#1 |
Member#: 78506
TXIC
Vehicle:'04 WRX PSM |
A few days ago I noticed one of my license plate lights was slightly flickering so today I removed the led bulb and reinserted it to see if this would fix the problem. However, now both of my license plate lights and my taillights no longer function when I have my lights on. Everything else still works ok, my blinkers, brake lights, and headlights are all still fine. I'm guessing there must be a blown fuse somewhere? Can somebody help me with this?
#2 |
Member#: 226005
Vehicle:2006 WRX WHITE |
Ya I would suggest looking at all the fuses first
#3 |
Member#: 78506
TXIC
I plan on checking my fuses tomorrow in the am. I do not have my manual with me though, does anyone know which fuse and where it is located?
#4 |
Member#: 53443
Vehicle:2001 LL Bean Outback Winestone |
Fuse 16 in the dash panel is one of the fuses. The tail light illumination relay is in that panel also. Check to see if the rear lights will work with the switch on top of the steering column.
#5 |
Member#: 78506
TXIC
Well I went out this morning to look at my fuse panel behind the ashtray and I found the problem. The fuse for the taillights/parking lights was out. Swapped it out for a new one and everything works perfect.
I'm hitting up autozone later today for some new license plate bulbs, screw the pos yourledshop.com lights.... Thanks for the help guys, much appreciated! |
#6 |
Member#: 53443
You're welcome for the help. Glad you solved the trouble.
| Thread Tools | |
| Display Modes | |
| Subaru baja tailgate license plate light burned out... | Soukyoku | Electrical & Lighting | 4 | 01-05-2013 03:38 PM |
| Can't figure out how to access license plate lights 07 Legacy(/Outback?) SEDAN | awns729 | Electrical & Lighting | 1 | 06-16-2009 09:32 PM |
| License plate lights and trunk light out | TBone7281 | Electrical & Lighting | 6 | 05-17-2009 01:35 AM |
| ticket for license plate light out in MA | legav05 | New England Impreza Club Forum -- NESIC | 36 | 05-02-2009 11:52 AM |
| license plate lighting and auto dimming mirror on same circuit? | [27] | Electrical & Lighting | 2 | 06-22-2006 10:48 AM |
