Old 06-25-2002, 01:18 PM   #1
Impreza777
Member#: 20453
Post Weird Rattle noise from Turbo on WRX ?
Ever since I installed a Turbo back exaust system on my WRX I get a weird rattle noise when the turbo kicks in. It only happens between 3000 - 4000 RPM right when the turbo starts to kick in. It almost sounds like something inside the turbo is rattling. It does it only when your driving and going though each gear. You can hear the Turbo start to kick in and make it's Hissss noise and then it makes a horrible rattle sound. It's not super loud, but it's just enough to bug you....and it just doesn't sound right. The Turbo still seems to works fine......doesn't feel like I lost any boost or anything. Just wondering if anyone has ever heard of this. And what steps I could take to fix this ?
Thanx, Jeff -
Impreza777 is offline   Reply With Quote
Old 06-25-2002, 01:22 PM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
Could it be a loose heatshield?
Calvin
cnk is offline   Reply With Quote
Old 06-25-2002, 01:36 PM   #3
Impreza777
Member#: 20453
Nawww.........the Heat shield isn't loose. Nothing is loose under there. I've checked everything. If something was loose I would probably hear the rattle at random times. You can only hear this noise right when the Turbo kicks in......and it only happens between 3000-4000RPM.....when you get to higher RMP's it seems to disappear. I'm pretty sure It has something to do with the Turbo.......so who knows ?
Old 06-25-2002, 01:48 PM   #4
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
I have a rattle that IS the heatshield, but the heatshield is NOT loose. All bolts are definitely tight. It happened when the car was stock too.
I can put it in neutral and rev to about 3000 RPM or so and the heatshield on the turbo will start rattling.
Then if someone else presses (pretty hard) on the heatshield in the right location the rattling/buzzing will stop.
For me, when driving, it is most prevalent when I let off the gas at around 3000-3500 with a small amount of boost (very slight vacuum to 3 psi or so)
I have no idea how to get rid of it besides taking off the heatshields.
Maybe you should take off the heatshields for a quick drive just to verify that's not your problem.
Concillian is offline   Reply With Quote
Old 06-25-2002, 02:05 PM   #5
Impreza777
Member#: 20453
Yea..........I've done that test also. It's not the Heat Shield.
I've sat in the driveway and reved it up through 4000 RPM's.
I've have a friend push on stuff while I did that. There was no noise. It only makes the noise when the Turbo kicks in while you are driving. When your on the highway cruzing at 3000 RPM....nothing. When your cruzing at slow speeds at low RPM's....nothing. It only does it when the Turbo comes on... up through 4000 RPM. It's really weird.
Old 06-25-2002, 02:16 PM   #6
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Uh, does it only happen at FULL boost?
Is it pre-detonation?
Old 06-25-2002, 03:13 PM   #7
Impreza777
Member#: 20453
No it disappears by full boost. It only makes the noise right when the Turbo is kicking in somewhere between 2500 - 3000RPM. And the noise stays up to about 3500 - 4000 RPM......and then it's gone. It's not loud........It's like a slight rattle instead of just a smooth Hisssss sound from the Turbo. Almost like whatever moves inside the Turbo is slightly rubbing against something. It doesn't seem like a big deal, but it just doesn't sound right.
Old 06-25-2002, 03:30 PM   #8
roybfr
Member#: 14456
09 BMW 335i Sedan
69/72/01 Corvettes
Are sure it is not the stock boost solenoid turning on and off. After installing my DP it became very noticable when boost was coming on up to about 5psi or so but then at full boost it would go away as full boost was reached. The sound was kind of metalic clanking.
Troy
roybfr is offline   Reply With Quote
Old 06-25-2002, 03:55 PM   #9
krave
Member#: 13908
2002 WRX Sedan
296 whp
well i figure its one of the two...either your exhaust is vibrating under boost and rubbing on something. or, some sort of exhaust leak?
krave is offline   Reply With Quote
Old 06-25-2002, 04:16 PM   #10
Impreza777
Member#: 20453
Yea...........I was thinking it could have something to do with some kind of exhaust reverb or something ? I did get under there a few times to make sure that the whole exhaust wasn't moving or vibrating......seemed to be very solid........but ya never really know I guess.
Old 06-25-2002, 04:46 PM   #11
Wreckleford
Member#: 887
It may very well be detonation.
Wreckleford is offline   Reply With Quote
Old 06-25-2002, 05:04 PM   #12
KwanDDS
Member#: 15709
2002 WRX WAGON
SILVER
Post
I'm pretty much stock and I get a similar sound. Its probably just a sound inherent to the WRX engineering. I have a stock exhaust, so I doubt its an exhaust leak.
Hope this helps.
KwanDDS is offline   Reply With Quote
Old 06-25-2002, 05:21 PM   #13
Impreza777
Member#: 20453
Cool..........Thanx for all the input !
Jeff -
Old 06-25-2002, 05:52 PM   #14
elgorey
Member#: 4374
06 Titan,99,94 SM
06 nasa spec miata champ
I have had this since I installed my DP. It bugged me at first but after doing a search, it looks like a common occurence and it is completely normal. Supposedly it is the boost control solenoid or wastegate fluttering
elgorey is offline   Reply With Quote
Old 06-25-2002, 07:36 PM   #15
BamBooI
Member#: 10945
2006 Evolution IX
I think the wastegate fluttering happens when you let off of the gas ie off of boost. What all mods do you have?
BamBooI is offline   Reply With Quote
Old 06-25-2002, 07:53 PM   #16
Impreza777
Member#: 20453
Nawwww...........only makes the noise when you are on the Gas. I just have a Turbo back Exhaust....that's all.
Jeff -
Help diagnose: weird rattle/flutter from turbo? Or is this knock? AcquaCow Engine Management & Tuning 1 05-15-2010 11:30 AM
Weird noise from turbo SYBugeye Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-02-2009 02:30 PM
Weird noise from Turbo area theSlothy1 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 22 11-05-2008 06:45 PM
Weird noise from turbo abgusaf Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-03-2007 07:18 AM
tapping noise from turbo on boost cold DISCOPOPE Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 11-15-2003 06:40 PM
