Old 09-21-2010, 02:39 PM   #1
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
Default AEM UEGO reads --- all the time. ¿HELP?
i bought a aem uego brand new from a user and i installed it, it worked perfectly fine for the first month then within a weeks time it would slowly go to the lean side then ---, then i would tap on the throttle to maybe 2k, and it would read #s, then go back to ---..
*opening ceremony going as it should.
now no matter what, i only see --- while IDLE/CRUISING/WOT/engine off key on.
i only had this thing not even 2 months. i DO NOT run race gas or e85, i use 92 oct.
car: EJ20G
sti 550cc injectors
td05 16g
18psi
hsk Dp
sti CB
nothing really out of the normal for a subaru..
ill post pics or video later.
pic of DP i have
http://www.jscspeed.com/part_picture...rxdownpipe.jpg
i put the sensor on that one and only bung so its not too close to the hot side.
help?
thanks
MEAD
azn0boi04 is offline   Reply With Quote
Old 09-21-2010, 02:56 PM   #2
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
how is the car running? sounds like a hose clamp came loose and you have a vacume leak... Any chanve in vacume on your boost gauge or during data logs?
rexworx is offline   Reply With Quote
Old 09-21-2010, 03:55 PM   #3
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
well i have a good vacuum. its like 22 in/HG. car is running just as good as before...
Old 09-22-2010, 02:27 AM   #4
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
Poo sound like I have to get a new sensor... I have been searching forever on what it could mean... Even on Honda, dsm, evo, Toyota, forums I couldn't find what --- meant...
O well
Thanks..
IF ANYONE STILL HAS ANY CLUE OR ANYTHING AT ALL LET ME KNOW
Old 09-22-2010, 06:01 AM   #5
mar1asynger
Member#: 45808
2003 WRX Wagon
JDM Sedan'd Sonic Yellow
O well
Thanks..
have you emailed AEM? they'd probly be the ones to ask
mar1asynger is offline   Reply With Quote
Old 09-22-2010, 12:31 PM   #6
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
Yeah I was thinking about that, but they will probably ask for date of purchase and I bought it locally from someone and charge me 120 for the sensor alone.
But I'll give it a shot..
All the gear, all the time... RaceCarRiot Off-Topic 24 11-16-2009 03:12 PM
Help! Lifting inside rear wheel ALL THE TIME... InsatiableAmos Brakes, Steering & Suspension 47 07-29-2009 02:48 AM
idle real low and stalling all the time. HELP!! Brother EddieJ. Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-12-2009 02:31 PM
05 WRX exhaust smells like burning corn all the time...Help! jornander Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 01-15-2009 10:00 AM
60% of the time, it works all the time poon warrior Off-Topic 6 11-21-2006 09:16 PM
