Old 09-23-2010, 02:00 PM   #1
blacksubieSTi
Member#: 258367
2007 Impreza WRX STi
Black Obsidian
Default Fuel gauge innaccurate
First of all, I would like to appologize if I missed any previous threads on this topic. However, I have found a few but they were all a bit different than my exact issue.
I just bought an 07' STi this past Saturday and when I first filled my gas tank, I noticed that my needle did not completely reach the "F" line. I have now filled my tank a few times and the exact position of the needle varies each time, but still remaines less than Full. Typically in most vehicles, it will exceed the "F" line. I am somewhat concerned as I have an innacurate reading of how much fuel is actually in my tank...
I did read somewhere they were saying that one of the two sensors gets some sort of build up grime on the end of the sensor and produces this innaccurate reading and that by gently cleaning the tip of it, it resolves the issue. They also stated this is a common issue with most Subaru vehicles.
One other thing I noticed is that my engine temp is a bit below center. See the photo below:
Thanks for your help...
blacksubieSTi is offline   Reply With Quote
Old 09-23-2010, 02:31 PM   #2
Rhymesayer
Member#: 181389
13 Sti WRB
93 K20 Hatch
Engine temp is fine. Did the previous owner install a larger fuel pump? He may have bent the lever arm. I bent mine.
Rhymesayer is offline   Reply With Quote
Old 09-23-2010, 02:37 PM   #3
blacksubieSTi
Member#: 258367
Black Obsidian
Not that I know of...where do I check the lever?
Old 09-23-2010, 03:40 PM   #4
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The level sensors contacts may be dirty. Some folks have used Chevron Techron in the tank to help clean the contacts and it has help some of them clear this trouble.
Old 09-23-2010, 03:45 PM   #5
Rhymesayer
Member#: 181389
13 Sti WRB
93 K20 Hatch
Make sure your tank is low and pull out the fuel pump. Its located behind your passenger side rear seat. Then check the lever arm with the little plastic float at the end of it.
Old 09-23-2010, 04:52 PM   #6
blacksubieSTi
Member#: 258367
Black Obsidian
Thank you all for your replies...I will be trying the Chevron Techron and if that doesn't do the trick I'll be moving onto the other method.
Old 09-26-2010, 10:23 AM   #7
Dirty_WRX
Member#: 258491
2002 VF34'd Bugeye
My Other Ride's your MOM
Most likely that bent lever arm. This happens very often when people get impatient taking out the fuel pump assy.
Dirty_WRX is offline   Reply With Quote
Old 09-28-2010, 12:39 AM   #8
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
was the pump ever swapped?, if so the lever arm is probably bent
fastnoypi is offline   Reply With Quote
AEM Boost Gauge and AEM Air/Fuel Gauge FknQikly Engine/Power/Exhaust 24 02-12-2010 04:39 PM
AEM Tru Boost Gauge,AEM UEGO Air/Fuel Gauge,Duel Gauge Dash Bezel jester696 Interior/Dressup/Audio & Security 11 06-21-2009 08:04 AM
AEM Tru Boost Gauge,AEM UEGO Air/Fuel Gauge,Duel Gauge Dash Bezel jester696 Interior/Dressup/Audio & Security 0 05-01-2009 06:02 PM
FS: DFW - Boost gauge, air/fuel gauge, tachometer w/ shift light integralus TXIC Private Classifieds 2 03-05-2009 07:01 PM
air/fuel gauge vs. EGT gauge kaidoy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-02-2001 10:00 PM
