South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 02-21-2011, 11:28 AM   #376
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
These suckers hold the rear hub to the lateral links. Typically, they either bend or rust and are really hard to remove. The four I sent to the plater came back great and since they were not bent, I used them. If you had to buy them from Subaru, they are like $23 each!
JDM axle nuts, yo!
Hubs installed:
Old 02-21-2011, 11:40 AM   #377
vilar17
Member#: 213592
07 wrx limited
08 STI
Do this for my car please
vilar17 is offline   Reply With Quote
Old 02-21-2011, 12:54 PM   #378
kpluiten
Member#: 120273
06 WRBWRXWGN
No problem. I'll get right on it in my spare time.
Old 02-21-2011, 01:19 PM   #379
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
Car is looking sick nasty man. I likea the way it's gettin' done!
KP is offline   Reply With Quote
Old 02-21-2011, 01:23 PM   #380
kpluiten
Member#: 120273
06 WRBWRXWGN
KP: Straight up baller
Me: what?
KP: The rear end on your car
KP: the under side of it
KP: Very cool
Me: thanks dude.
Me: so you're saying I have a sexy rearend?
KP: I'm saying I would definitely like to lube it up
Old 02-21-2011, 01:33 PM   #381
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
amirite or amirite?
Old 02-25-2011, 02:44 AM   #382
kpluiten
Member#: 120273
06 WRBWRXWGN
Well, I made some more progress tonight.
A couple of nights ago, I painted the underside of the car. Why? I don't know. But it was quick and relatively easy. It looks pretty nice too. Until the first puddle I'm sure.
Old 02-25-2011, 02:46 AM   #383
kpluiten
Member#: 120273
06 WRBWRXWGN
First, I got an old STi fuel tank and metal shied thing from Jay (thanks dude! ). My want for this was that it had drain plugs and for whatever the reason, the wagon didn't come with drain plugs. Since I had the fuel tank and all the lines out to remove the ridiculous amount of mud from the underside of the car, I figured I'd simply throw the STi tank back in in place of the WRX one. Not so easy. It turns out some of the lines are different both in the way they attach to the hard lines on the body, but the evap system/filler neck has differences too. I fixed this problem by swapping all of the lines and valves from the WRX tank to the STi tank and all was well. There is a silly amount of lines down there to deal with.
Was it worth it just for drain plugs? Probably not, but it's done now.
Some lousy pictures of the STi shield and tank (hint: looks just like any other tank):
Old 02-25-2011, 02:51 AM   #384
kpluiten
Member#: 120273
06 WRBWRXWGN
I also installed the rear subframe assembly. It's stupid easy to install, literally 6 bolts if you pre-assemble it on the floor, away front the car. I just put the R180 on a trans jack and hoisted it up. Seriously took about 10 minutes.
I installed the Kartboy outrigger bushings while I was doing it as well.
Old 02-25-2011, 03:10 AM   #385
kpluiten
Member#: 120273
06 WRBWRXWGN
Lastly, I messed around with the shifter linkage. Originally, when I bought the 6 speed, I bought linkage from another NASIOC member. He told me that it was brand new JDM linkage. When it arrived, it was in fact brand new and unopened in the box, but I never investigated what the difference between JDM and USDM linkage was if any.
The JDM linkage was gold, so I assumed it was the non-factory sort throw linkage. A few month later I stumbled upon some used green linkage which is supposed to be the USDM factory short throw linkage so I bought it. It also came with some kartboy front and rear bushings. Tonight I went to swap the two and found out that they were identical. So the linkage I had was the factory short throw (which is pretty pathetic).
All of the lengths, angles and pivot points line up when compared:
So I decided to keep the original gold linkage since it was in much better shape (on the trim rings), but I swapped over the kartboy stuff.
Front bushing.
Stock is a joke.
Rear bushings. Once again, the stocker is laughably soft.
Installed:
Old 02-25-2011, 03:14 AM   #386
kpluiten
Member#: 120273
06 WRBWRXWGN
I obviously haven;t driven with the new bushings yet, but already, I can tell there is far less play in the shifter assembly and you fell more of a "click" when moving through gears. I think I might order a Kartboy short shifter and call it a day.
Old 02-25-2011, 09:20 AM   #387
madmax_087
Member#: 197077
1992 Dodge Ram W150
BAN CORINATOR
Angry
Originally Posted by KP View Post
amirite or amirite?
Youamgay
Originally Posted by kpluiten View Post
Lastly, I messed around with bla bla bla who cares bla bla
So this is why you didnt show last night? You were messing around with your stupid wagon?! Well thanks for making the meet so spectacular, you jerk!!
madmax_087 is offline   Reply With Quote
Old 02-25-2011, 10:02 AM   #388
kpluiten
Member#: 120273
06 WRBWRXWGN
Originally Posted by madmax_087 View Post
Youamgay
The main reason I didn't go was because I had to work late and was on call until about 9:00. Going to the met, while fun, is kind of a pain as it's a 35 minute drive from my house. Plus I just need to get this car done.
Old 02-25-2011, 10:56 AM   #389
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
..... says the jerkoff that went home, instead of Red Robin with the rest of us.
Looking awesome Ken! obviously a labor of love!
Z0rr0 is offline   Reply With Quote
Old 02-25-2011, 11:41 AM   #390
kpluiten
Member#: 120273
06 WRBWRXWGN
Thanks dude. How's your car coming? Did you get the IC pipes and front bumper figured out? I'm glad the diff wasn't something more serious. I was not looking forward to rebuilding/re-shimming that sucker with you. It's a lot of work!
Old 02-25-2011, 12:02 PM   #391
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
I heard you guys were going to redrobin, and went home. F that place.
Old 02-25-2011, 12:26 PM   #392
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
dropping the car of with efrain tuesday, so he can fix the piping.
saw your rear links when i was there the other night, looking goood!
Old 02-25-2011, 12:29 PM   #393
Evil Imports
Member#: 14732
+ 13 B8
but you have driven my wagon with all that stuff in
Evil Imports is offline   Reply With Quote
Old 02-25-2011, 02:29 PM   #394
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
As have I, not far, but it felt good!
Old 02-25-2011, 03:12 PM   #395
05bluesti
Member#: 251804
05 WRB STi
kartboy ss is awesome, i went from factory short throw to kartboy ss with front/rear bushings, amazing now, how it shoulda come stock
05bluesti is offline   Reply With Quote
Old 02-25-2011, 03:38 PM   #396
kpluiten
Member#: 120273
06 WRBWRXWGN
Any chance you could pick my stuff up and bring it to the meet when you're there? It would save me a serious drive.
Old 02-25-2011, 03:46 PM   #397
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
He can't remember to bring my xboxes from his house, I doubt he'll remember to grab your stuff while he's there, AND bring it to the meet with him.
Old 02-25-2011, 05:22 PM   #398
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
KP, just come get them... you can bitch about it all you want, but you haven't got a hold of me all week...
kpluiten, sure, i'll grab them tuesday when i drop the car off.
Old 02-25-2011, 05:37 PM   #399
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
The simple fact of the matter is you said you would bring them to the meet 3 weeks ago finished. You didn't show up that week. 2 weeks ago you didn't have them done, but said to stop by that weekend. Then you didn't have the tools Then I called and talked to you and you said you were waiting for me to come over for you to get the stuff to do it.
I'm not mad, or bitching, just giving you a hard time. If you don't want to do it, just say it. I'll have someone else do it or send it into Microsoft at this point.
Old 02-25-2011, 05:39 PM   #400
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
that might be better for both of us. lets keep this **** out of ken's thread.
I am master of Procrastination! subySerb Off-Topic 13 04-29-2008 03:29 AM
By Build Thread: 1991 Legacy Turbo with EJ20G Swap livestrong14 Member's Car Gallery 69 03-14-2007 08:59 PM
Some nice things can be borne out of procrastination [56k beware] sherifx Off-Topic 6 01-21-2007 09:18 PM
Tale of Two Cities: City of God and City of Lost Children Snoopy Off-Topic 7 11-07-2005 11:03 AM
Just sit right back and you'll hear a tale, A tale of a fateful nap... collegedropout Off-Topic 4 08-01-2004 09:36 AM
