Old 09-23-2010, 11:54 AM   #1
CorbanDallas
Member#: 232583
2006 Wrx limited
Quack Attack member #1
Default Cam shaft help
Going to be swapping a ej25de into my 99 legacy wagon soon. I was thinking of doing a set(4) of cams. I called Delta Cam and was given a price of $150 per cam for a stage one. I had a couple different questions on this. 1. Is it worth it? 2. Is there another company out there that might be cheaper?
I am not looking to make a huge amount of power or anything, just wanted a little more out of the motor. Any insight and help is appreciated. Thanks in advance
CorbanDallas is offline   Reply With Quote
Old 09-23-2010, 03:27 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
You might want to go a little more aggressive. Note that you have shim over bucket lifters in that motor. Delta usually welds and regrinds the DOHC cams so you don't have to wait for the 16 new shims you'd have to buy if they simply ground down the base circle like the SOHC cams are.
Is it worth it? It all depends, I would say yes.
Jay
Old 09-23-2010, 03:31 PM   #3
renob123
Member#: 41986
'06 STI/'85 Brat
Hmm, that price doesn't ring a bell. You may want to double-check with them on that. All of the Delta people I've met seemed knowledgeable, but Ken and Jon are both on this board, so they should be able to help you. Maybe a core charge or something is messing with the pricing.
1) I felt that for my goals with my car, the Delta torque cams were EASILY worth it. The power comes on almost immediately. I can't tell you if it'll be worth it for you because I don't know what your budget is and what you plan to do with the car.
2) I've never heard of anybody cheaper than Delta. If anyone was cheaper, I'd be highly suspicious of what they were selling.
I hope that helps.
Jacob
renob123 is offline   Reply With Quote
Old 09-23-2010, 04:25 PM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
Since the DOHC cams are welded up and reground, the price per stick is a bit higher than the SOHC stuff. They're still the best value in the Subaru cam game though....no doubt about that!
Jay
Old 09-24-2010, 11:32 PM   #5
CorbanDallas
Member#: 232583
2006 Wrx limited
Thanks for the insight guys. My car is my only car so I am not looking to go crazy with it(hence the non-turbo motor swap). I am just looking for little more power than a stock dohc. I figured since the cams were coming out already it would be a good thing to check into. I am already looking at a $2000 bill for the motor(rebuilt) and installed. Adding on another $600 puts me above my budget. I still
might go for it though Oh the only other mods I will be doing to the motor are a catback exhaust, UEL and a top mount intake. Just in case that was something you needed to know lol.
Old 09-25-2010, 02:24 PM   #6
Badtiming
Member#: 254996
2010 Impreza 2.5i
What kind of gains can you see with swapping out the cams on the 2.5? I have a 2010 2.5i.
Just curious because I know on my last car, if i were to put in a new cam and got a tune I could have easily gained 50-75hp..
Badtiming is offline   Reply With Quote
Cam shaft gear removal? HELP! johndingk2 Legacy Forum 2 01-16-2005 10:27 PM
Cam Shaft Sensor help matt6669 Factory 2.0L Turbo Powertrain 4 03-05-2004 11:53 AM
cam shaft positioning sensor?????????? Harrison Factory 2.0L Turbo Powertrain 15 02-23-2002 06:20 PM
Cobb Cam Shafts mofoporn Normally Aspirated Powertrain 4 09-17-2001 09:42 AM
Warning-Torque Spec Error in Shop Manual for Cam Shaft Cap Bolts GarySheehan Factory 2.0L Turbo Powertrain 3 08-02-2001 04:37 PM
Message Board Statistics All times are GMT -4. The time now is 02:21 AM.
