South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 10-20-2013, 04:57 PM   #826
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Originally Posted by lox View Post
'mericans
expensive, but worth it
I'm sure there are cheaper fabrication/welding guys in the valley, but with Kent, you can trust that it is done right the first time and every time. His work is top notch and you pay for that piece of mind. I've generally been disappointed when I choose the lowest cost bidder for a job.
One trip under the M3's he builds will let you know what he is capable of.
Originally Posted by Infantry209 View Post
Wow k, looks great man. Keep it up.
Thank you.
Originally Posted by bdj238 View Post
Question for you, what model type front sway bar are you using? Sedan or wagon? I have the aluminum front control arms on my wagon and had a wagon specific Whiteline bar on mine and it never fit right, so someone suggested going to the sedan due to the wider track that the control arms give you but again, it still doesn't fit right. I'm using solid endlinks and plan on swapping over to the ball joint style to try to help but am not sure that alone will solve my issue.
I'm using the Hotchkiss wagon front sway bar. I'm using hemispherical end links and collars to keep the bar centered. Lastly, I'm using custom washers/spacers between the bar and the link and the link and the arm. There are some pictures a few pages back. So far, I have had no issues. The front end feels solid and planted. No noise or banging.
What doesn't fit right on yours?
Originally Posted by Z0rr0 View Post
Very Nice, Ken!
Thank you.
Originally Posted by 3mlwhly View Post
great build man, and what are the part numbers for those power steering adapters?
The ones on the rack? I think they were these ones:
http://www.anplumbing.com/search/ind...h_text=9894DBJ
I threw out the packaging, but I'm pretty sure it is these. One of each. I modified mine slightly as described above in that section, but many guys run them as-is with no issues. Sometimes a new oring on the rack line helps a lot.
Originally Posted by SaabaruMike View Post
I'm speechless Ken. Amazing work!
I've seen what you did to your GN, so I'll take that as a big compliment.
Old 10-20-2013, 05:00 PM   #827
kpluiten
Member#: 120273
06 WRBWRXWGN
Originally Posted by IVIattIVIan View Post
Untitled by IVIattIVIan, on Flickr
Great pictures, thanks!
Old 11-04-2013, 01:13 AM   #828
05bluesti
Member#: 251804
05 WRB STi
Ken, do it meow
05bluesti is offline   Reply With Quote
Old 11-05-2013, 01:35 PM   #829
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
Reminds me of Wagonwheel or whatever his name was on here.
KP is offline   Reply With Quote
Old 11-05-2013, 01:46 PM   #830
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
Helped Ken tune this beautiful wagon last night.
Color me impressed, there was no fight, no issues, just a smooth running car that loved to be tuned.
Ken, if you don't mind, here's the VD graph.
Z0rr0 is offline   Reply With Quote
Old 11-05-2013, 03:19 PM   #831
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
Old 11-05-2013, 03:59 PM   #832
SaabaruMike
Member#: 113342
2014 WRX
Nice. Looks like it pulls hard and flat.
SaabaruMike is offline   Reply With Quote
Old 11-05-2013, 04:00 PM   #833
Z0rr0
Member#: 23123
15 WRX 6MT
07 Legacy SpecB
Feels that way too. I was literally shocked by the timing values we got away with on ACN91.
Old 11-06-2013, 05:04 PM   #834
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
2 legit 2 quit
Old 11-07-2013, 03:30 PM   #835
Aki223
Member#: 257190
1994 BC6
ABM
Really nice build. Clean!
Aki223 is offline   Reply With Quote
Old 11-10-2013, 01:33 AM   #836
Evil Imports
Member#: 14732
+ 13 B8
Evil Imports is offline   Reply With Quote
Old 11-10-2013, 03:16 AM   #837
Erik
Member#: 168774
Erik is offline   Reply With Quote
Old 11-10-2013, 06:35 AM   #838
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
Haha Yes!
Old 11-10-2013, 02:23 PM   #839
TwinscrollGT35R
Member#: 256810
I have some photos from vegas I'll post up in a bit.
TwinscrollGT35R is offline   Reply With Quote
Old 11-12-2013, 02:34 AM   #840
kpluiten
Member#: 120273
06 WRBWRXWGN
I picked up some interesting parts tonight:
I'm still not sure what my plans are for this project, or even the timeline, but the opportunity to pick these up presented itself. I got to cut the quarters oy which was kind of fun.
I'm thinking sedan factory widebody with 05-07 rear fender arches, STi side skirts, and CS bottom line kit all around. But we'll see what happens.
Old 11-12-2013, 03:32 AM   #841
05bluesti
Member#: 251804
05 WRB STi
And Karlton flares
Old 11-12-2013, 11:50 AM   #842
amroof
Member#: 211224
2005 Saabaru
Who knows
You dirty hor3 I'm getting all my wide body parts assembled for my wagon! Should be badass!
amroof is offline   Reply With Quote
Old 11-12-2013, 11:58 AM   #843
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
You should have just bought an STI, poser.
Old 11-12-2013, 12:09 PM   #844
kpluiten
Member#: 120273
06 WRBWRXWGN
Originally Posted by 05bluesti View Post
Ken, do it meow
That's probably wider than I need to go. I want to fit 265's all around. I should be able to do that easily with the sedan widebody.
His wagon was so cool. I haven't seen it in years though.
Thank you for your help. I'm surprised what that little motor/turbo can do on pump and only 20 psi. I really can't wait to try 24-25 psi and e85.
Car ran great up to Vegas, but needs a bit of work on the high load/low RPM regions of the map as I was getting a bit of knock climbing up those hills into the Vegas valley. If I shifted down and brought the RPM up and reduced load, the knocking stopped.
You should have heard it on Las Vegas Blvd...
It's a lot of fun. Not the torque of the 2.5, but revs like a sport bike. No joke.
Originally Posted by kellygnsd View Post
2 legit 2 quit
Thank you!
Thank you!
Originally Posted by Evil Imports View Post
That was a long drive. And some dick in a riced out Forester kept tailgating me.
Originally Posted by Erik View Post
Have you though about charging for your work?
You were the guy standing on the roof of the parking garage?
And Karlton flares
Baby steps. This probably won't happen until later this year as my wife would like to buy a house...
What wagon is this?!?
Old 11-12-2013, 12:19 PM   #845
kpluiten
Member#: 120273
06 WRBWRXWGN
It would have been cheaper, that's for sure.
Old 11-12-2013, 01:09 PM   #846
Evil Imports
Member#: 14732
+ 13 B8
It might have been cheaper to cut a STI and make it a wagon at this point
Old 11-12-2013, 01:33 PM   #847
kpluiten
Member#: 120273
06 WRBWRXWGN
Old 11-12-2013, 03:51 PM   #848
TwinscrollGT35R
Member#: 256810
And one more time
Old 11-12-2013, 04:07 PM   #849
TwinscrollGT35R
Member#: 256810
Deleted again
Old 11-12-2013, 04:27 PM   #850
TwinscrollGT35R
Member#: 256810
deleted
I am master of Procrastination! subySerb Off-Topic 13 04-29-2008 03:29 AM
By Build Thread: 1991 Legacy Turbo with EJ20G Swap livestrong14 Member's Car Gallery 69 03-14-2007 08:59 PM
Some nice things can be borne out of procrastination [56k beware] sherifx Off-Topic 6 01-21-2007 09:18 PM
Tale of Two Cities: City of God and City of Lost Children Snoopy Off-Topic 7 11-07-2005 11:03 AM
Just sit right back and you'll hear a tale, A tale of a fateful nap... collegedropout Off-Topic 4 08-01-2004 09:36 AM
