Old 09-25-2010, 03:15 PM   #1
iamthelazerviking
Member#: 247820
1992 Legacy Wagon
Default Idle switch/circuit trouble code on '92
My check engine light blinked a "42", which is a trouble code for idle switch or circuit. 1992 wagon, automatic. How/where can I check that out so I can solve the problem?
Thanks.
iamthelazerviking is offline   Reply With Quote
Old 09-27-2010, 12:45 PM   #2
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
The idle control solenoid is a stepper motor that sits on the top of the intake manifold.
jey is offline   Reply With Quote
Old 09-27-2010, 01:32 PM   #3
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
On the older cars, the idle switch is in the TPS.
Here's a copy & paste from my PM to you.
The idle switch is in the throttle position senser. Here's how to test/adjust the idle switch. If it doesn't adjust properly or you have problems afterwards, you may need to replace the TPS.
http://main.experiencetherave.com/su...S_testing3.jpg
Josh
Legacy777 is offline   Reply With Quote
P0519 trouble code on 2003 WRX mick_the_ginge Engine Management & Tuning 13 09-02-2010 08:17 PM
Error Code 0508 - Idle Control Circuit Low? MikeOliver Newbies & FAQs 0 07-27-2009 07:45 AM
Help with trouble code on 97 Leg. GT epike7915 Legacy Forum 5 04-13-2007 02:31 PM
TCM trouble code on 05 impreza metalsman Transmission (AT/MT) & Driveline 0 03-24-2006 02:12 PM
Trouble codes 22 & 42 on a BF Legacy GusS Legacy Forum 3 12-28-2001 03:56 PM
