Welcome to the North American Subaru Impreza Owners Club Friday October 24, 2014
Old 09-25-2010, 11:44 AM   #1
gtbensley
Member#: 167448
2013 2013 wrx hatch
Plasma blue pearl
Default 215/60/16 on Legacy?
I can't seem to find any info on this. Does anyone know if I can run 215/60/16 on a 98 legacy gt? These are off a forester and mounted on steele rims.
Thanks
gtbensley is offline   Reply With Quote
Old 09-25-2010, 12:27 PM   #2
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Yes, these wheels will likely fit, although your speedometer will be reading a shade LOW as the wheels are bigger (you will be traveling at a faster speed than your speedometer indicates).
Also there is some possibility of wheels rubbing, and even greater possibility of snow and ice getting packed up on your inner fenders and rubbing against your tyres.
I don't recommend it, but I *think* it will work.
Jonathan is offline   Reply With Quote
Old 09-25-2010, 05:42 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
It will be more than a "shade" - it'll be about 5% off, which is a pretty big difference. Those tires are about 1.3" taller than the proper size, so they'll probably fit on the car, but as Jonathan said, there may be problems as a result of the bigger tires.
I wouldn't do it.
Pat
Old 09-25-2010, 09:17 PM   #4
jamal
Member#: 71875
98 2.5GT
my wheels fit
it's likely the tires will contact the struts
jamal is offline   Reply With Quote
Old 10-01-2010, 09:28 AM   #5
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
i had 215's on the stock wheels slightly lowered and I was rubbing on the fenders all day...you may not be lowered but you're talking about putting bigger tires on there so chances are you'll rub too
legacy1907 is offline   Reply With Quote
Old 10-01-2010, 02:49 PM   #6
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Originally Posted by legacy1907 View Post
I had 215's on the stock wheels slightly lowered and I was rubbing on the fenders all day...You may not be lowered but you're talking about putting bigger tires on there so chances are you'll will experience rubbing as well.
GT Bensley is using a Legacy GT wagon. I am not sure what vehicle Legacy1907 was using. Was it a GT ? Or maybe a more basic car like maybe a Legacy L or LS ? Were these 16" wheels, or 15 inches ? What aspect ratio ? 55s ? or maybe 60ies ?
Old 10-03-2010, 11:20 AM   #7
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
i had 215/55/r16 on a GT that was slightly lowered, but it would rub the inside of the fenders pretty nicely
Old 10-06-2010, 03:23 PM   #8
Zakster87
Member#: 176886
2008 00/08 LGT LTD's
00-Titanium Pearl 08-DGM
this site is extremely helpful for finding out what tires will fit and how far your speedo will be off... http://www.rimsntires.com/rt_specs.jsp
Zakster87 is offline   Reply With Quote
Old 10-08-2010, 11:33 AM   #9
PA-Outback2000
Member#: 161832
2000 Outback Limited
what is teh stock size?
PA-Outback2000 is offline   Reply With Quote
Old 10-08-2010, 11:35 AM   #10
Zakster87
Member#: 176886
of what?
Stock size tires for my stock 16x6.5 +50 snowflakes is 205/55R16...
Old 10-11-2010, 09:05 AM   #11
PA-Outback2000
Member#: 161832
a better choice would be a 215/55/16. the closest choice if u want bigger is 225/50/16.
if u went with the 215/60/16, u would be off +3mph. ur speedo would need to read 63mph to actually be doing 60mph.
Old 10-11-2010, 10:14 AM   #12
grafton
Member#: 187936
97 Legacy w/12:1CR
07 WRB STi
I've rubed on 205/55r16's with a full car load, and only have ~3/16"s tire to strut clearance in the rear. it's not possible for me to run taller tires or wider ones.
i'm on kyb's and H&R lowering springs, but strut clearance is my killer issue
grafton is offline   Reply With Quote
Old 07-09-2011, 05:37 PM   #13
Hites
Member#: 138997
0000 Nothing
Could a stock ride-height 99 Legacy L (wagon, if that matters) run 215/60-16s? If not, then what about one with Outback shocks (+1.5") and lowering springs (-1.5")?
Hites is offline   Reply With Quote
Old 07-25-2011, 04:33 PM   #14
PMDSOA
Member#: 274810
05 LGTL
Brilliant Silver
I have 205/55/16 on my 99 outback and it seems like a tight fit but it did clear. 05 WRXwheels. I was afraid it would rub but it doesnt. Maybe see if you can find someone to let you test fit ??
I dont know if the outback shocks will work with lowering springs. You might be compressing the shock to much??
PMDSOA is offline   Reply With Quote
Old 07-25-2011, 06:13 PM   #15
Wiscon_Mark
Member#: 94945
1995 Legacy OB 5MT
2003 Forester X 5MT
I wouldn't think Outback shocks would work well with lowering springs either. Either opt for GT shocks, or some KYB GR-2s if you're going with new parts...
Wiscon_Mark is offline   Reply With Quote
Old 07-30-2011, 12:56 PM   #16
'Buru in the Burgh
Member#: 262205
2003 Legacy
18x Regatta Red
Will I be able to run 225/45/17's on my 2003 Legacy w/ stock suspension?
'Buru in the Burgh is offline   Reply With Quote
Old 07-30-2011, 02:11 PM   #17
Azlegacy
Member#: 279837
I think 215's are the widest. But I could be wrong.
Azlegacy is offline   Reply With Quote
Old 08-05-2011, 09:32 AM   #18
PMDSOA
Member#: 274810
05 LGTL
Brilliant Silver
Outbacks can get 225 to fit. I read that on the subaru outback forum. Id think 215 on a legacy with stock suspension should fit.
Old 08-05-2011, 12:23 PM   #19
cgroh89
Member#: 285758
I am running 215/60/16 on a 2004 legacy. Yokohama Geolander At/s its a tight fit but I have rubbed them yet except under alot blunt force hitting some ruts in mud.
cgroh89 is offline   Reply With Quote
Old 08-05-2011, 12:44 PM   #20
Zakster87
Member#: 176886
Needs MOAR mudflaps! ... like this!
Old 08-06-2011, 12:51 AM   #21
cgroh89
Member#: 285758
Got some ikea mud flaps in the work lol, your car looks sharp though, I like the color!
Old 08-06-2011, 03:14 PM   #22
Zakster87
Member#: 176886
made mine out of a semi mudflap from a farm and fleet store. Much more durable than teh ikeas, but they only come in black.
215/60/16 on Legacy? gtbensley Legacy Forum 0 09-25-2010 11:42 AM
215/60/16 on wrx? austinpike Tire & Wheel 5 02-03-2009 12:50 PM
Quickie: 215/60/16 On Stock Wheels? TDQuiksilver Tire & Wheel 2 04-15-2008 11:27 PM
Quick question... 215/60/16 on stock RS? RSblood Tire & Wheel 6 12-10-2005 07:46 PM
Fitted Michelin Energy XM1 215/60/16 on MY03 XS Forester subyroo Tire & Wheel 1 09-16-2004 11:18 AM
