Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 09-22-2010, 07:28 PM   #1
EsubaruJ
Member#: 200008
03 wrx
TE72 wagon, Legacy wagon
Default Compression testing
Is there a way to accurately test the compression of an engine that is out of the car? I have read a few threads regarding this subject but haven't really been able to find a clear answer, some say yes, some say no. I would assume you can put the tester in the cylinder then crank the engine by hand using the bolt on the crank pulley, but are you going to be able to generate enough rpm's by hand cranking the engine to get an accurate reading? And if someone can tell me the size of the crank pulley bolt on a subaru engine(EJ20K) that would be great, iirc, its a 22mm but I could be wrong.
thanks
Chris
EsubaruJ is offline   Reply With Quote
Old 09-22-2010, 08:15 PM   #2
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
Yes you can hand crank the engine.
car_cursed is offline   Reply With Quote
Old 09-22-2010, 08:35 PM   #3
Bones702
Member#: 205115
06 Sti Dom4.0XTR
Just pull all of the spark plugs. That will help turn it over a little faster.
Bones702 is offline   Reply With Quote
Old 09-22-2010, 09:06 PM   #4
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
Do a leak down test. Not a compression test. Its better than a compression test and will tell you where the leaks are coming from. (no im not talking about a boost leak test)
bhhamblin is offline   Reply With Quote
Old 09-22-2010, 09:13 PM   #5
EsubaruJ
Member#: 200008
03 wrx
I will try both, I'm sure I can find a link on how to perform a leakdown test. Thanks everyone! Does anyone have a leakdown tester? I assume its a different unit than a compression tester.
Old 09-22-2010, 09:30 PM   #6
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
Checker or Autozone
Old 09-22-2010, 10:28 PM   #7
EsubaruJ
Member#: 200008
03 wrx
Most of the tutorials I read say to do both of these tests while the engine is warm. I obviously wont be able to get it warm, as its not wired up yet. How bad will that effect the outcome of the results?
Old 09-22-2010, 10:37 PM   #8
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
Ive tested both warm and cold. its like 2-10%. Nothing enough to worry about.
Old 09-22-2010, 10:48 PM   #9
EsubaruJ
Member#: 200008
03 wrx
Cool, thanks!
Old 09-23-2010, 03:40 AM   #10
EsubaruJ
Member#: 200008
03 wrx
Well, I wasn't able to even compression test the engine, but after looking at the car, it needs a lot. It will need everything besides the transmission to complete the 5 spd swap thats in it. I was really excited about this car, but unfortunately I just wont be able to finish the project without more funds. I am pretty bummed, but I just don't want to take on another project I can't finish. We all know how well my last project went over.. Hopefully something happens and I can still get it. But my hopes aren't high. Well I just needed somewhere to vent lol. This thread can be closed or deleted or whatever. Thanks for everyones input.
Old 09-23-2010, 10:37 AM   #11
Bones702
Member#: 205115
06 Sti Dom4.0XTR
Lets hear some details man.
Compression Test and Boost Pressure Test costs? BrigadoonB Newbies & FAQs 3 08-17-2008 10:20 PM
Recommonded Shop for Compression Test and Leak down test? stook2003 Vancouver Impreza Club Forum -- VIC 0 07-02-2007 04:20 PM
Odd compression test and leakdown test numbers SloRice Built Motor Discussion 10 11-13-2006 10:07 AM
What the compression test and leakdown tests SPEC for 05 STI hilfiger4you Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 12-25-2005 04:43 PM
Compression Test vs. Leak Down Test dug-e-fresh Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 08-17-2002 11:42 AM
