Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 09-22-2010, 12:42 PM   #1
zakSti
Member#: 118551
2007 SOLD
White Satin Pearl
Default Please help!!! Crawford Catchcan! help.
Ok..whos running them? Ive got an idea...but want a better one..what hoses go to where? Tough to see in the pic, but i'm running a garbage Catchcan Not a Crawford. If someone has a any detailed pics, an easy graph..anything that will help me get this setup id greatly appreciate it.
This is my Setup now without the Crawford.
zakSti is offline   Reply With Quote
Old 09-22-2010, 02:38 PM   #2
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I can't see you picture but if its a conventional catch can it won't be plumbed up anything like the Crawford air/oil separator. Crawford's site has instructions for there part. So what was your question???
Old 09-22-2010, 03:54 PM   #3
zakSti
Member#: 118551
2007 SOLD
White Satin Pearl
That vid, isnt that helpful..its shows a full stock car with a topmount.
Old 09-22-2010, 07:42 PM   #4
zakSti
Member#: 118551
2007 SOLD
White Satin Pearl
ok..heres a pic of it installed...now can someone tell me where these 3 open lines go? i know the top is a breather, so scratch that one...Crawford stated with High HP cars..just attach a small hose and a breather at the end or leave it open. Now what about the 2 side ones on opposite sides?
Also i bought this used off my friend..i noticed where the top line is, i took the hose off, there was dried up gook..it was brownish. If there is more of it in the can i dont want it recirculating back into my motor. Your thoughts guys, anyone else found that issue?
Old 09-23-2010, 12:03 AM   #5
mikescar
Member#: 214832
http://www.iwsti.com/forums/2-5-lite...ns-thread.html
Look at that. That show's you exactly where to run the lines.
mikescar is offline   Reply With Quote
Old 09-23-2010, 10:43 AM   #6
Crawford Performance
Member#: 42075
The front line is almost sitting where you want to connect it, it goes to the coolant reservoir.
When you take the existing line off the reservoir, remove it from the turbo as well. Now you can take the rear line and attach it to the turbo.
Team Crawford
Crawford Performance is offline   Reply With Quote
Old 09-26-2010, 01:57 PM   #7
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Team Crawford
Just call Crawford and get the instructions, its pretty easy to follow.
dexterous is online now   Reply With Quote
Timimg belt/water pump help FreshNSoft Normally Aspirated Powertrain 17 09-27-2010 06:01 PM
HELP.After turbo inlet instal not hitting full boost. neo277 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 09-23-2010 09:09 AM
Oil / Air Separator,catch can,catchcan DIY , crawford alternative kike_ej20 Pre-2002 Factory Turbo Powertrain 1 04-28-2008 12:32 PM
Catchcan / Breather Lines HELP! 04RCSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 02-21-2008 11:05 PM
need help with catchcan dlowman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 35 02-08-2006 10:34 AM
