Welcome to the North American Subaru Impreza Owners Club Tuesday January 27, 2015
Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Suspension/Brakes/Handling
Closed Thread
Old 09-24-2010, 05:39 PM   #1
RaceComp Engineering
Vendor Sales Rating: (30)
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Default Racecomp and GTWORX are MOVING sale! GTWORX Bilsteins out now and new RCE parts!
Ok we are moving to a new place in Severn, MD, but its into a nice, small, quaint, intimate 1500 sq ft unit with sales office, customer lounge and shop for fitting and testing parts applications. Stay tuned for more info! October 1st we move in and expect an open house this fall!
GTWORX Bilsteins and Racecomp Engineering GH Yellow performance springs!
for 08+ Impreza WRX
The wait is over!
Manufactured by BILSTEIN Exclusively for GTWORX using customized SPORT VALVING matched to a NEW RCE "YELLOW" performance spring.
Observing the poor results of pairing lowering springs with the standard Subaru dampers, GTWORX decided to start from scratch and develop an entirely new spring and damper package in conjunction with the world renowned shock experts at Bilstein. This new set-up was designed from the ground up to pair with an all new “Yellow” high performance spring from Racecomp Engineering.
The goal was to transform the Impreza WRX into a precision handling machine. Extensive testing was conducted at Bilstein USA West headquarters in Poway, California to perfectly match the monotube, gas charged, inverted front struts and rear shock system with Racecomp Engineering springs. Several damping profiles were considered, with the final selection exceeding all expectations. An emphasis on low speed bump and gas pressure provide “platform” to stabilize the chassis and is normally recognized as a reduction in initial body roll, pitch, and dive.
These dampers also provide an excellent option for stock class autocrossers looking for an OEM fitment damper that has firmer damping and large amount of gas pressure to pair with stock springs.
The rear shocks feature an adjustable SIR CLIP for + 5 mm, +10 mm or -5 mm, -10 mm rear ride height.
Designed for both WRX sedan and hatchback, these make your Impreza handle like it should from the factory!
GTWORX Bilsteins only
$999 + shipping
GTWORX Bilsteins and RCE GH Yellow Springs
$1349 + shipping
GTWORX Bilsteins and RCE GH Yellow Springs FULLY ASSEMBLED with all OEM mounts and hardware:
$1599 shipped
This saves you a lot of time/money in labor and you do NOT need to break down your stock shocks. Everything comes pre-assembled and ready to pop-in. Very convenient.
_
__________________
512 Shaw Ct, Suite 104
Severn, Maryland 21144
410-846-5407
RaceComp Engineering is offline
Old 09-24-2010, 05:39 PM   #2
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Racecomp Engineering GH Yellow performance springs for 08+ Impreza WRX
Designed in conjunction with the GTWORX Bilsteins, the Racecomp Engineering GH chassis Yellow sport springs turn a soft, rally-inspired, sports sedan or hatchback into a mean, corner-carving, track-worth machine. With spring rates and a drop designed from the ground up to maximize the capabilities of the Bilstein dampers, this system allows a level of control far above what was expected from the 2008 and later Impreza WRX.
Spring rates are 330 lbs/in front and rear with a drop of 20mm front and 15mm rear.
This part is not to be used with OEM dampers. A Bilstein or Koni upgrade is required.
$349 shipped
_
__________________
410-846-5407
Old 09-24-2010, 05:40 PM   #3
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Racecomp Engineering GR Yellows Sport lowering springs
for 08+ Impreza STI
RaceComp’s classic “Yellow” high performance lowering spring is now available for the GR chassis Impreza STI! Following the release of our popular "Regular Guy" springs, RaceComp has produced a more aggressive lowering spring for the 08+ STI. These new springs lower the car approximately 15mm and include new replacement bumpstops to maintain as much travel as possible on the lowering sensitive GR Impreza chassis. Spring rates are an aggressive 330 lbs/in front and 335 lbs/in rear. With a stance to match the performance, these springs utilize the knowledge RaceComp has gained from years of GR chassis set-up experience to maximize handling, retain ride comfort, and improve the look of your Impreza.
Racecomp Engineering’s goal was to help cure the crippling understeer that adds to lap times at the track and autocross course. Studying the design of the new GR suspension, a more aggressive performance spring has been produced that retains available bump travel, matches the OEM
dampers, and works in conjunction with the new rear motion ratio. The result is a car that handles extremely well from corner entry to corner exit.
$359 + shipping
_
__________________
410-846-5407
Old 09-24-2010, 05:40 PM   #4
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Racecomp Engineering 2008 Impreza WRX and STI (GH and GR) Sway Bars
These front and rear 25mm hollow 2 position adjustable swaybars are a must have for your 2008 and later Impreza STI. Featuring carefully chosen swaybar rates and a tubular design, these swaybars weigh less than other solid bars with a similar stiffness.
Designed to work with stock or highly modified suspensions, these make a perfect addition to any coilover system. Match them with RCE Regular Guy Functional Lowering Springs or RCE Yellow springs for coilover level performance at a more modest price.
Front and rear bars:
$399 shipped
__________________
410-846-5407
Old 09-24-2010, 05:40 PM   #5
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Racecomp Engineering GR Black "Regular Guy" Functional Lowering Springs for 08+ Impreza STI
Finally, a performance spring designed with function over form is available for the latest Subaru Impreza STI.
Paying special attention to the completely new rear suspension design of the GR chassis, the Functional Lowering Springs provide a mild 5mm drop front and rear to maximize the limited suspension travel available. Shorter bumpstops are included front and rear to take things one step further, resulting in more bump travel than stock. Rarely does an aftermarket spring set-up add suspension travel, but in this case it is a crucial design aspect that improves performance while helping to maintain a civil ride on the street.
Spring rates of 320 lbs/in front and rear are intended to work with the completely new rear suspension of the GR chassis, which has a lower motion ratio in the rear than previous Imprezas. In addition, the OEM dampers have been carefully examined on a shock dyno to match the new spring rates to the dampers.
Continuing the “Regular Guy” theme from previous Racecomp designs, the springs are colored black for a low key look. Coupled with the minimal drop, most people would be hard pressed to find anything different from stock….until the road curves.
$359 + shipping
_
__________________
410-846-5407
Old 09-24-2010, 05:40 PM   #6
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Racecomp Engineering Steering Rack Bushings for 2008+ Impreza WRX, STI and 2005-2009 Legacy
Racecomp Engineering Steering rack bushings are now available for 2008 Impreza WRX and STI as well as 2005 Subaru Legacy GT. These advanced polyurethane bushings that eliminate slop in steering and increases response.
Improve the feel and control of your car without adding harshness or noise. Sharper steering and improved control from a durable, reliable, and low key bushing upgrade. Includes special OEM bush removal tool kit for easy installation.
$69 + shipping
__________________
410-846-5407
Old 09-24-2010, 05:41 PM   #7
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Racecomp Engineering GH and GR Kool Brake Kits for 08+ Impreza WRX and STI
All new Kool Brake Kit reduces brake temperatures at the track by directing air to the center of the rotor. Comes with 2 brake ducts, foglight inlet adapters, high quality 300 degree temp. duct hosing and stainless steel hose clamps.
This kit was designed to cool and vent the braking system, thus reducing rotor temperatures and increasing the usable life of both brake pads and rotors. Initial testing at Summit Point Raceway showed up to a 200 degree F drop in rotor temperature when using aggressive pads. Testing was done with Pagid Blue RS-42, Pagid Yellow RS-19 and the new RS-29 brake pads. Designed to work with both stock STi rotors and any aftermarket 2 piece rotor, this kit is a must have for serious track day and race enthusiasts.
$479 + shipping
new version coming soon for GD!
__________________
410-846-5407
Old 09-24-2010, 05:41 PM   #8
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
GTWORX Camber Plates for 02-07 Impreza, 08+ Impreza, and 05-09 Legacy
Key features of these front camber plates include a very low stack height, which means that tehse top mounts are non-raising at most camber settings. In addition, up to +.8 degrees of caster are built in to the camber plate, which helps minimize dynamic camber loss in a turn for the camber-challenged Impreza chassis.
GTWORX lightweight alloy camber plates feature a high quality pillowball bearing provides smooth, long lasting and quiet operation. Hardware is zinc coated stainless steel. Each bearing is rated at 37,000 lbs radial and 7,730 lbs axial force.
$359 + shipping
__________________
410-846-5407
Old 09-24-2010, 05:41 PM   #9
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Racecomp Engineering Yellow Lowering Springs for 04-07 Impreza STI
With increased and mildly progressive spring rates, these springs are properly
matched to the stock dampers. Thus ensuring that ride quality is not
diminished. The performance is on par with the Black Springs but bring the
car further down to 20mm drop in the rear and 23mm in the front.
$339 + shipping
_______________________________________
Racecomp Engineering Black Lowering Springs for 04-07 Impreza STI
With a subtle drop and increased spring rates, the RCE Black Springs are a
perfect option for those who daily drive their cars as well as the autocrossers
and track day weekend warrior.
$339 + shipping
Racecomp Engineering Adjustable swaybars
for 04-06 Impreza STI
Our well known swaybars that are adjustable from 25.5, 27.0 and 28.5mms.
Designed to work well with stock springs, lowering springs or coilovers.
Includes washer tabs to prevent walking.
$209 each shipped (regular price $219 + shipping)
__________________
410-846-5407
Old 09-24-2010, 05:42 PM   #10
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Racecomp Engineering GR Tarmac II Clubsport Coilovers for 08+ Impreza STI
These coilovers feature the same inox-line stainless steel corrosion
resistant construction as previous versions of KW suspensions. Spring
rates are 9 kg front and 9 kg rear. These are aggressively valved, 2 way
adjustable, performance coilovers. These are valved more aggressively
then the standard KW Variant 3's, yet still offer an amazing ride
quality not felt with other brands.
$2280 Shipped (Coilovers Only)
$2550 Shipped (Group-N Front Tops, STi Rear Tops-Fully Assembled)
$2699 Shipped (GTWorx Front Camber Plates, STi Rear Tops-Fully Assembled)
Racecomp Engineering GD Tarmac II Coilovers for 02-07 Impreza WRX and STI
Racecomp Engineering Tarmac 2 coilovers are comprised of stainless steel dampers mated to linear race springs, incorporating a 2 way design with separate compression and rebound adjustments, motorsports level spring rates, composite locking perches with safety perches added, piggyback reservoirs on all front dampers, and feature a limited lifetime warranty.
These shocks were used on the 2008 SCCA National STU champion Impreza STI.
$2,275 (Coilovers only) + shipping
$2,695 (Group N Top Hats) shipped
$2,995 (GTWORX Camber Plates) shipped
Racecomp Engineering GD Tarmac Zero Coilovers for 02-07 Impreza WRX and STI
With preset damping and adjustable ride height, these coiolvers are made to
maximize performance and ride quality while still being very affordable. The
Tarmac Zero Coiolvers are based on the popular RCE Tarmac 2s and offer the
high quality of KW suspension in germany.
$1,899 (05-07 STI) + shipping
$1,775 (04 STI/02-07 WRX) + shipping
__________________
410-846-5407
Old 09-24-2010, 05:43 PM   #11
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
space saved for PACKAGES
our favorite:
RCE Yellows or Blacks for GR + GR Sways $749 shipped
add RCE Steering Rack Bushings for 50 bucks.
__________________
410-846-5407
Old 09-24-2010, 05:43 PM   #12
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
another space.
__________________
410-846-5407
Old 09-24-2010, 05:46 PM   #13
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
just in case.
__________________
410-846-5407
Old 09-24-2010, 05:52 PM   #14
medamullet
Member Sales Rating: (35)
Member#: 99442
2006 SGM STI
I'm on CORN YO!
needs more JDM
medamullet is offline
Old 09-26-2010, 07:47 AM   #15
Hyper
Member Sales Rating: (30)
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
do you still carry GC T2s? No longer see them on the website
Hyper is offline
Old 10-15-2010, 03:51 PM   #16
GTWORX.com
Vendor Sales Rating: (10)
Member#: 97303
2009 WRX and Boxster
Gray and Black
email if you're interested in GC T2's or PM.
__________________
GTWORX - 410-846-5633
- BILSTEIN- Cobb - WHITELINE- Kartboy - KW - AST - STOPTECH - SPARCO-JRZ
GTWORX.com is offline
Old 10-15-2010, 03:53 PM   #17
GTWORX.com
Member#: 97303
Gray and Black
Some pictures:
__________________
Old 10-22-2010, 03:15 PM   #18
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
we've moved!
__________________
410-846-5407
Old 12-03-2010, 04:45 PM   #19
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
steering rack bushings arrived.
__________________
410-846-5407
Closed Thread
its official, the fed and treasury are moving to bail out freddie and fannie today lateralus1082 Off-Topic 9 07-13-2008 10:38 PM
RaceComp and GTWORX are moving Sale!!!!!!!! GTWORX.com Suspension/Brakes/Handling 25 04-27-2006 03:30 PM
My wife and I are moving tommorrow BGPunk2001 Texas Impreza Club Forum -- TXIC 7 04-23-2006 05:16 AM
Shop Moving Sale Tons of Used WRX and Forester parts John Holmes Private 'For Sale' Classifieds 91 07-18-2005 01:12 PM
Christine and I are moving to Harrisburg, PA. Siper2 New England Impreza Club Forum -- NESIC 25 01-14-2004 01:49 PM
