Vancouver Impreza Club
Go Back   NASIOC > NASIOC Chapters > Vancouver Impreza Club Forum -- VIC > VIC Vendor Classifieds
Closed Thread
Old 09-20-2010, 10:30 PM   #1
dalesalignment&brake
Vendor Sales Rating: (47)
Member#: 173316
'13 BRZ
Default '08+STI RCE Yellows are in stock!!!!!!
RCE Yellows('08+STI) are here!!!!
Following the release of our popular "Regular Guy" springs, RaceComp has produced a more aggressive lowering spring for the 08+ STI. These new springs lower the car approximiately 15mm and include new replacement bumpstops to maintain as much travel as possible on the lowering sensistive GR Impreza chassis. Spring rates are an aggressive 340 lbs/in front and rear.
Teaser pic courtesy of Myles at Racecomp Engineering
Following the release of our popular "Regular Guy" springs, Racecomp Engineering has produced a more aggressive lowering spring for the 08+ STI. These new springs lower the car approximately 15mm and include new replacement bumpstops to maintain as much travel as possible on the lowering sensitive GR Impreza chassis.
Spring rates are an aggressive 330 lbs/in front and 335 lbs/in rear. With a stance to match the performance, these springs utilize the knowledge RaceComp has gained from years of GR chassis set-up experience to maximize handling, retain ride comfort, and improve the look of your Impreza.
Racecomp Engineering’s goal was to help cure the crippling understeer that adds to lap times at the track and autocross course. Studying the design of the new GR suspension, a more aggressive performance spring has been produced that retains available bump travel, matches the OEM dampers, and works in conjunction with the new rear motion ratio. The result is a car that handles extremely well from corner entry to corner exit.
$389/set
And add a set of these for optimum control:
Racecomp Engineering GR Sway Bars
These front and rear 25mm hollow 2 position adjustable swaybars are a must have for your 2008 and later Impreza STI. Featuring carefully chosen swaybar rates and a tubular design, these swaybars weigh less than other solid bars with a similar stiffness.
Racecomp Engineering GR Sway bars for the 08+ STI. Rear bar will fit the 2008+ Impreza / Impreza WRX.
$470set(when purchased with Yellows)
or these
Whiteline swaybars
$410set
We also have:
RCE Tarmac Zero-'02-07 WRX and STI-in stock
RCE Tarmac 2 '05+STI and '08+STI-in stock
RCE GD('02-06 STI)-in stock
RCE Yellows and Regular Guy springs for '02-07 WRX/STI-in stock('02-03 WRX/Impreza need '04+ rear tophats)
RCE CF Kool Brake Kit-in stock
GTWorx camberplates-in stock
[email protected]
__________________
[CENTER][CENTER][SIGPIC][/SIGPIC][/CENTER][B][I][COLOR="Red"]"We do pricing a little differently. Every price you see includes the shipping cost to our office(Surrey, BC), duties and exchange rate . This creates a built in cost savings, no hidden fees, and less hassles. The best part is we still have a price match guarantee!"[/COLOR][/I] [/B]
[COLOR=black]Service Center: 604 530 9160 [/COLOR] [COLOR=black]Email- [/COLOR]
[/CENTER]
dalesalignment&brake is offline
Old 09-21-2010, 07:35 AM   #2
HRCboy
Member Sales Rating: (4)
Member#: 167075
08 STI & 999R
Give me a call... gotta schedule Wayne in. He wants to do the steering rack bushings at the same time.
HRCboy is offline
Old 09-22-2010, 07:19 PM   #3
Member#: 173316
'13 BRZ
__________________
[/CENTER]
Old 09-26-2010, 04:50 PM   #4
j y
Member Sales Rating: (7)
Member#: 8829
GRB STI
Thanks Jason
-Jeff
Post-install pics I took before it started raining...
j y is offline
Old 09-28-2010, 05:03 PM   #5
j y
Member#: 8829
GRB STI
Sorry, have to bump this again. These things are awesome.
j y is offline
Old 10-01-2010, 03:00 PM   #6
Petrie
Member Sales Rating: (8)
Member#: 1260
09 STi, DGM
04 WRX Stage 2, red
Springs went in last week and the alignment got done today now that they have settled.
Front: zero toe, -1.5 camber, 6.7 caster
Rear: zero toe
Now I can start to really test the improvements. Prior to the alignment I noticed reduced pitch movement under acceleration and braking (nose lift/dive). That makes the passengers a little happier. The ride over bumps and potholes is just as good as stock. The ride quality is not reduced at all. No extra noises.
Body roll has improved (reduced) but not by much. Remember though that I have a lot of bushing and sway bar upgrades with an ALK already. Personally, I like my car to be even a little flatter in the corners. I would have selected a slightly stiffer spring but not by much.
Until now I have not tried to push the car too hard as it needed the alignment. I was just careful to allow the springs to settle first. However, certain long sweeping corners that I am used to are noticeably easier and the limit has been extended.
Drop is fine for a daily driver. It is noticeable that the car has a more aggressive stance but speed bumps are not a problem (even with a front lip and skirt).
$400 for springs or $2500 for coilovers, no brainer - springs.
If I was tracking the car I may consider it worth having adjustable struts but without that requirement these are all you need.
Petrie is offline
Closed Thread
RCE functional springs in stock for '08+STI dalesalignment&brake Canada Region Vendor Classifieds 2 08-20-2009 03:49 PM
RCE swaybars are in stock. RCE coilovers, springs etc. are also in stock dalesalignment&brake VIC Vendor Classifieds 0 01-20-2009 02:07 PM
MY '08 STI KW Clubsport coilovers and RCE Tarmac II in stock dalesalignment&brake Canada Region Vendor Classifieds 0 07-15-2008 11:42 AM
MY '08 STI KW Clubsport Coilovers and RCE Tarmac II in stock dalesalignment&brake VIC Vendor Classifieds 0 07-15-2008 11:26 AM
