Old 09-21-2010, 06:11 PM   #1
unleashed132
Member#: 255563
2003 Impreza WRX
Rally Blue
Default Help.. hanging wires?
Anyone know what these go to? ignore the other circle..
unleashed132 is offline   Reply With Quote
Old 09-21-2010, 07:01 PM   #2
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
EGT harness? do you have an aftermarket up-pipe? or no EGT anymore??
I'm not 100% on that FYI
ProdriveDreams is offline   Reply With Quote
Old 09-22-2010, 02:24 AM   #3
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
There are three plugs there. The large one connects to the engine harness, the 4 pin one goes to the front O2 sensor, and the 2 pin one goes to the factory EGT sensor.
One a side note the large section of harness coming out of the firewall behind your turbo is kind of out of place too. It looks like it could get melted on the turbo heat shield. That section of harness needs to turn down at about 6 o'clock, run along the frame rail (under where the cruise control module would have been from the factory), then it should run up in front of the shock tower to where those plugs are mounted.
FourOnTheFloor65 is offline   Reply With Quote
Old 09-22-2010, 02:31 AM   #4
todeswalzer
Member#: 191495
'05 WRB GTX3071R
JDM V8 EJ207 USDM 6MT
boost control solenoid is the one at the bottom of the circle with the white clip in it
edit: it belongs behind that black bracket attached to the strut tower, which in turn is missing the rubber grommet and bolt to hold it in place
todeswalzer is offline   Reply With Quote
Help Hanging a Door in Sammamish JasonLHall North West Impreza Club Forum -- NWIC 13 12-16-2007 09:18 PM
Question about some hanging wires. BloodWRX Newbies & FAQs 3 07-13-2004 05:32 PM
Need help! hanging wire harness! skiteton Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 03-26-2004 05:36 PM
lowering spring questions.. and does anyone wanna help\hang out\drink\bbq? LargeOrangeFont Southern California Impreza Club Forum -- SCIC 33 02-12-2003 11:49 PM
WED. April 18th, install in Chesterfield, wanna help, hang out and BS? STiShawn Mid West Subaru Owners Club Forum -- MWSOC 21 04-19-2001 12:01 AM
