Old 09-23-2010, 04:33 PM   #1
ASU
Member#: 164551
2006 Brotastic STi
Land of beer and laws
Default Found problem Cracked head
Thought it was a head gasket with all the smoking, no it was worse than that
ASU is offline   Reply With Quote
Old 09-23-2010, 04:53 PM   #2
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Happened to me too on the intake side though.
alcoolaid is offline   Reply With Quote
Old 09-23-2010, 04:54 PM   #3
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
those must be ported heads? or stock?
FuJi K is online now   Reply With Quote
Old 09-23-2010, 06:45 PM   #4
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
CNC Ported Cosworth heads
Token-Negro is offline   Reply With Quote
Old 09-23-2010, 06:58 PM   #5
crashtke
Member#: 120912
Doe! Man that sucks. Any clue what to attribute it to?
crashtke is offline   Reply With Quote
Old 09-23-2010, 07:09 PM   #6
ASU
Member#: 164551
2006 Brotastic STi
Overporting most likley, not 100% sure the block is fine.
Old 09-23-2010, 07:29 PM   #7
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
same thing happened to me a while back...
Been hearing a few horror stories about Cosworths Big post heads lately...
mtcs is offline   Reply With Quote
Old 09-23-2010, 07:35 PM   #8
02WRX2.5
Member#: 63192
02 wrx
161mph Trapspeeds
Humm just had a failure myself blew a hole out of the exhaust side...
02WRX2.5 is offline   Reply With Quote
Old 09-23-2010, 07:51 PM   #9
ASU
Member#: 164551
2006 Brotastic STi
All I can think is that the port was way to aggressive there is no reason to have failure on heads like this with less than 4k on them and not hitting past 19 PSI. This time I am going to not port my heads just grind them down and cut the seats for my kelford and supertech valve train. This is for reliabilty issues the wall must be paper thin for that to happen.
Old 09-23-2010, 07:56 PM   #10
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
WOW man, that sucks. Sorry to hear and I know how you feel just when your close to having it all running good something jumps up and bites you.
Sinister redlines is offline   Reply With Quote
Old 09-23-2010, 07:58 PM   #11
ASU
Member#: 164551
2006 Brotastic STi
Had her purring like a kitten, now I am scrambling just to get her back up and running
Old 09-23-2010, 08:12 PM   #12
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
CGM
Ya, I am sure you heard about my latest experience with my 2.7L if not ask Mike or Dom. I feel ya and hope it gets better for ya. Too bad to I wanted to see your car running I had heard it was working awsome till this..
Old 09-23-2010, 08:29 PM   #13
ASU
Member#: 164551
2006 Brotastic STi
It was still a monster even with the cracked head. Oh well back to step 1 again
Old 09-23-2010, 08:34 PM   #14
Evil Imports
Member#: 14732
+ 13 B8
Evil Imports is offline   Reply With Quote
Old 09-23-2010, 10:56 PM   #15
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
ekkkKK. So far, I only port at the valve bowl, valve guide, short turn and splitter for the exhaust side. For B25 STi heads and their smaller exhaust ports, they flow well because they are much straighter. Big improvement on stock valves with the B25 heads flowing 178cfm stock to an impressive 228cfm on the Dog Leg.
Old 09-24-2010, 04:59 AM   #16
Beetspeed
Member#: 166264
1974 VW 2.2ltr 7670
402 WHP @ 30psi
Is that per port or for both (intake?) ports together ?
Tnx and sorry for the OT.
Walter
Beetspeed is offline   Reply With Quote
Old 09-24-2010, 02:03 PM   #17
alcoolaid
Member#: 134949
'07 SWP STi
Is the head repairable?
Old 09-24-2010, 02:43 PM   #18
rdieder
Member#: 257818
2007 STi
CGM
rdieder is offline   Reply With Quote
Old 09-24-2010, 02:46 PM   #19
wobbletop
Member#: 11652
'11 STI 5dr Red
'70 Porsche 914/6
YouTube - Cracked STI Heads
Newb question... what am I looking at?
wobbletop is offline   Reply With Quote
Old 09-24-2010, 03:26 PM   #20
ASU
Member#: 164551
2006 Brotastic STi
Dindt know you could repair a cracked head
Old 09-24-2010, 03:34 PM   #21
ASU
Member#: 164551
2006 Brotastic STi
Originally Posted by rdieder View Post
I wish that would work, but I have a feeling it couldnt sustain 2000 temps and on top of that once a crack develops even if you seal it, its a weak point and prone to more cracks.
Old 09-24-2010, 04:59 PM   #22
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
I think it was bretune who had something similar happen to him. I believe he just welded the crack shut and then did some porting and was on his way. Id give that a shot with those big $ heads
Old 09-24-2010, 06:01 PM   #23
rdieder
Member#: 257818
2007 STi
CGM
2000 temps? i'd stay away from that tuner, that high heat is a result of way lean.
I saw from your other thread you had over heating issues, did you top off with cool water? If so , it can crack a head if the motor was still hot. Also can crack from high pressures due to det
Old 09-24-2010, 08:22 PM   #24
69subaru360
Member#: 159682
1995 WRX
2015 F150
High egts lead to cracks like that. JB weld will work fine on the intake side but not the exhaust. Just have it welded up and save the head. If you can get at the ends of the crack, drill them to stop it from spreading.
Old 09-24-2010, 09:37 PM   #25
bertune
Member#: 107290
Yes sir u r perfectly right, first it happened on the exhaust side and sucked oil out of the motor so there was alot of smoke nothing major, then next it was on the intake side and then it sucked water...............HYDROLOCKED!
bertune is offline   Reply With Quote
110k miles, found hairline crack on Airbox hose. strohausii Service & Maintenance 9 01-04-2010 12:23 PM
So I just found out my younger bother is a crack head. Rev Off-Topic 27 04-10-2005 02:25 PM
Class Action Lawsuit Re: Blown Head Gaskets/ Cracked Heads/ Overheating oldblackbeard Legacy Forum 22 01-13-2005 12:18 AM
Stupid crack-headed idea.. but what the hell.. Diranged Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 06-28-2002 03:39 PM
Cracked Heads. Radiator Broke. CAB General Forum Archive 3 03-28-2001 07:58 PM
