Old 09-22-2010, 03:35 AM   #1
soulsweeper
Member#: 22159
02 WRX
WR BLUE PEARL
Default Headlights MELTED?
Alright.
It's really a long story, but I'm going to make it real short.
My 06 STI headlight had that headlight protector thingy.(Clear invisigard or whatever) I had a reason to put it back to stock and had to peel it off. So I did. I had to clean off the after-mess which was full of sticky gooey things. I used industrial degreaser....and it did jack! After a short internet research...(Big mistake on my part...should have done a VERY VERY thorough research) some said goof off or goo gone works. So I did. AND IT TURNED WHITE!!
I'm thinking plastic melted and junk.
WHAT CAN I DO?
THank you so much in advance.
-max
soulsweeper is offline   Reply With Quote
Old 09-22-2010, 11:02 AM   #2
b00st3d
Member#: 9891
2015 RC-F
Ultra White
you can try one of those headlight restorer kits?
b00st3d is offline   Reply With Quote
Old 09-22-2010, 11:10 AM   #3
RaineMan
Member#: 256727
2007 2.5I Wagon
Yeah... never use harsh chemicals on clear plastics, tough lesson to learn. A headlight restorer kit might work if the frosting is just in the top few layers of plastic. If it goes deeper than that you will probably need to replace the light.
RaineMan is offline   Reply With Quote
Old 09-22-2010, 11:12 AM   #4
blue-sun
Member#: 15934
I don't think plastic melted.
Why did you have to take the headlight protector off. If it was a clear one, why would it matter to anyone? How did you take it off? Just peal it off or did you heat it properly and then remove it.
Without seeing a pic, my guess is that you didn't get all the adhesive off of the headlight and the goof-off/goo-gone residue got stuck in the adhesive and that's what turned white. Here's what I would suggest if it is indeed adhesive:
Get some plastic razor blades and a heat gun.
Amazon.com: 6-piece Plastic Razor Blades: Health & Personal CareAmazon.com: 6-piece Plastic Razor Blades: Health & Personal Care
Heat up the headlights really good, and using the plastic razor blade scrape the adhesive off (if it is indeed adhesive).
This will be messy and time consuming, be patient.
Once all (or most) of the adhesive is off, spray it down again with the goo-gone/goof off and let that sit for a good 5-10 mins to penetrate and loosen up the adhesive and go to town with the plastic razorblades again.
Once all the adhesive is off, use a headlight restore kit to get any scuffs out and you should be good to go.
blue-sun is offline   Reply With Quote
Old 09-22-2010, 11:20 AM   #5
Smdavis27
Member#: 219455
2009 WRX Sedan
Satin White Pearl
Wetsand that b***h down with some 1000 grit sandpaper until that garbage is off, proceed to a 2000 grit, and then polish with a porter cable and compound/polish/glaze of your choice.
easy.
Smdavis27 is offline   Reply With Quote
Old 09-22-2010, 05:04 PM   #6
12sechatch
Member#: 132458
Okie Dokie Fine
You're going to have to wetsand it. If that doesn't work (I doubt it will, you're probably effed), you'll just need to buy a new lens.
12sechatch is offline   Reply With Quote
Old 09-23-2010, 01:14 AM   #7
ilikesubaru:)
Member#: 207275
2000 RSTI/07 STI
WRB/SWP
Get a 600 grid or something in that area sand paper, sand the headlights off, wipe them off (do not polish or do anything else except use a bit of acetone to get rid off oil particles on the headlight, well who ever will spray them should to that) go to the local auto body shop or who ever know how to paint and spray 2 layers of clear coat on them they will look better than new please don't use spray can.
ilikesubaru:) is offline   Reply With Quote
Old 09-24-2010, 02:35 AM   #8
soulsweeper
Member#: 22159
02 WRX
WR BLUE PEARL
I'm going to try the sanding method first. I hope I don't have to replace the headlights. Maybe find non sti headlight and change the clear plastic part only or something.
Argh. Thanks everyone
Max
Old 09-24-2010, 03:54 AM   #9
STi Rob
Member#: 237567
2007 SWP STi
Molested by Drunkmann
The best thing I could tell you is try some headlight restorer and see what happens.
This is the stuff I used to restore some headlights and it came out really nice! Its a bit pricey but really worth it. Also Walmart I believe sells it for around $17.
http://shop.advanceautoparts.com/web...ci_sku=7110142
STi Rob is offline   Reply With Quote
Old 09-28-2010, 01:37 PM   #10
P.Rico
Member#: 239452
2010 Impreza WRX
1991 Prelude Si 4WS
How many people are going to make the mistake of equating Goof Off with Goo Gone?
They are not the same!
Goof Off is an organic solvent (mix of acetone and xylene). It even says on the label "Damages many plastics..." http://www.goofoffstainremover.com/s..._w_asphalt.pdf
It is basically a small can of PAINT THINNER.
Goo Gone is a petroleum distillate (Naptha) mixed with citrus oil (a great natural degreaser). It is perfectly safe for plastics and paint and works great for adhesives, bugs and getting rid of old wax on automotive paint.
A headlight restore kit is going to do nothing to that headlight, it has been etched beyond physical repair. Sorry, guy. You can buy just the headlight assembly without the harness, bulbs or ballasts at Subarugenuineparts.com
P.Rico is offline   Reply With Quote
06/07 WRX headlight swap for OEM 06/07 STI HID headlights! Plug n play? Melted wires? subierider Electrical & Lighting 31 05-12-2010 01:34 PM
Headlights Melted emsmap Electrical & Lighting 13 11-09-2007 05:13 PM
melted headlight harness? rrubel Legacy Forum 12 09-21-2001 10:56 AM
melting headlight..HELP!! VOLTIS5 Legacy Forum 8 05-03-2001 06:34 AM
('93-'01) How many watts can are headlight take before they melt. 2.5rsMI Impreza Forum 6 04-17-2001 06:48 AM
