Old 09-26-2010, 01:40 PM   #1
sixthgearjunkie
Member#: 219497
1997 Impreza L
Default Internal paint job WAS good
I went out to autozone and picked up some paint. I spent about a week doing the paint job off and on using what i believe to be the appropriate paints, but now the job is chipping. when doing the job i covered all the parts i didn't want to have ruined and took some out, but the dash was a huge problem and i have no desire to do the whole thing in the car again.
A. what kind of paint should i be using for which parts and
B. how can i take out the entire dash so as to have better access to it for the job
here are some pics of the job so far, still incomplete
id=2821http://www.mysubie.com/vehicle?id=2821
sixthgearjunkie is offline   Reply With Quote
Old 09-26-2010, 02:23 PM   #2
barnburner
Member#: 220484
2003 PSM WRX
sweet mother of god
barnburner is offline   Reply With Quote
Old 09-26-2010, 02:38 PM   #3
rwdCivic
Member#: 155986
2013 Caddiliac ATS
Raven
Looks sweet bro.
rwdCivic is offline   Reply With Quote
Old 09-26-2010, 02:44 PM   #4
sts2689
Member#: 145708
2007 WRX TR
TopSpeed Built =D
insert face palm
sts2689 is offline   Reply With Quote
Old 09-26-2010, 02:45 PM   #5
iRazor
Member#: 257035
2008 wrx
kool-aid red
lulz...
iRazor is offline   Reply With Quote
Old 09-26-2010, 03:02 PM   #6
kickniteasy
Member#: 201661
2009 WRX "Stage 2"
2002 Forester
I think entering a demolition derby might fix the problem
kickniteasy is offline   Reply With Quote
Old 09-26-2010, 03:07 PM   #7
cmiller219
Member#: 187179
5 Golden
Rings
u spray painted the seats
cmiller219 is offline   Reply With Quote
Old 09-26-2010, 03:08 PM   #8
polarisboy385
Member#: 222041
2009 Impreza 2.5i
PRP
Not my thing imo
I've painted mine, BUT I took out the pieces and prepped them well, you got a problem cause unless I'm not seeing it you didn't sand your dashboard (I'm on a cellphone so clarity isn't the greatest)
What you should do is take that paint off
Cover everything, take your stencail lay it and tape it.
Then sand the stencil and apply the appropriate coats. Keep the stencil on after each coat. And remember lightly sand between coats so the paint has something bind with. I also found the krylon seems to work the best for plastics interior plastics, and has been holding up well on my grill exterior as well!
Let me know about anything else you did procedurely
polarisboy385 is offline   Reply With Quote
Old 09-26-2010, 03:11 PM   #9
jagr_200
Visiting NASIOC Timeout
Member#: 230710
2004 STi John Tuned!
04 AW Shwagon
Originally Posted by sts2689 View Post
insert face palm
That is the ugliest thing I have ever seen. lol
jagr_200 is offline   Reply With Quote
Old 09-26-2010, 03:12 PM   #10
dobiewrx
Member#: 162681
2002 Impreza Wrx
Midnight Blue Pearl
Okay I am not gonna flame. So what you probably didnt do was clean the surfaces 100 percent, then you probably didnt use a abrasive to give the paint something to hold onto. Just something to scuff the surface ever so slightly. Also there is an adhesive promoter that should have been applied to the surfaces right before you painted them. All of these things can be found in your autozone auto paint section.
And no, I dont have the interior of my car painted.
dobiewrx is offline   Reply With Quote
Old 09-26-2010, 03:41 PM   #11
Dave_zok
Member#: 225034
2006 STI
good advice. I thought i saw everything but im going to have to email some of these pictures out monday.
I dont know what you had as an visioin but i hope that was not it. Man that is nasty
if you did not start with a clean surface then you need to start over. use a 50/50 alcohol water mix to clean then prime, paint, sand/scuff, paint. This process should give good results.
Also vinly interior, or anything with some flex, is never a good thing to paint. the fabric or material will flex, bend and bow and return to its natural location. the painted layer will not do this. Instead of the paint flexing it will just crack.
Dave_zok is offline   Reply With Quote
Old 09-26-2010, 04:09 PM   #12
iRazor
Member#: 257035
2008 wrx
kool-aid red
ive painted the interior of a few cars including 3 of my own i've found 220 grit sandpapaer for me works the best.. wash the area first with dawn dishsoap diluted in water so it gets rids of any armor all or grease from other "shine" makers lightly sand, clean again tape off and stencil your design if you cant actually remove your dash (its just easier to remove to prevent overspray and dont have to worry about messing up with your restricted angles and at the end if your using that autozone interior paint i tried and ended up with good results by giving it 1 slight coat of the clear engine enamel to prevent it from cracking in exposed sun
Old 09-26-2010, 04:54 PM   #13
Kilo6_one
Member#: 229396
Now Ive seen it all, i guess im going back to bed.
Kilo6_one is offline   Reply With Quote
Old 09-26-2010, 05:06 PM   #14
djinn
Member#: 212818
2010 Impreza 2.5i
Satin White Pearl
Agreed! ...
djinn is offline   Reply With Quote
Old 09-26-2010, 05:08 PM   #15
nairbmik
Member#: 220259
09 2.5i
SSM
Hahahahahahaha
What exactly is a "DIY momo shift knob" ?
nairbmik is offline   Reply With Quote
Old 09-26-2010, 05:16 PM   #16
Krang
Member#: 134272
Chapter/Region: HIIC
2002 WRX Wagon - WRB
ej207 v8 vf37
Looks good man. You need to prep your interior pieces before you paint them using sandpaper, google it.
Also...
Ensanguined Semblance makes absolutely no sense whatsoever.... Unless the next step is to cover your subie in blood?
Krang is offline   Reply With Quote
Old 09-26-2010, 05:37 PM   #17
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Mr. Smoke is crying right now. Not in a good way.
You painted your interior wrong. My entire interior is painted and it's going strong after 2 years.
Smoke is online now   Reply With Quote
Old 09-26-2010, 05:38 PM   #18
Ryguy32789
Member#: 214559
2005 WRX
I hear you can help the paint cure by lighting the car on fire.
Ryguy32789 is offline   Reply With Quote
Old 09-26-2010, 05:41 PM   #19
AcquaCow
Member#: 36838
2000 RS Sedan
2004 STi w/RS body swap
I'd probably re-do it but with more complementary colors vs mixing primary colors.
The combo just makes my retinas vibrate a bit when trying to see one color separate from another.
http://en.wikipedia.org/wiki/Color_theory
http://websitetips.com/colortools/sitepro/
-- Dave
AcquaCow is offline   Reply With Quote
Old 09-26-2010, 06:32 PM   #20
thewritingwriter
Member#: 243214
2006 SOLD WRX TR
SGM
thewritingwriter is offline   Reply With Quote
Old 09-26-2010, 06:58 PM   #21
Kilo6_one
Member#: 229396
I used to be in the sporttruck scene, painting dashes was very common, usually we would glass them, but when we didnt do it it was all about the prep work, in face the first truck i ever did back in 98 still looks like new....... wish i had pics of it, but we painted the dash and it ended up looking like the outside finnish.
this just looks very elementry like someone had an idea (be it goo or bad who cares) and did not know the first thing about how to carry out the idea.
i cant even imagine the work trying to correct it..........
Old 09-26-2010, 07:17 PM   #22
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Painting interiors that would hurt your rods and cones is something southern people like to do.
Old 09-26-2010, 07:21 PM   #23
jdmSpecC760
Member#: 151598
04 WRX STI
jdmSpecC760 is offline   Reply With Quote
Old 09-26-2010, 07:47 PM   #24
That guy in Maine
Member#: 256642
'00 Forester S,
'94 CBR600F2, '12 CBR250R
Is this some sort of a joke? Really you PAINTED THE SEATS?? Good luck selling that car if you ever try.
That guy in Maine is offline   Reply With Quote
Old 09-26-2010, 08:29 PM   #25
05ASPINREX
Member#: 190454
2005 wrx stage II
white like my bitch
holy ****
05ASPINREX is offline   Reply With Quote
What shop does good paint jobs? MagicMT Bay Area Impreza Club Forum -- BAIC 3 01-31-2012 12:49 AM
I was thinking about a new paint job, Your thoughts??? singincanary Tri-State Area Forum 17 08-19-2005 02:16 PM
How much for a good paint job? Siper2 Interior & Exterior Modification 11 07-19-2004 07:51 PM
Anyone gotten a good paint job in LA for less than $2000? BLCK DVL Southern California Impreza Club Forum -- SCIC 7 06-15-2003 07:48 PM
How much for a good paint job??? Whose gotten one? 96Lconversion Interior & Exterior Modification 18 02-27-2001 10:14 AM
Message Board Statistics All times are GMT -4. The time now is 09:45 PM.
