Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 09-25-2010, 12:27 PM   #1
homemade
Member#: 235937
88 supra
Default my swap is throwing a CEL
ok so after i swapped the ej20g with a 93 harness, im getting a CEL.
since putting the 93 harness in (which is obdI) i have no way of checking
what the CEL is.
any hints.
this is kirils old motor. he says he had it running with 0 CEL's.
it runs fine i am just getting sick of seeing this light.
homemade is offline   Reply With Quote
Old 09-26-2010, 03:42 AM   #2
EsubaruJ
Member#: 200008
03 wrx
TE72 wagon, Legacy wagon
Remember the clips under the steering column that were plugged in making it so you couldn't start the car? They should be black for that year, in other years they were green. Those clips put the car in test mode. When you clip them together you need to count the number of times the check engine light flashes. Count the slow and fast flashes separately. The slow flash indicates the first digit of the code and the fast flash indicates the second digit of the code. For instance if you get slow slow fast fast fast that means you are throwing a 23 code. There will be a slight pause in between codes if there are multiple codes. Then pretty much google the code(s) you are getting or they should be listed in a haynes manual. I couldn't find a list of the codes online, but you may be able to find a .PDF impreza haynes manual online somewhere. Hope that helps! If you are in the area you can stop by and I will help you out with it. Its probably something dumb like "Complete engine failure" Or "Driver is a tool!" hahaha kidding
EsubaruJ is offline   Reply With Quote
Old 09-26-2010, 09:00 AM   #3
Subr-man
Member#: 169211
into a gearhead."
Goin' Back Old Skool
^ I concur, although the only basis I have to support it is from clipping a paper clip into a 89 corsica I use to drive during college I paid 80 bucks for. It would flash exactly like that in troubleshooting mode. Good luck!
Subr-man is offline   Reply With Quote
Old 09-27-2010, 07:30 PM   #4
EsubaruJ
Member#: 200008
03 wrx
haha yeah, some cars require a jumper like that. I'm pretty sure hondas do.
my STi is throwing a p0129 CEL Code..HELP PLEASE... billy720 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 02-17-2008 09:27 PM
My car is throwing codes, I searched here is what i found p8baller07 General Community 1 12-02-2006 08:04 PM
Why does my Subbie always throw a CEL on road trips? Hotrodguru Texas Impreza Club Forum -- TXIC 15 11-22-2004 07:51 AM
My Car is Throwing the Following Codes... Cthulhu Normally Aspirated Powertrain 25 09-24-2003 10:16 PM
my friend is throwing a car show anyone wanna be in it with me???? gokou006 Southern California Impreza Club Forum -- SCIC 8 08-12-2001 07:05 AM
