Old 09-23-2010, 01:17 PM   #1
zakSti
Member#: 118551
2007 SOLD
White Satin Pearl
Default Best Injectors?
My car is starving with my DW 850CC's. i'm around 430WHP..i would like to upgrade 1000's if not 1200's. What do you guys think? from your experience.
1. Bosch?
2. DW?
3. RC?
zakSti is offline   Reply With Quote
Old 09-23-2010, 01:31 PM   #2
berdugo
Member#: 163108
07 EuroDM STi 2.5L
DW 1300 or ID2000
berdugo is offline   Reply With Quote
Old 09-23-2010, 01:38 PM   #3
zakSti
Member#: 118551
2007 SOLD
White Satin Pearl
i did hear the DW's were not fully up to standards.
Old 09-23-2010, 01:45 PM   #4
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx2
Really? any info on the issues with the DW's? Are you talking about the new 1300cc topfeeds? Ive only heard good about the 1300s so far but havent heard much...
rexworx is offline   Reply With Quote
Old 09-23-2010, 01:52 PM   #5
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
probably. I have fiveOmotorsport 1200cc injectors top feed bosh EV14 100% plug and play and they rock, way cheaper than others. I will have some data soon
juanmedina is online now   Reply With Quote
Old 09-23-2010, 01:56 PM   #6
zakSti
Member#: 118551
2007 SOLD
White Satin Pearl
awesome feedback guys...keep em comming. I just heard that the DW's werent spraying the full amount as claimed, thats all.
Old 09-23-2010, 01:59 PM   #7
juanmedina
Member#: 133146
who told you that? I know ID1000 don't spray what they claim, IDK about ID2000
Old 09-23-2010, 02:01 PM   #8
rexworx
Member#: 103232
GTX 3071R'd 11WRX
I have a set of ID1000s sitting on standby. Im was going to sell them because I dont really want to bump my fuel pressure alot.
I know it may sound silly...
Old 09-23-2010, 02:07 PM   #9
zakSti
Member#: 118551
2007 SOLD
White Satin Pearl
well had my DW 850's tested..they were off..buddy of mine.. same thing.
Old 09-23-2010, 02:23 PM   #10
rexworx
Member#: 103232
GTX 3071R'd 11WRX
From what Ive been told the DW1300s are "supposed" to actually flow a little more then advertised "1350cc ish" Also bump the fuel pressure to 50psi and they'll flow 1500cc.
Im interested to learn more about the five0motorsports bosch injectors? their pretty much the same as the IDs but without the hype and pricetag?
Old 09-23-2010, 02:29 PM   #11
juanmedina
Member#: 133146
Yeah, no connectors either 100% plug and play.
Old 09-23-2010, 02:33 PM   #12
rexworx
Member#: 103232
GTX 3071R'd 11WRX
I think Im going to have to look into these more. I need to purchase some soon.
Old 09-23-2010, 03:18 PM   #13
zakSti
Member#: 118551
2007 SOLD
White Satin Pearl
damn that does sound kick arse!
Old 09-23-2010, 03:55 PM   #14
zakSti
Member#: 118551
2007 SOLD
White Satin Pearl
just ordered the 1200's from five 0 ...cheaper than my DW 850's...these guys rock.
Old 09-23-2010, 05:58 PM   #15
juanmedina
Member#: 133146
The 1200cc injectors from fiveO
Injector tab, from when we started tuning
Semi cold start I drove the car like 3 hours earlier
Old 09-23-2010, 07:03 PM   #16
outfrontmotorsports
Member#: 220204
i have 900cc and 1100cc injectors available with flow test results. PM me
outfrontmotorsports is offline   Reply With Quote
Old 09-23-2010, 08:34 PM   #17
arghx7
Member#: 232940
anything that is based on Bosch EV14 is essentially the same thing as what Injector Dynamics sells. Bosch EV14 is a recent OEM injector design.
Injector Dynamics injectors are awesome injectors because they are Bosch EV14, not because Injector Dynamics did anything special to them besides flow testing and fitment related stuff.
arghx7 is offline   Reply With Quote
Old 09-24-2010, 03:22 AM   #18
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
I'll be using the Fuel Injector Clinic 1350cc Subaru WRX/STi BlueMAX Peak and Hold Low Impedance Ball & Seat Injector set (Low-Z) IS275-1350
I'm not sure if they are Bosch EV14 but I spoke to Phil @ Element tuning since I'll be using the Hydra 2.6 which supports low impedance injectors. I gave him the specs on these injectors and he gave me a thumbs up on these.
More info from FIC's site:
Low impedance injectors (1.5 to 4.0 Ohm) have a faster trigger times due to the type of electrical signal pattern emitted by the ECU. This “Peak and Hold” pattern uses a high (6 amp) initial current pulse to open the injector, and then a lower current signal to keep the injector open. Since the “hold” or lower current part of the signal has created a weaker magnetic field, the injector will also close quicker.
Typically most injectors with higher flow rates (600cc/min or more) would be more likely to be low impedance injectors. This is because low impedance injectors have a faster opening response times and generate less heat when operated at higher flow duty cycles.
You will see that most of our injectors flowing more than 500cc/min are low impedance injectors since the performance industry prefers the faster response times of the “Peak and Hold” pattern.
methaddict is offline   Reply With Quote
Old 09-24-2010, 12:49 PM   #19
zakSti
Member#: 118551
2007 SOLD
White Satin Pearl
interesting!
Old 09-24-2010, 03:08 PM   #20
Wardroid
Member#: 248325
2005 STI
1. Bosch?
2. DW?
3. RC?
850cc should be more than plenty for that power level. if you're having issues, it doesn't seem like going with bigger injector would solve the problem.
Wardroid is offline   Reply With Quote
Old 09-24-2010, 05:07 PM   #21
rexworx
Member#: 103232
GTX 3071R'd 11WRX
for a real 430whp on pump/racegas yes. for that whp on e85 thats prob pushing it.
Old 09-24-2010, 08:54 PM   #22
zakSti
Member#: 118551
2007 SOLD
White Satin Pearl
My car wasn't goin' past 430whp. The 850's were maxed out and my maf aswell.. Was hitting 5volts. Got the Perrin big Maf, 1200's on the way... So we will see the outcome.. Possibly next week.
Old 09-27-2010, 03:39 PM   #23
RLR257
Member#: 176667
2006 AW WRX Ltd
PPG'd EWG'd & Dom3'd(XTR)
DW's or ID's...i heard the samething about the DW's a few months ago, but i believe they also heard that and have stepped their game up.
RLR257 is offline   Reply With Quote
Old 09-28-2010, 09:31 AM   #24
zakSti
Member#: 118551
2007 SOLD
White Satin Pearl
Just got in my Bosch 1200's yesterday in the mail. Now next question.. Dual pump necessary? Power wise I'm at 430whp, I would like to be around 470-500whp after these pups get installed, bigger MAF.
Old 09-28-2010, 10:29 AM   #25
murphy660
Member#: 255857
04 35r sti
I have 410whp with 860 helix injectors and I must say they're ****.
murphy660 is offline   Reply With Quote
Best Injector upgrade from stock 2009 wrx injectors? jrzpdx Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 04-02-2010 12:48 PM
best injectors TD05h- 16g mcornale Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 09-18-2005 07:44 PM
So I'm confused - What's the best Injectors jsk Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 08-15-2005 11:08 AM
Best injectors?? 1fastsube Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 12-16-2004 12:50 AM
the best injector how to install Ive seen 7point62 fmj Engine Management & Tuning 4 06-27-2004 07:27 PM
