and it worked awesome.
markgsa is offline   Reply With Quote
Old 11-20-2010, 03:37 PM   #19
FL4TFTW
Member#: 256953
2014 WRX Hatch
Okay I'll make this simple. You're wrong.
You're 100% correct.
FL4TFTW is offline   Reply With Quote
Old 11-25-2010, 07:18 PM   #20
prokaw875
Member#: 143318
GG Outback Sport
Version 8 EJ207
I used the turtle wax lens restorer and I am kinda torn by it. The rubbing compound didn't do crap. The 4 wet sanding steps worked good but even with using the lens wipe the small scratches and slight fading/blur still shows through. What wax or compound should i do use to make the lenses clear and scratches filled in fully? Just a plastic or normal car wax?
prokaw875 is offline   Reply With Quote
Old 11-26-2010, 03:40 AM   #21
Jaren1
Member#: 195061
1997 \_(ツ)
Green
I use normal car wax. a 2000 grit wax would do good after sanding
Old 11-26-2010, 05:00 AM   #22
FL4TFTW
Member#: 256953
2014 WRX Hatch
Okay you're confusing wax with polish(or compound). Buy some plastx and a yellow applicator pad if you want to do this by hand. Otherwise a random orbital buffer will do a great job and is easy to use. You can get a good one for around $60-100 used or $130ish new. I'm talking about the g110v2, pcxp, or griot's.
You can wax the headlight after you clean off all polish residue (with ipa) to add some uv protection.
Old 11-26-2010, 12:40 PM   #23
Jaren1
Member#: 195061
1997 \_(ツ)
Green
I do believe his question was "what wax or compound should I use"
Wax isnt going to remove scratches, compound will. Thats why I suggested it.
Old 11-26-2010, 12:50 PM   #24
polarisboy385
Member#: 222041
2009 Impreza 2.5i
PRP
i believe this is one of those times that there is more than one way to do something, toachieve the same (or nearly the same ) results
this is a good informative thred though and i will do it on my sisters car.... my dads about to buy new headlights and im tellin him to save money cause ill be able to do it
polarisboy385 is offline   Reply With Quote
Old 11-26-2010, 12:52 PM   #25
CSibbs
Member#: 262532
'12 STI
CSibbs is offline   Reply With Quote
head light restore-turtle wax- My rating Subey03 Car Care & Detailing 29 12-26-2011 10:35 AM
Turtle Wax Headlight restorer 98outbacksprt Car Care & Detailing 8 04-14-2010 02:24 AM
FS: Meguiars Cleaner Wax, Quick Wax, and Turtle Wax 2001 $2 front MWSOC Private Classifieds 1 02-22-2009 11:37 AM
PR: Turtle Wax to sponsor Subie Gal Racing Subie Gal Motorsports 36 01-28-2002 01:03 PM
Any comment on Turtle Wax Clear Coat? au112 Interior & Exterior Modification 0 01-13-2002 04:42 AM
