Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 09-22-2010, 05:31 PM   #1
my99210kw
Member#: 180429
99 WRX
Dark green
Default New JE FSR pistons oil rings visible???
Hi everyone,
I am assembling a new engine after having my liners drop in my 1st engine and I have noticet that at BDC when fitting the gudgon pin that the oil control rings can be seen through the access hole in the block. I would not expect this to be normal and hoped thad someone else that has built one of these engines might be able to help.
Cheers,
Tony
my99210kw is offline   Reply With Quote
Old 09-22-2010, 05:35 PM   #2
MartinSTi05
Member#: 145145
2006 wrx STi
My stroker was the same way. Chamfer the access holes so they don't grab a ring!
MartinSTi05 is offline   Reply With Quote
Old 09-22-2010, 05:42 PM   #3
my99210kw
Member#: 180429
99 WRX
Dark green
Thanks for super fast reply,lost some sleep last night over this. The ring doesn't grab as it goes over the hole it just looks weird. The top of the piston is close to flush with the deck at TDC which is good as I thought that the pistons may have been for a long rod.
Any one else seen this?
Old 09-22-2010, 06:16 PM   #4
Maxwell Power
Member#: 190729
happens all the time
Maxwell Power is offline   Reply With Quote
Old 09-22-2010, 10:31 PM   #5
my99210kw
Member#: 180429
99 WRX
Dark green
Good to hear, thanks for the info. Be glad to get her up and running again, only had 3 days with 320kw prior to failure,
Brand New Je Forged Pistons For Ej20 02-05 Wrx Cstmboxermotorsports Engine/Power/Exhaust 3 09-14-2009 05:19 PM
New Je Coated Pistons, Perrin Inlet, Sti Tgv's And More cbrdragbike Engine/Power/Exhaust 14 12-14-2008 07:31 PM
FS: New 04 STi Pistons w/rings Autopilot747 Engine/Power/Exhaust 19 11-05-2006 07:59 AM
sti piston oil ring assembly?? Pi7467mp Built Motor Discussion 8 04-28-2006 04:19 PM
EJ20 JE Forged pistons w/rings Yeah baby Private 'For Sale' Classifieds 4 01-28-2005 02:27 PM
