Old 10-01-2012, 12:46 PM   #101
dogbutter
Member#: 333014
new guy here.. but obviously not new to cars.
owned a toyota truck, GTI, GSR, and 4 BMWs(including a 330d), audis(A4 and A3), and 2 Mercedes, one scion, and now WRX.
OP.. looks great!
and hater.. it's amazing to me that if a mod suits your idea of a mod, it's fine, but if it violate someone's sense of a mod, then you sure have alot of excuses.
everyone agrees the stock tune is bad, and tuning is a great idea.. because either subaru engineer screwed up, or they have other reasons for tuning it that way.
but when someone adds a spacer, people want to claim how perfect setup is in stock(and wheel bearings blah blah) because 'subaru engineer did it'..
have some consistency.. factories don't produce cars in particular ways and their priority is not same as a owner/modder priority. subaru engineers did not select the offset based on same reasons we do. they probably did it because they don't want customers complaining that they get dirt on the side of the cars.
yes, of course, science is there.. further distance from the hub will create greater strain, but guess what? heavier tires and wheels will have the same affect.. and i don't see too many people calling that out.. and considering the pounding that a wheel bearing takes when it's on the pavement, i would say extra 25mm would play a small part in premature wearing of the bearings.
dogbutter is offline   Reply With Quote
Old 10-01-2012, 01:28 PM   #102
prescottn6ft7
Member#: 268918
2002 WRX Wagon
Fixed, and thanks for reviving a dead thread from over a year agp N008
prescottn6ft7 is offline   Reply With Quote
Old 12-25-2012, 04:30 PM   #103
deXter90
Member#: 285515
2011 wrx sedan
black
Originally Posted by modliving View Post
Once torqued down the studs are pretty much even with the spacers. If you buy 20mm spacers or smaller you will need wheels with cavities b/w the bolt holes or cut the bolts.
you wouldnt need extended studs? looking into 15 in the front and 25 in the back. Using stock wheels.
deXter90 is offline   Reply With Quote
Old 12-25-2012, 04:31 PM   #104
deXter90
Member#: 285515
2011 wrx sedan
black
NVM the H&R's come with studs the DRM series something like that
Old 07-30-2013, 02:37 PM   #105
pkluong
Member#: 341113
2013 WRX
Dark Grey Metallic
does the 25mm rub on stock under fully loaded? looks like a lot more people have 15mm over 25mm...why if 25mm is more flush?
pkluong is offline   Reply With Quote
Old 07-30-2013, 02:54 PM   #106
xluben
Member#: 261612
2002 WRX - 750WHP
9.5s @ 150mph
Wow, this is an old thread! Yes, 25mm can rub on stock suspension and wheels/tires. It will depend on your alignment, how many people in your car, and how big of a bump you hit. But it is possible that it will rub occasionally. That is why people opt for smaller.
xluben is offline   Reply With Quote
Old 07-30-2013, 03:07 PM   #107
pkluong
Member#: 341113
2013 WRX
Dark Grey Metallic
Ben, Whats the best then 20mm? no rub? im staying stock suspension.
Old 07-30-2013, 04:39 PM   #108
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Datsun 71 240Z & 68 2000
The best is NO spacers.
SCRAPPYDO is offline   Reply With Quote
hubcentric rings with 25mm spacers? [email protected] Texas Impreza Club Forum -- TXIC 27 04-22-2009 02:26 PM
FS: ICHIBA 25mm Spacers 5x100 grippy monkey SCIC Private Classifieds 5 08-18-2008 05:44 AM
Eibach 25mm spacers w/built-in studs the aaron vaccar Wheels/Tires 1 05-28-2008 10:46 AM
