Old 09-26-2010, 07:20 PM   #1
trininox
Member#: 62131
2005 Impreza WRX STi
Crystal Grey Metallic
Question Automatic Trans Leak after install - Torque converter issues
So i'm lookin for some ideas,
I pulled the 2.2NA motor out of a legacy to do headgaskets, originally the Torque converter was attached to the motor when it came out. It was put back on the transmission side and the flexplate bolts were attached to it after the motor was dropped in.
It would seem fluid leaks after the first startup and im not sure where to even look, is the torque converter not in right? its all buttoned up pretty well no gap between the block and bell housing.
Its the first automatic i've messed with, never had an issue with manual trans!
On top of that it sounds like the cams werent aligned 100% cuz its a tad rough runnin so it may all have to come apart anyway...
Thanks for your suggestions!
trininox is offline   Reply With Quote
Oil Leak After Installing Downpipe/Uppipe misterjoshua Factory 2.0L Turbo Powertrain 6 07-28-2008 07:18 PM
Anyone know how to install torque converter/valvebody? cjx17 Mid West Subaru Owners Club Forum -- MWSOC 8 10-08-2007 11:21 AM
installing Torque converters 04WRBWRX Transmission (AT/MT) & Driveline 1 08-13-2007 06:39 AM
Vacuum leak after installing TurboXS FMIC rewt Factory 2.0L Turbo Powertrain 10 04-17-2005 02:05 AM
How much Auto Trans Fluid does the Torque converter hold? bdoss123 Legacy Forum 5 10-07-2003 07:00 AM
Message Board Statistics All times are GMT -4. The time now is 09:52 AM.
