Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 09-23-2010, 10:46 PM   #1
dimwittedmoose
Member#: 231049
Default '02 OBW Battery Melt??
We just got back from vacation driving maybe 1000 miles or so and when checking the oil at a gas stop, I nopticed our battery sort of conforming to the shape of the factory clamping mechanism. It's not a high dollar battery(came with the car when I bought it), but I've never seen the battery case buckle like this one has; maybe 3/8" of meltdown?
1. Is there a chance the engine compartment(no turbo, if that's where you were going) is getting this hot that's causing this melting?
2. Any chance the alternator is over charging the battery?
3. Or is it "cheap ass battery syndrome" and it's merely time to replace it?
I have our Interstate battery in our 96 Legacy Wagon clamped down at least as tight as the clamp in the OBW, so I doubt that's the problem....or is it? We did replace the alternator with one from Advanced Auto, but again, we have an Advanced Auto alternator in the Legacy and we're not having that problem with it.
Any ideas from the Gurus would be a big help. Don't want to fry a $90 Interstate battery if there's a problem with the electrical system.
Thanks
Max
dimwittedmoose is offline   Reply With Quote
Old 09-24-2010, 08:13 AM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Normal engine heat, even with a turbo, should not distort or damage the battery.
The first thing to do is measure the voltage at the battery terminals with the engine running. It should be no higher than about 14V at operating temperature. If it's considerably higher than that, especially if it's 15V or above, you have a faulty regulator and need a new alternator. Excess voltage over a prolonged period will cause the battery to overcharge, overheat and vent gas and acid.
The battery itself could also have just failed, it does happen.
Once the alternator has been checked and either replaced or verified as ok, go ahead and replace the battery. Be sure to clean up any acid that may have spilled over, using a baking soda solution to neutralize it and prevent future corrosion.
Old 09-24-2010, 05:33 PM   #3
dimwittedmoose
Member#: 231049
Thanks. I think I'll let Advance do the alternator testing and see if they remember selling me the Alternator.
Max
Old 09-24-2010, 08:33 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Max
there is the issue
Old 09-25-2010, 06:22 PM   #5
dimwittedmoose
Member#: 231049
Alternator tested out fine. Battery Voltage with engine idling and no load was 14.1. With engine off, 12.05. Advanced Guru said the battery is a tad weak with full load on it, but not toast. Car starts fine and headlights seem normal, but he'd never seen a battery melt down around the battery clamp like that either. Definitely some battery fluid corroding the clamping bar. Battery's going to get replaced soon.
What is the biggest "series" battery I can fit in there size-wise? He was pushing a 35-N, but the current one is an 85. For what Advanced wanted for their 3 year warranty Gold battery, I could get the same spec battery from Interstate with 7 year warranty on it for less money.
Thanks
Max
Old 09-26-2010, 11:57 AM   #6
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Costco battery... never failed me. Take a photo if you can of your meltdown though, should be interesting!
Old 09-26-2010, 03:07 PM   #7
dimwittedmoose
Member#: 231049
No Costco for 3 states in any direction. to my knowledge. Anything that Johnson Controls makes should be fine.....wait a minute, the current battery is a JC!!!! Guess I better pull it and check the sell date.
Max
Old 09-27-2010, 07:16 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
there is a REASON that many of us will NEVER buy anything other than a
get this one
GENUINE SUBARU ALTERNATOR
gee.....wonder why?????
WTB : '02-07 WRX WAGON tops/struts/springs - take - offs wtdash Private 'Wanted' Classifieds 8 09-23-2010 11:01 AM
Tips For Pulling the DS Cam In An '02 OBW? Seal Leak dimwittedmoose Service & Maintenance 1 02-16-2010 04:59 PM
Melting Battery Terminals, Smoke Everywhere(!!) cartervt2k Electrical & Lighting 6 02-16-2010 10:14 AM
'02 OBW Transmission Shift Points BraytonAK Outback Forum 0 10-10-2003 01:03 AM
Broken Tachometer in '02 OBW BraytonAK Outback Forum 0 10-10-2003 12:52 AM
