Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 09-25-2010, 11:09 PM   #1
IMHARD2
Member#: 223775
2006 Fully built STi
Default Factory 06 STi HID replacement guide??
Does anyone know if there is a DIY for just replacing the factory HID bulbs in a hawkeye??? I've looked all over, but haven't found anything, and I'm sure there's something out there...Thanks
IMHARD2 is offline   Reply With Quote
Old 09-26-2010, 09:43 PM   #2
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
D2S capsules(bulbs) can be found just about anywhere. Theretrofitsource.com is a good place to start. The higher the color temperature is the less visible the light is in poor conditions such as rain, fog, etc. Prices are much more reasonable than factory replacements.
Old 09-26-2010, 10:15 PM   #3
02boxer
Member#: 139853
2002 wrx....its tsxy
TRS=great place to shop.
I'm running morimoto 4300k capsules, which is pretty much the OE standard...although I've used 5000k and felt they have a bit more usable light
chris
02boxer is offline   Reply With Quote
Old 09-27-2010, 07:39 PM   #4
IMHARD2
Member#: 223775
So I was asking about a guide for installation, not a place to buy bulbs...Good job for reading guys...
Old 09-27-2010, 07:48 PM   #5
02boxer
Member#: 139853
Have you even looked at it to try and figure it out?? Often times these things are really simple if you poke around
Old 09-27-2010, 08:16 PM   #6
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
Open the cap on the back of the headlight housing-this will be directly behind the projector. It should need 1/4 turn or so. There will be a cap, possibly metal underneath-this also gets a 1/4 turn to disconnect it. You now should be able to see the back of the HID capsule and the spring retainer holding it in place. Push and squeeze the retainer and it should pivot out of the way. The HID capsule should slide out easily. Replace the old capsule with the new one taking care not to touch the capsule(bulb) and reverse the previous sequence. If I can find pictures I will post them as well. Some say removing the battery is needed but I've been able to change both halogen and HID hawkeyes without doing so though its a pain. Sorry for the misread and please fill out your profile.
Old 09-28-2010, 12:17 PM   #7
IMHARD2
Member#: 223775
Fill out my profile?? And thanks, finally someone with some good insight...Just really wasn't sure about the backing cap and all, like if it was attached by screws, threads, etc. Thanks again
Old 09-29-2010, 05:35 PM   #8
nosmo
Member#: 53142
06' STI,02WRX,982.5
www.Flat4lv.com
FYI Your a retard. If you don'nt know how to change a headlight then you should not be high and mighty.
nosmo is offline   Reply With Quote
Old 09-29-2010, 08:04 PM   #9
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
IMHARD2
Member#: 223775
2006 STi
aspen white
Chapter?
Location?
This is what I meant by filling out your profile. Glad the info helped.
Old 10-09-2010, 05:20 PM   #10
Clockwork
Member#: 69452
2013 WRX
Tangerine Orange
Just did this today. It was very straight forward. No instructions really needed.
However I did need to remove my battery.
Clockwork is offline   Reply With Quote
06 sti hid replacement bulbs scoobywagon06 General Community 1 02-09-2010 08:02 PM
Retrofitting 06 STI HID parts into 06 WRX headlight? maverickar15 Electrical & Lighting 3 11-22-2008 10:46 AM
Swap 06 STi HIDs into 06 WRX Snowrider Electrical & Lighting 0 01-09-2008 03:12 PM
05 STi HID replacement question elitescouter Newbies & FAQs 4 09-24-2007 07:15 PM
06 sti HID lights to put on 06 wrx?? dodiox Electrical & Lighting 6 09-13-2005 07:58 AM
