Old 09-26-2010, 12:23 PM   #1
acssa
Member#: 184023
Default waterpump-over heating
So our quest to solve the overheating on the track goes on....
On the circuit track the car runs 86 deg C when revving up to 6000rpm.
Rev over 6000 to 7000 and the heat shoots up to 115 deg C
Why? Cavitation?
acssa is offline   Reply With Quote
Old 09-26-2010, 02:14 PM   #2
BlackJavaPearl04
Member#: 198522
98 LGT Limited
00 LGT -WRX swap
do you have an upgraded cooling system?
BlackJavaPearl04 is offline   Reply With Quote
Old 09-26-2010, 02:45 PM   #3
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Why? Cavitation?
This is water temp or oil temp? Can you provide us some info about your car? A description of the motor, cooling system, power output, etc would be somewhat helpful.
I have a totally stock long block on my 2005 STI but make pretty substantial power. My car got pretty hot at the track so I installed a large 25 row Setrab oil cooler and it really helped a lot.
dexterous is offline   Reply With Quote
Old 09-26-2010, 04:42 PM   #4
acssa
Member#: 184023
1.The cars has a water temp problem.
2. 440 WHP
3. used two engines 2.7L with 9:1 CR and a 2.5l 8.5 CR complete with heads, water pumps, oil pumps the lot
4. use bigger radiator....Ron D
5. Use oil cooler 17 rows
6. used cooler thermostat and no thermostat.
7. TMIC and no AC items... full caged stripped race car.
8. used water only and also water wetter.
Like I said we can drive to 6000rpm no problem...going to 7000 cooking!
Old 09-26-2010, 06:46 PM   #5
nhsilversti
Member#: 50895
. www.48hrs.info
donation chairman
you need to use the wrx(?) water pump, it has a cast impeller and supposedly does not cavitate
nhsilversti is offline   Reply With Quote
over heating/ heat no longer working johnlattanzi Newbies & FAQs 10 02-22-2010 11:04 AM
Over Heating Again.... WRX02CRH Tri-State Area Forum 2 12-09-2002 10:33 AM
:( over heating...why??? stant093@ Legacy Forum 10 11-27-2002 08:35 PM
head unit over heats cspunk Car Audio, Video & Security 3 04-29-2002 11:33 PM
Over Heating Problem akuhner Normally Aspirated Powertrain 24 12-28-2000 07:45 AM
