Old 06-04-2001, 02:11 PM   #1
Jessie James
Member#: 2072
Post Turbo kit and CE light issues - what causes it and how to prevent it?
Okay,
In reasearching the CARB legal turbo kit, I disconvered that the CE light cannot come on in order to pass the inspection. So...
For those of you with turbo kits, help me out:
1. What causes it?
2. How can I prevent it and still have the CE light work otherwise
3. Any other related info on the turbo kit and the CE light...
Thanks!
-James
Jessie James is offline   Reply With Quote
Old 06-04-2001, 02:17 PM   #2
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Post
The only CE light I've gotten so far was from over-rich mixture. Tweaking the point where the RRFPR kicks in eliminated it.
Search on Larry Ganz's posts. He's detailed a bunch of them.
Jon Bogert is offline   Reply With Quote
Old 06-05-2001, 04:15 AM   #3
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Post
When I originally had the Minnam stage 2 kit installed, I ended up having 3 codes:
  • insufficient cat performance
  • insufficient EGR flow
  • MAP overpressure
The insufficient cat performance was due to the fact that Minnam shipped their kit with a "cat" that was really only a pre-cat. The insufficient EGR flow was because the intercooler interfered with the EGR valve placement on the MY98. The MAP overpressure was caused by the MAP sensor not liking positive pressure in the intake manifold.
All three have since been resolved for me. I now run a high flow cat (which allowed me to pass inspection this past January). The EGR has been reinstalled after RalliSpec modified my intercooler slightly. The MAP code is gone after installing a simple check valve so that the MAP sensor doesn't see boost.
Steve http://www.forcefed4.com/
SteveS is offline   Reply With Quote
Old 06-05-2001, 04:23 AM   #4
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
Post
Just cut the Check Engine light power cords!
jay25RS is offline   Reply With Quote
Old 06-05-2001, 09:12 AM   #5
Jessie James
Member#: 2072
Post
Cool - it looks like all the issues are easily resolved.
Cutting the wire won't work - CARB takes your car and inspects it up and down, inside and out, before they run the tests. It's hard core....
Downshifting Clunk - What is it and how to stop it? hieu1004 Newbies & FAQs 17 04-07-2010 12:50 PM
clear bra.. what not to do! and how to clean it.. 801_STi Car Care & Detailing 11 05-30-2009 04:03 PM
Wheel Repair, what can be repaired, where to get it done, and how safe is it? Corn-Picker Tire & Wheel 3 06-23-2004 04:44 PM
UTEC: Knock when shifting. Whats causing this and how to fix it? STR8OUT Engine Management & Tuning 14 07-03-2003 11:35 AM
