Old 12-03-2010, 12:41 PM   #76
fircrest
Member#: 193852
2004 Forester XT
NEEDS
FORESTER
fircrest is offline   Reply With Quote
Old 12-03-2010, 08:43 PM   #77
thebigevilfoot
Member#: 253836
2008 AW e90 M3
2011 WRX 350/365- sold :(
If you don't mind me asking, what wheel brand are those? I'm having a hard time finding a nice set of wheels x_x
thebigevilfoot is offline   Reply With Quote
Old 12-03-2010, 10:22 PM   #78
Julio Bro!
Member#: 192923
Originally Posted by SCRAPPYDO View Post
Yes it would. The car was not designed for a staggered track in OEM form. But if your thinking of uber low car with huge camber, then handling is not your top priority anyway, so knock yourself out.
Still learning...what is staggered track?
Not going to lower the car and WRX's have some negative camber. Took a detailed measurement and front is 12mm and back is 22mm, this with 235/45 tires. That makes me think about 15/25, because 3mm is about 2/16 inch, just a little they stick out. Safe would be 10/20, but the only 10mm bolt-on spacer is FIC and I don't know if the OEM wheel would clear the studs.
Anyone tried those sizes on 2008-09 WRX?
Julio Bro! is offline   Reply With Quote
Old 12-04-2010, 01:02 AM   #79
modliving
Member#: 161273
2008 forester xt
They are drag wheels. Very cheap but good looking as long as you dont use the centercap or paint it.
modliving is offline   Reply With Quote
Old 12-04-2010, 01:23 AM   #80
Fat Black Pig Sac
Member#: 247911
2006 CGM WRX TR
soon Cyber Grey
Looks sick bro, I like it a lot
I put 25mm spacers all around 2 years ago, and now, after 30,000 miles the spacers look and perform like new
BTW, I have 8.5" wide rims with 45mm offset
Fat Black Pig Sac is offline   Reply With Quote
Old 02-28-2011, 05:43 AM   #81
JFChamp
Member#: 269961
2011 WRX
Default H&R springs vs busted struts?
I read earlier in this topic that the use of lowering springs (like H&R) will bust the struts on 08+ models... I own a 2011 WRX and I have a set of H&R that I am about to install... What exactly is the issue with this?? Any info appreciated.
Sorry to ask this here but I am new to the forum and can't create a thread yet!
JFChamp is offline   Reply With Quote
Old 02-28-2011, 09:55 AM   #82
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
The stock struts and shocks are very weak and sometimes start to leak when paired up with springs that lower the ride height and have an increased spring rate.
This is especially the case on the 08's (softest suspension) but also on the 09'-10's to a lesser extent.
I haven't heard anything yet about the this issue on 11's.
There should be plenty of threads specifically about this somewhere around here.
Breezio is offline   Reply With Quote
Old 02-28-2011, 10:01 AM   #83
JFChamp
Member#: 269961
2011 WRX
Thanks Breezio for the info... I will go ahead and give it a try anyway, if I end up with leaking struts I'll think about a coilovers setup
Old 02-28-2011, 11:32 AM   #84
snowflowmfg
Member#: 163700
2013 Impurzer
wFc #270
looks good
snowflowmfg is offline   Reply With Quote
Old 02-28-2011, 11:52 AM   #85
Ryan314
Member#: 82989
Hybrid EJ257
So are you running these spacers without longer wheel studs?
If so that is risky business.
Ryan314 is offline   Reply With Quote
Old 02-28-2011, 06:26 PM   #86
Breezio
Member#: 234357
2009 WRX
I think most of the 25mm spacers have their own built in studs.
I don't think there is even 25mm of extra stud to even start the nut on the factory studs...?
Old 02-28-2011, 09:15 PM   #87
JFChamp
Member#: 269961
2011 WRX
Ishiba type 2 spacers do have their own studs pre-mounted… No worries there
QUOTE=Breezio;33434481]I think most of the 25mm spacers have their own built in studs.
I don't think there is even 25mm of extra stud to even start the nut on the factory studs...?[/quote]
Old 02-28-2011, 09:21 PM   #88
Cartmans 03_Wagon
Member#: 222833
. Guess who's
back. Back again.
Why would you roll the fenders of a brand new car?
Cartmans 03_Wagon is offline   Reply With Quote
Old 02-28-2011, 09:31 PM   #89
Ryan314
Member#: 82989
Hybrid EJ257
So the spacers the OP is using doesn't require removal of the factory studs to replace with longer ones?
Old 02-28-2011, 09:42 PM   #90
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Datsun 71 240Z & 68 2000
forget that question my friend. Form >>> anything else to some people
SCRAPPYDO is offline   Reply With Quote
Old 02-28-2011, 10:16 PM   #91
KINGSPADE
Member#: 228359
Fn' nice fozzy in that first set of pics. -squattn-
KINGSPADE is offline   Reply With Quote
Old 02-28-2011, 11:18 PM   #92
Breezio
Member#: 234357
2009 WRX
According to post #5 in this thread, it sounds like the OP used spacers that have their own studs built into them.
You bolt the spacer to the hub with the original studs and some shorty lug nuts, then the spacer has it's own studs built into it that extend out and you bold your wheels onto those.
Old 08-11-2011, 10:28 PM   #93
gsheee
Member#: 277926
2011 Subaru WRX
Dark Gray Metallic
Pretty Interested in wheel spacers too. Think you convinced me
gsheee is offline   Reply With Quote
Old 08-12-2011, 01:54 AM   #94
AZRally
Member#: 103491
2013 Audi S4
I like it since they line up with the wheel well perfectly. That being said, from a distance I feel like they are too much in my face, and u might kick up a lot of debris towards your paint.
Why not get bigger wheels? Will the 11 STI wheels fit?
AZRally is offline   Reply With Quote
Old 08-12-2011, 02:47 AM   #95
NickDHdfc
Member#: 203250
2011 Bmw 135i
Alpine White
Yeah covered 10000x in this thread but from experience...had H&R on my 08 wrx and struts were blown in less than 700 miles...dont waste your time or money. Save your money and go straight to coils..Car looks great btw!
NickDHdfc is offline   Reply With Quote
Old 08-12-2011, 03:17 AM   #96
wakaka
Member#: 291193
a car with the eyelashes!http://goo.gl/uB8QH
wakaka is offline   Reply With Quote
Old 08-12-2011, 10:56 AM   #97
Bov_Rider
Member#: 142667
2006 STI 07
WRBlue
good. the car looks a lil more mean.
Bov_Rider is offline   Reply With Quote
Old 08-13-2011, 09:13 AM   #98
Julio Bro!
Member#: 192923
Finally went with 15mm front and 20mm rears. As I have 235/45, oddly enough one rear tire scrape. I had to roll the rear fenders a little and now it's cool.
Old 08-13-2011, 11:14 AM   #99
dScooby
Member#: 277465
2010 WRX
sl0w
I like the look except maybe a smaller spacer in the front..
dScooby is offline   Reply With Quote
Old 08-16-2011, 09:15 AM   #100
CincyWRX
Member#: 175201
11 WRX Limited 4dr
08 Triumph Speed Triple
Coilovers arethe better option, but all I hear on this thread is don't do H&R. With exception to above post, doesn't sound like anyone else tried it for themselves. I had H&R on my 08 for 20k miles, and then re-installed them on my 2011 for the last 4k miles and NO PROBLEMS.
I don't doubt that it could possibly cause a leak, and I know it is under-damped with the stocker struts, but I get annoyed when people post absolute "it will kill the car" type posts without personal experience (not directed at you Nick, since you were unfortunate to have it happen).
CincyWRX is offline   Reply With Quote
hubcentric rings with 25mm spacers? [email protected] Texas Impreza Club Forum -- TXIC 27 04-22-2009 02:26 PM
FS: ICHIBA 25mm Spacers 5x100 grippy monkey SCIC Private Classifieds 5 08-18-2008 05:44 AM
Eibach 25mm spacers w/built-in studs the aaron vaccar Wheels/Tires 1 05-28-2008 10:46 AM
