Old 09-25-2010, 01:10 PM   #1
Seda
Member#: 230378
2006 Impreza WRX TR
Thumbs up 1 Solution to Brake Lights Not Working
So the other day I was driving home from work when a stranger informed me that none of my brake lights were working. When I got home I immediately checked the brake light fuse (fuse #16 for my car), and it was fine. Checked a few other fuses which were also good. I didn't think the bulbs were out since both sides and my spoiler brake lights weren't working. Checked filament on the two taillight-brakelights anyways and they looked good.
I narrowed it down to being a problem with the brake switch connected directly to the brake pedal. I dug around and found a post saying you can bypass the switch by disconnecting it from the pedal and connecting terminals 1 and 2 on the switch. I took a wire and connected the blue/yellow wire slot to the white/black slot. All three brake lights came on, narrowing my problem down to the switch. I was going to try to clean up the switch and see if that was the problem. Before I even got that far I was able to figure out the problem.
The switch is connected by 2 nuts that lock against a plate between each other. I busted out a wrench to loosen them and realized they were so loose already I could turn them by hand. These nuts control the position and adjustment of the switch, so they must have just loosened up over time and came out of adjustment. I simply adjusted the position of the switch and made sure the nuts were tight and the brake lights seem to work fine now. Problem wasn't too daunting, but I figured I'd share my experience in case anyone else runs into this brake light problem.
Seda is offline   Reply With Quote
Old 09-13-2012, 11:18 AM   #2
ckc
Member#: 3696
2002 WRX Sedan WRB
'05 LGT wagon
I had a similar issue but it turned out to the switch going bad. In case anyone needs it, the part number for the stoplamp switch is 83370AA001 which should run you less than $50.
Thanks for the info on which wires in the harness to connect to test the lights. I bridged a wire between the blue/yellow and white/black after checking to see if 12v was getting to the blue/yellow, and low and behold, all the brake lights came on.
ckc is offline   Reply With Quote
Rear left brake light not working. but bulb isn't burnt out. help Blackout713 Electrical & Lighting 3 01-27-2010 12:49 AM
Brake lights not working wrxrono Electrical & Lighting 6 12-01-2009 02:03 AM
Brake lights not working gaveup Electrical & Lighting 6 09-24-2007 12:26 AM
Brake lights not working MPREZD Electrical & Lighting 9 06-17-2006 08:05 PM
'05 STi Brake Lights not working EXzacLEE Electrical & Lighting 2 05-03-2006 02:58 PM
