Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 09-23-2010, 10:38 PM   #1
Impact240sx
Member#: 237603
Default 96 Legacy crank pulley torque
Dumb question but i just did my timing belt/water pump. How can i keep the motor from turning when Im trying to torque the pully down? 2.2 Ej22
Impact240sx is offline   Reply With Quote
Old 09-24-2010, 03:37 PM   #2
Impact240sx
Member#: 237603
bump!!
Old 09-24-2010, 05:57 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Put it in gear and have someone stand on the brake pedal. If you don't have an extra body to stand on the brake pedal, then wedge something between the driver seat and the pedal. (That works better if you have a power seat and can wedge something in there, then drive the seat forward. )
Pat Olsen
Old 09-26-2010, 02:31 PM   #4
GeneralDisorder
Member#: 108999
1991 Legacy SS
Pearl White
Just use a 1/2" socket (deep is prefered) and ratchet handle - carefully position the handle and smack the end of it with a 3 to 4 lb hammer. Do this about a dozen times. Hand Impact FTW. The actual torque value isn't important - just as long as it's tight enough to not come loose.
GD
GeneralDisorder is offline   Reply With Quote
Old 09-27-2010, 11:44 AM   #5
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
For an automatic putting it in gear won't work. You will have to keep the motor from turning by securing the flex plate or wrap a chain wrench around the crank pulley.
jey is offline   Reply With Quote
Crank pulley install: How many ft-lbs to torque down the pulley? roninsoldier83 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 41 07-29-2008 10:48 PM
Crank pulley torque XTTX Newbies & FAQs 12 06-21-2008 12:39 AM
Crank pulley torque spec. NRTmotorsports Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-21-2005 03:29 AM
Torque Spec on stock crank pulley? Baluchitherium4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-12-2003 07:53 AM
Torque specs for alternator and crank pulleys BluJay Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-23-2001 11:48 AM
