Old 09-26-2010, 06:00 PM   #1
taylorjonesphoto
Member#: 245925
1997 Impreza OBS
Acadia Green
Default Driver's side foglight not working (97 OBS)
Hey guys, I've tried doing a little research and using the search but not finding much for answers relating to my specific problem.
When i bought my car only the passenger side foglight would turn on, I just assumed that the driver's side bulb was burnt out. I ordered some HELLA YellowStars to replace the old bulbs.
The driver's side bulb will still not turn on.
I pulled apart the assembly again to make sure everything was plugged in properly and everything looked correct. I checked what I believe to be the right fuse however the labeling on the fusebox wasn't very descriptive so there's a possibility I didn't check the right fuse.
I've seen at least 3 other posts about this particular issue and none of them had any resolution in their posts. I'm an electrical n00b and not much of a wrench monkey so I'm quite perplexed.
Thoughts?
taylorjonesphoto is offline   Reply With Quote
Old 10-01-2010, 03:22 PM   #2
taylorjonesphoto
Member#: 245925
1997 Impreza OBS
Acadia Green
does anyone have any input on this?
Old 10-05-2010, 03:26 PM   #3
taylorjonesphoto
Member#: 245925
1997 Impreza OBS
Acadia Green
the rainy season is coming and i want to fix this issue before then!
Old 10-05-2010, 03:45 PM   #4
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
Get a wiring diagram and check for continuity from the light backwards and make sure you were checking the correct fuse(s). If you do not have a multimeter or short spotter now would be the time to get one. I know this might not seem like much help but not being there makes chasing down electrical gremlins next to impossible.
Old 10-08-2010, 12:00 PM   #5
taylorjonesphoto
Member#: 245925
1997 Impreza OBS
Acadia Green
where is a good source for wiring diagrams? i did a search and didn't come up with a whole lot, also didn't see any stickies about it.
Old 10-08-2010, 01:48 PM   #6
aoscjs
Member#: 255221
1997 Impreza L 2.2
Green
i just went to walmart bought driving lights ($20) then to amazon.com and HID conversion ($40) then there they were bitchin bright fog lights for around $60 lol and super easy to install and no problems and work great in fog, rain, and snow and mean people who bright light me
aoscjs is offline   Reply With Quote
Old 10-11-2010, 12:05 PM   #7
taylorjonesphoto
Member#: 245925
1997 Impreza OBS
Acadia Green
i'm guessing this is your solution to my problem? otherwise i hardly see how this is relevant haha.
Old 10-11-2010, 12:42 PM   #8
jonklein611
Member#: 117776
2011 WRX Limited 5dr
WR Blue Pearl
check the ground wire. Normally the fogs are grounded individually. Are you getting full voltage at the socket?
jonklein611 is offline   Reply With Quote
Old 10-11-2010, 04:48 PM   #9
taylorjonesphoto
Member#: 245925
1997 Impreza OBS
Acadia Green
i need to grab a battery for my multimeter to check. when i put the bulbs in i assembled them exactly as they were which included putting the ground wire around one of the screws that goes into the light assy. the only thing i can think of is that there seperate fuses for each side which seems illogical or that something is disconnected on the way up to the switch.
Old 10-11-2010, 04:55 PM   #10
taylorjonesphoto
Member#: 245925
1997 Impreza OBS
Acadia Green
OH! I can't believe I didn't mention this before. when i disassembled the light in question there was what looked like corrosion around the bulb and it had a white powder in the lens and in the weatherproof back piece.
Old 10-12-2010, 07:28 AM   #11
jonklein611
Member#: 117776
WR Blue Pearl
clean that stuff off and get yourself some fog light grease (i'm not joking) it's the little $0.99 packets @ advanced. It will keep the connections from corroding. sounds like the resistance of the crud is too high and sapping the light of the voltage it needs.
Old 10-12-2010, 08:48 AM   #12
taylorjonesphoto
Member#: 245925
1997 Impreza OBS
Acadia Green
Haha the guys at autozone always try to sell me that crap!
Old 10-27-2010, 08:15 PM   #13
taylorjonesphoto
Member#: 245925
1997 Impreza OBS
Acadia Green
I busted out my meter and sure enough both lights are getting power. Now I'm stumped.
Old 10-27-2010, 08:31 PM   #14
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
there's a reason people shine their brights at you - you're running illegal HIDs in ****ing Wal-Mart driving lights.
OP, don't listen to this idiot.
Pull your bumper and look for electrical problems - the wiring tester is a good idea, too.
XanRules is offline   Reply With Quote
Old 10-27-2010, 08:32 PM   #15
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
you coulda fried another bulb. Switch the two around - you probably have a grounding problem or a short somewhere.
Old 10-28-2010, 07:14 AM   #16
jonklein611
Member#: 117776
WR Blue Pearl
Or super high resistance somewhere. Check how many ohms you have between your relay and the bulb socket.
Old 10-28-2010, 12:10 PM   #17
taylorjonesphoto
Member#: 245925
1997 Impreza OBS
Acadia Green
will definitely check this out. what is a normal amount of ohms?
Old 10-28-2010, 12:15 PM   #18
jonklein611
Member#: 117776
WR Blue Pearl
For just wire it should be fairly low (i'd say less than 5 ohms give or take). One problem I had is one of the connections to the relay went bad and wasn't making a good connection between the relay and the wire, it was like 20-30 ohms. A general rule of thumb is the resistance across the bulb should be more than the resistance of the wiring.
If the wire has more resistance than the bulb, it's basically "stealing" the power from the bulb, and there isn't enough to get the light to ignite.
driver's side foglight, hella500 rockshields anthonyrb98 Exterior/Styling 7 03-26-2007 08:07 PM
WTB: Driver's side headlight for 95-97 Legacy Legacy Forum 4 09-13-2006 11:00 PM
WTB: driver's side foglight 2002 sovietjet Private 'Wanted' Classifieds 1 03-08-2006 11:18 AM
FS: 02-03 Driver's Side Foglight $50 Shipped OBO proletariandan Private 'For Sale' Classifieds 8 12-25-2005 08:32 PM
WTB: 02-03 Impreza Driver's side foglight iggy.b.dawg Private 'Wanted' Classifieds 4 01-28-2005 10:33 PM
