Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 09-23-2010, 03:28 PM   #1
mC_LoCc_E
Member#: 253708
1995 Legacy Wagon
Red
Question Speedo, Tach, Turn Signals, Climate Contols, and Stereo suddenly won't work???
Ight so I have been tearin apart my car so i can put my stereo in but ran out of time yesterday and had to go to class when i noticed my Speedo, Tach, Turn Signals, climate controls, and my stereo wont power on(at least those are the things ive noticed). The only things I've disconnected are the plugs to my window switches on my door...I checked all of my fuses and they're all good so I am at a complete loss for ideas. I tried resetting my ECU and that didn't do a damn thing so yeah....anybody got an idea?
mC_LoCc_E is offline   Reply With Quote
Old 09-24-2010, 10:40 AM   #2
ruby914
Member#: 243509
2002 WRX in a 914POR
Many
Did you disconnect any ground wire?
ruby914 is offline   Reply With Quote
Old 09-24-2010, 11:59 AM   #3
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I would guess you either missed a blown fuse as a lot of folks do on the first check or there is a loose connector under the dash to those areas.
Old 09-25-2010, 08:22 PM   #4
mC_LoCc_E
Member#: 253708
1995 Legacy Wagon
Red
lol I didn't disconnect any ground wires to my knowledge...I disconnected my window switches so i could take my door cards off and i ran some wires but i never soldered or connected any of them yet....and I DID check my fuses at least 5 times...
Old 09-26-2010, 12:11 AM   #5
mC_LoCc_E
Member#: 253708
1995 Legacy Wagon
Red
im guessing something got pulled out when i was running wire through the doors but i have no idea what could cause all that...idk if that helps...
Old 09-28-2010, 07:26 PM   #6
Cougar4
Member#: 53443
Winestone
You need to verify if power is getting to those areas. I would bet there is fuse or a power wire problem.
Old 10-01-2010, 10:10 PM   #7
mC_LoCc_E
Member#: 253708
1995 Legacy Wagon
Red
ok havent tried to verify power yet but i was fidgeting with my car and i noticed when i turn my ac on the light comes on for it but when i turn the blower on, it turns the light off...and just a second ago i turned on my hids and my gauge cluster lights waited a second or two and turned on...i disconnected my new radio to see if something got f*cked up and i turned on my car again and tried to turn my lights on and now my gauge cluster wont light up...so obviously i have a short somewhere...im just baffled right now
Old 10-01-2010, 10:29 PM   #8
mC_LoCc_E
Member#: 253708
1995 Legacy Wagon
Red
i was also reading in an older post where you helped someone with a turn signal/hazard problem....do you think an ignition relay could be a factor in this case? .....and btw i tried replugging in my radio and now my guage cluster wont light up at all....also i just used a tester on my fuse panel for my radio slot and i didnt get any power there...
Old 10-01-2010, 11:05 PM   #9
Cougar4
Member#: 53443
Winestone
The trouble isn't due to a short but it does sound like a bad connection to power somewhere. The trouble could be due to a faulty ignition switch or in the wiring before or after the switch. You need to check that. Also make sure the fuses under the hood are ok and if you have any fusible links be sure they are making good connection. Clean the battery to chassis ground.
Old 10-10-2010, 06:09 PM   #10
mC_LoCc_E
Member#: 253708
1995 Legacy Wagon
Red
ight man so far ive been takin your advice, but jus dont know about this ignition switch thing....i was wigglin around some wires and my hazards are working, but my turn signals wont...from my reading i know that they are on the same circuit but the turn signals are after the hazards, idk if this can help you pinpoint my problem or not...
Old 10-10-2010, 06:27 PM   #11
Cougar4
Member#: 53443
Winestone
Ok. If all the other things you first mentioned still aren't working along with the turn signals then you need to check for power using a test light probe. We need to verify that power is getting to the fuses first. If that is ok then we need to test further down the line. If you don't have a test light then you need to got one so we can prove where power is getting to.
Old 10-10-2010, 06:59 PM   #12
mC_LoCc_E
Member#: 253708
1995 Legacy Wagon
Red
i tested some of my fuse slots and it says the radio is getting a steady 12 amps....rear turn signals no power, and mirrors no power.
Old 10-10-2010, 10:18 PM   #13
Cougar4
Member#: 53443
Winestone
If the fuses you tested that had no power were in the dash then check the fuses under the hood and make sure they have power to them.
Front turn signal, brake light, and running light won't turn off Floor it Electrical & Lighting 0 06-27-2009 10:34 PM
FS: turn signals, side markers, and side idicators, CLEAR and Orange soobyfan Exterior/Styling 0 11-11-2007 02:31 PM
GC8 -> Fog covers, turn signals, rear spats. maumau Private 'Wanted' Classifieds 3 04-11-2007 06:21 PM
Rear defroster and Wiper defroster install with Remote Start rockwvu Car Audio, Video & Security 2 11-24-2004 01:23 PM
turn signal indicators (front and rear) basicsk8 Interior & Exterior Modification 15 08-19-2003 12:00 PM
