Old 10-08-2010, 02:22 PM   #101
iluvdrt
Member#: 46248
82 Brat
Tan
Originally Posted by DaWhiteScoob View Post
^^^ This!
But isn't your car a 98? I thought you only need the Borla Rep Manifold to connect to the rest of your car.
Originally Posted by royalnewjersey View Post
This prototype isn't for your car
2008+
Whew. Good. Thanks for pointing that out, I must have missed it. I am sure it would fit my car, just not the budget.
I am sure it would go on my 05 OBS as well, but then again, not for the price.
iluvdrt is offline   Reply With Quote
Old 10-08-2010, 02:40 PM   #102
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Your 05 OBS can fit a Borla rep for less than $200.
Old 10-08-2010, 06:45 PM   #103
GrundleJuice
Member#: 165749
Originally Posted by GEE-OTTO View Post
You can say all the **** you want about EL headers until you show me a video of a EJ25 with EL that DOES NOT SOUND LIKE A HONDA you are full of **** WRX or 2.5i
Post #1112, page 45. True EL header. eat it.
http://forums.nasioc.com/forums/show...345720&page=45
Old 10-08-2010, 09:13 PM   #104
iluvdrt
Member#: 46248
82 Brat
Tan
Cool. I thought the header designs were different between the P1 EJ25 and newer models. I was under the impression the older models used a UEL stock header and the new ones used more of an EL design. I'll have to look.
None the less, I'll butt out. This thread doesn't concern my cars (after all), and I don't want to hijack/not contribute any more then I already have.
later guys, GL with the new design.
Old 10-08-2010, 09:23 PM   #105
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Yep, that's about what mine sounds like. Mine's not quite as deep because I still have the stock muffler on it, but it has that same pattern of sound yours does.
Old 10-09-2010, 01:00 AM   #106
royalnewjersey
Member#: 250954
2013 WRX Hatch
Would still rather have the boxer rumble. Even if it "doesn't sound like a honda"
royalnewjersey is offline   Reply With Quote
Old 10-09-2010, 09:32 AM   #107
GrundleJuice
Member#: 165749
And we have come full circle... the whole point of this thread. /\/\/\
Old 10-09-2010, 11:13 AM   #108
blk6s
Member#: 200057
2013 Impreza 2.0i
RalliSported RomRaided
lol. Well said. I do concede, it didn't sound nearly as bad as I was expecting. As someone else stated in a borla vs obx thread, doesn't sound like a "honda" but doesn't sound like a "subaru" either. I think you know what I mean. Personally I would take the extra power over the rumble, but its not about what I want, its about what the community wants.
blk6s is offline   Reply With Quote
Old 10-09-2010, 11:21 PM   #109
royalnewjersey
Member#: 250954
2013 WRX Hatch
^^^ Hey blk6s, Any sound clips or videos of the prototypes? I'm excited
Old 10-10-2010, 08:27 AM   #110
blk6s
Member#: 200057
2013 Impreza 2.0i
One more week...
Old 10-11-2010, 07:55 PM   #111
Matt515
Member#: 241492
2006 Forester, RBP
Tuned by M@ at WI!
i absolutely cannot wait. i purposely bought a 2.5i for a DD. my whole point in working on this car was to make it look good and sound good. im missing the "sound good" part because no UEL headers. if i had to, id pay up to 700 for a UEL for my Forester. i cant not freekin wait to hear sound clips and be reassured that it is fully bolt on and NO CEL's!
thank you for all the info you have given us and i am looking forward to getting more info along the way.
Matt515 is offline   Reply With Quote
Old 10-11-2010, 11:54 PM   #112
djinn
Member#: 212818
2010 Impreza 2.5i
Satin White Pearl
In for 1 if this does not throw CEL and doesnt have any leaks.
djinn is offline   Reply With Quote
Old 10-12-2010, 06:03 PM   #113
GEE-OTTO
Member#: 201277
2009 Legacy GT
IM sure it will throw every code in the ECU and leak to high heaven Thats why vendors develop products
GEE-OTTO is offline   Reply With Quote
Old 10-12-2010, 06:13 PM   #114
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
In all probability, it'll throw a P0420 DTC due to the increased heat loss. With how sensitive the 05+ cars have become, it's nearly inevitable.
Old 10-12-2010, 08:34 PM   #115
AfflxnPB
Member#: 172036
2010 2.5i Prem
SSM
woohoo! I emailed you guys awhile back and i'm glad they finally got to be finished up.
AfflxnPB is offline   Reply With Quote
Old 10-12-2010, 08:39 PM   #116
royalnewjersey
Member#: 250954
2013 WRX Hatch
Would wrapping / coating help this product not to throw a CEL? If so, what products would you suggest that do a good job?
Old 10-12-2010, 09:06 PM   #117
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I had my Borlas coated with JetHot and still got the CEL. The swaintech coating I'm using on my TWE header is far more effective, but I suspect still not good enough. It's possible that wrapping the header might be sufficient, but the wrap will need replaced often.
Old 10-12-2010, 09:53 PM   #118
kero
Member#: 94299
2000 2.5 RS Sedan
SRP
Best solution, do what I did, have a local tuner edit the map in the ECU to remove the P0420 DTC permanently. I have not had an issue since.
kero is offline   Reply With Quote
Old 10-12-2010, 11:16 PM   #119
littlec
Member#: 208934
09 2.5i
Have not had an issue or have not thrown a code. Two different things.
Dei heat wrap and high heat spray before and after wrapping. Ceramic costing may also help keep more of that heat in.
littlec is offline   Reply With Quote
Old 10-13-2010, 12:56 AM   #120
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
Or do it yourself
Ok n00b with pubes question. How hard would it be to unbolt my stock header and bolt this bitch up? Should I expect header bolts snapping etc?
Subyroo2.5 is offline   Reply With Quote
Old 10-13-2010, 01:08 AM   #121
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Use an impact wrench and they'll come right off. You'll need to be wearing chem lab goggles or ski goggles though as a staggering amount of tiny bits of rust and other crap will get into your eyes. Believe me, being strapped into a head-vise while they use a cotton swab to remove rust slivers from your cornea is a BAD night.
The 06+ cars seem to be getting different studs than the older cars and the anti-rust coating on the new studs is crap. Plan on replacing the studs and nuts. The old (better) studs are 800910390 while the new (crap) studs are 800910550. The old nuts are 902370009, the new nuts are 902370010.
Old 10-13-2010, 01:11 AM   #122
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
Hahah umm that post was useless without a video! (thanks for the part numbers though) Impact wrench? I wish I had such a device! I live in a second floor apartment with just a parking space. I would give my left nut for a garage to use such tools in
Old 10-13-2010, 02:50 AM   #123
royalnewjersey
Member#: 250954
2013 WRX Hatch
sounds like you answered your own question
Old 10-13-2010, 12:04 PM   #124
GEE-OTTO
Member#: 201277
2009 Legacy GT
The P0420 is far less likely to occur with the new UEL design. Heat loss would need to be extensive and cat light off temps shouldnt drop much at all after it is achieved, given the cat location relative to the exhaut ports and velocity of the gases. Fast moving gases retain heat better than slow moving ones but they dont transfer that heat to the surrounding environment as well.
The Delta of the cat will be lower due to higher ambient temps caused by the primaries. However I would wrap mine to take out a little insurance against that damn CEL. But honestly I would just pay a tuner to adjust the acceptable emissions values
Old 10-13-2010, 12:11 PM   #125
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
EL vs UEL doesn't figure into it.
Also, the Borla reps, which are UEL, fairly consistently cause the P0420 DTC on the 05s and the few newer cars that have switched to them.
RalliSport Racing HF Cat Kramer3608 Normally Aspirated Powertrain 20 02-16-2015 01:27 PM
Support the Rallisport Racing 2.5i build GEE-OTTO Normally Aspirated Powertrain 18 02-16-2015 01:25 PM
It's finally time for the ice racing! see red Mid West Subaru Owners Club Forum -- MWSOC 19 11-07-2011 11:35 AM
i finally cracked opened the motor i blew at the last race... giveme5bux Texas Impreza Club Forum -- TXIC 11 07-01-2007 01:27 PM
Ultimate-Racing 785CC final map impressions RiftsWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 07-24-2003 04:18 AM
